1 (edited by De-Backer 2020-09-22 17:56:34)
Topic: Qt 6.0 development and qelectrotech
Currently, the Qt 6.0 development timeline is planned to be the following:
Structure and platform freeze at 30th June
Feature Freeze at 31st August
Alpha Release at 14th September
Beta 1 Release at 1st October
Release Candidate at 17th November
Final Release 1st December
Qt 6 requires C++17    =>mod  pro file of qelectrotech
the build system (move from qmake to cmake as Qt's internal build system) => we can still use qmake, but qmake may disappear in the future
https://wiki.qt.io/CMake_Port
and for qelectrotech:
built on Alpha fail
- KWidgetsAddons KCoreAddons: built on Alpha fail => I have temporarily deleted it on my disk for further testing
- QPrinter => I am now working on it
https://wiki.qt.io/Checklist_for_Qt_6.0_inclusion
Qt XML
Status Summary    Not Ready
Cmake port    Done
Jira backlog    N/A (assessment for Qt 6 not done yet)
Recent CI SHA    yes
gitmodules/submodule bot    N/A (qtbase)
Comments/Circumstance
Qt XML Patterns
Note, this module is deprecated in Qt 5.15 and therefore may no longer be shipped in Qt 6.
Re: Qt 6.0 development and qelectrotech
Great news Simon, I hope KF5 build again.
3 (edited by De-Backer 2020-09-22 18:11:14)
Is the have KF5 absolutely necessary?
this provides 2 function
-kbuttoncolor
-backup
if we can do this without it, it is easier for cl
GitHub wrote:
Welcome to the code scanning beta
Your account, De-Backer, is off the waitlist—you're all set to start using code scanning on public repositories!
Learn more about code scanning.
Run failed for master (08a8250)
Repository: De-Backer/qelectrotech-source-mirror
Workflow: CodeQL
Duration: 1 minute and 50.0 seconds
Finished: 2020-09-09 20:28:18 UTC
View results
Jobs:
Analyze (cpp) failed (1 annotation)
For me is a pain and a lot of complications for QET packaging and for Qt Webassembly test but is great for Joshua, it keeps him from reinventing the wheel.
a wheel like "singleapplication" would be perfect
6 (edited by De-Backer 2020-09-24 22:27:34)
a wheel for kbuttoncolor:
https://github.com/De-Backer/qt-color-p … ool-button
Todo:
KAutoSaveFile class
KDE crash of my PC, I'll be off-line for a moment nomicons/unsure ,that's just my luck.
https://teejeetech.in/timeshift/
https://www.qt.io/blog/qlist-changes-in-qt-6
11 (edited by De-Backer 2020-09-30 22:05:10)
71 Issues for built on qt6  nomicons/unsure
21:56:36.292 Info: Start-up
21:56:36.305 Info: debugging enabled: false
21:56:36.305 Info: Qt library version: 6.0.0
21:56:36.305 Info: Qt library location default prefix: "/home/simon/Qt/6.0.0/gcc_64"
21:56:36.306 Info: Qt library location documentation: "/home/simon/Qt/6.0.0/gcc_64/doc"
21:56:36.306 Info: Qt library location headers: "/home/simon/Qt/6.0.0/gcc_64/include"
21:56:36.306 Info: Qt library location libraries: "/home/simon/Qt/6.0.0/gcc_64/lib"
21:56:36.306 Info: Qt library location executables: "/home/simon/Qt/6.0.0/gcc_64/libexec"
21:56:36.306 Info: Qt library location Qt binaries: "/home/simon/Qt/6.0.0/gcc_64/bin"
21:56:36.306 Info: Qt library location Qt plugins: "/home/simon/Qt/6.0.0/gcc_64/plugins"
