Topic: erreur de frappe trouvée dans les fichiers
@Laurent (scorpio810)
../sources/ui/dynamicelementtextitemeditor.cpp
26 = #include "../ui_dynamicelementtextitemeditor.h"
_  devrait être  /
26 = #include "../ui/dynamicelementtextitemeditor.h"
../sources/ui/elementinfowidget.cpp
24  #include "../ui_elementinfowidget.h"
_ devrait être  /
24  #include "../ui/elementinfowidget.h"
I am an pre-retired industrial developer technician and born in 1960.Electrical, Electronics, Mechanical,Électricité, électronique, mécanique,Native language(Dutch)/langue maternelle/moedertaal(BE,NL).OS : Linux/GNU Debian Forky/Sid and Trixie; Qt 5 and 6; Compiler :  qmake(Qt5) qmake6(Qt6)
Re: erreur de frappe trouvée dans les fichiers
Did you read line 18 in both cpp-files?
There the headerfiles are already included.
So:
If the lines you mentioned do not cause compilation-errors, they do not need to be changed.
3 (edited by Re-searcher 2025-10-09 16:26:08)
The include ui_ files are generated files.
QET_changes-files
../ui_ TO ui
../sources/ui/
line 26 MUST BE #include "ui_dynamicelementtextitemeditor.h"
Line 24 MUST BE #include "ui_elementinfowidget.h"
imagepropertieswidget.cpp
Line 23 MUST BE #include "ui_imagepropertieswidget.h"
inditextpropertieswidget.cpp
Line 24 MUST BE #include "ui_inditextpropertieswidget.h"
linksingleelementwidget.cpp
Line 28 MUST BE #include "ui_linksingleelementwidget.h"
multipastedialog.cpp
Line 27 MUST BE #include "ui_multipastedialog.h"
potentialselectordialog.cpp
Line 28 MUST BE #include "ui_potentialselectordialog.h"
shapegraphicsitempropertieswidgetcpp
Line 24 MUST BE #include "ui_shapegraphicsitempropertieswidget.h"
4 (edited by plc-user 2025-10-12 11:26:29)
The project compiles here without any warnings or errors regarding these lines the way they are now!
If there would be a general problem with these lines, more users would have reported...
What is your build-environment?
What versions do you use? (OS, Qt, Compiler, etc)
How do you compile?
What error-messages do you get, when not changing these lines?
Edit:
You have not yet given any reason why these lines should be changed.
I also found this
J'ai également trouvé ceci
../sources/colorbutton.cpp: In member function ‘void ColorButton::clicked(bool)’:
../sources/colorbutton.cpp:56:32: warning: unused parameter ‘checked’ [-Wunused-parameter]
   56 | void ColorButton::clicked(bool checked)
../sources/colorcombobox.cpp: In member function ‘virtual void ColorComboBox::paintEvent(QPaintEvent*)’:
../sources/colorcombobox.cpp:80:45: warning: unused parameter ‘e’ [-Wunused-parameter]