21:56:36.306 Info: Qt library location installed QML extensions: "/home/simon/Qt/6.0.0/gcc_64/qml"
21:56:36.306 Info: Qt library location dependent Qt data: "/home/simon/Qt/6.0.0/gcc_64"
21:56:36.306 Info: Qt library location independent Qt data: "/home/simon/Qt/6.0.0/gcc_64"
21:56:36.306 Info: Qt library location translation: "/home/simon/Qt/6.0.0/gcc_64/translations"
21:56:36.307 Info: Qt library location examples: "/home/simon/Qt/6.0.0/gcc_64/examples"
21:56:36.307 Info: Qt library location Qt testcases: "/home/simon/Qt/6.0.0/gcc_64/tests"
21:56:36.307 Info: Qt library location Qt settings: "/home/simon/Qt/6.0.0/gcc_64/etc/xdg"
21:56:36.307 Info: "GitRevision 930bb70f99d5fd160804e43aa677e72745a5f30d"
21:56:36.307 Info: "QElectroTech V 0.80-DEV"
21:56:36.307 Info: "Compilation : GCC 10.2.1 20200825 [revision c0746a1beb1ba073c7981eb09f55b3d993b32e5c]"
21:56:36.307 Info: "Built with Qt 6.0.0 - Date : Sep 30 2020 : 21:54:31"
21:56:36.307 Info: "Run with Qt 6.0.0 using 16 thread(s)"
21:56:36.307 Info: "CPU : model name\t: AMD Ryzen 7 3700X 8-Core Processor\n"
21:56:36.307 Info: "RAM Total : 32027 MB"
21:56:36.307 Info: "RAM Available : 21694 MB"
21:56:36.307 Info: "GPU : "
21:56:36.307 Info: "GPU RAM : @ToDo"
21:56:36.307 Info: "OS : linux  - x86_64 - Version : openSUSE Tumbleweed - Kernel : 5.8.10-1-default"
21:56:36.307 Info: *** Qt screens ***
21:56:36.307 Info: "( 1 : 3840 x 2160 )"
21:56:36.307 Info: "( 2 : 1920 x 1080 )"
21:56:36.624 Info: Elements collection reload
21:56:36.630 Info: Elements collection finished to be loaded
With ~ 7000 elements in official collection?
6 ms?
6 ms?
sharp eye, no, one of the Issues
6 ms?
no elements in /usr/share/
add in run works
--common-elements-dir="...../qet/elements/"
Todo:
KAutoSaveFile class
QSaveFile iso : KAutoSaveFile
https://doc.qt.io/qt-5/qsavefile.html
may i create any submodules in the project?
info submodules: https://qelectrotech.org/forum/viewtopic.php?id=1774
why:
TODO:
-remove KCoreAddons
-remove KWidgetsAddons
I would like to change this to
and QSaveFile
https://git.tuxfamily.org/qet/qet.git/c … b35acef3c3
Debian buster i386 amd64 ok
Debian Sid  i386 amd64 ok
Windows i386 amd64 ok
* Source Package: qelectrotech
* Version: 0.80.r6824-2ubuntu1
* Architecture: amd64
* Archive: ~scorpio/ubuntu/qelectrotech-dev
* Component: main
* State: Failed to build
* Duration: 9 minutes
* Build Log: https://launchpad.net/~scorpio/+archive … ING.txt.gz
* Builder: https://launchpad.net/builders/lgw01-amd64-034
* Source: not available
* Architecture: i386
* Component: main
* Builder: https://launchpad.net/builders/lgw01-amd64-032
https://git.tuxfamily.org/qet/qet.git/c … 2ad2944474
macOS ok
AppImage ok
Flatpak ok
I am of the opinion that we no longer send packages for Ubuntu Bionic (Qt 5.9), what do you think?
And support only Qt >=5.11.3
19 (edited by De-Backer 2020-10-03 20:26:00)
Right, i forgot that the min QT was 5.9, my apologies.
Version : Ubuntu 18.04 LTS
Code name : Bionic Beaver
Release : April 26, 2018
End of Standard Support : April 2023
End of Life : April 2028
does it not support QT5.11.3?
if not, I'll look for some extra code.
And for git submodules is it allowed or not?
gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/richtexteditor.o sources/richtext/richtexteditor.cpp
sources/richtext/richtexteditor.cpp:90:41: error: ‘QStringView’ does not name a type; did you mean ‘QStringRef’?
  static inline bool filterElement(const QStringView &name)
                                         QStringRef
sources/richtext/richtexteditor.cpp:97:10: error: ‘QStringView’ does not name a type; did you mean ‘QStringRef’?
    const QStringView &name,
          QStringRef
sources/richtext/richtexteditor.cpp:127:40: error: ‘QStringView’ does not name a type; did you mean ‘QStringRef’?
  static inline bool isWhiteSpace(const QStringView &in)
                                        QStringRef
sources/richtext/richtexteditor.cpp: In function ‘bool qdesigner_internal::isWhiteSpace(const int&)’:
sources/richtext/richtexteditor.cpp:129:24: error: request for member ‘size’ in ‘in’, which is of non-class type ‘const int’
   const int count = in.size();
sources/richtext/richtexteditor.cpp:131:12: error: request for member ‘at’ in ‘in’, which is of non-class type ‘const int’
    if (!in.at(i).isSpace())
sources/richtext/richtexteditor.cpp: In function ‘QString qdesigner_internal::simplifyRichTextFilter(const QString&, bool*)’:
sources/richtext/richtexteditor.cpp:153:34: error: invalid initialization of reference of type ‘const int&’ from expression of type ‘QStringRef’
     if (filterElement(reader.name())) {
sources/richtext/richtexteditor.cpp:90:21: note: in passing argument 1 of ‘bool qdesigner_internal::filterElement(const int&)’
sources/richtext/richtexteditor.cpp:154:12: error: ‘QStringView’ does not name a type; did you mean ‘QStringRef’?
      const QStringView name = reader.name();
            QStringRef
sources/richtext/richtexteditor.cpp:156:23: error: ‘name’ was not declared in this scope
      filterAttributes(name, &attributes, &paragraphAlignmentFound);
sources/richtext/richtexteditor.cpp:156:23: note: suggested alternative: ‘rename’
                       rename
sources/richtext/richtexteditor.cpp:165:34: error: invalid initialization of reference of type ‘const int&’ from expression of type ‘QStringRef’
     if (!isWhiteSpace(reader.text()))
sources/richtext/richtexteditor.cpp:127:21: note: in passing argument 1 of ‘bool qdesigner_internal::isWhiteSpace(const int&)’
and i got the reverse message in qt6..
Can they take a position in qt?  QStringView or QStringRef
https://snapcraft.io/install/qt513/kubuntu
https://snapcraft.io/qelectrotech
sudo snap install qelectrotech --edge
23 (edited by De-Backer 2020-10-03 21:51:52)
I would drop the support, Suse is also not supported (and I use it)
but we must get rid of KWidgetsAddons KCoreAddons (this makes it difficult to compile)
Yes is sometime very difficult, I don't know what changes on brew KF5 or in  https://invent.kde.org/frameworks/kcore … ts/master/ but I finished to upgrade and compile fine with Qt 5.15.1 + frameworks 5.74 on OSX .. I had to copy KF5 include and libs to Cellar/Qt .. otherwise he does not find  the #include <KAutoSaveFile> path ..
https://forum.qt.io/topic/75081/qmake-m … r-karchive
https://download.qelectrotech.org/qet/forum_img_2/osx_qt5.15.1.png
Now wait MXE python2 to python3 changes to upgrade to Qt 5.15.1 for Windows cross-compile packages, Debian removed Python2 support in unstable https://github.com/mxe/mxe/issues/2561
https://github.com/mxe/mxe/issues/2561# … -692811705
De-Backer wrote:
Todo:
KAutoSaveFile class
Use KAutoSaveFile for the backup system, instead of home made function.
https://git.tuxfamily.org/qet/qet.git/c … 20eb10303a
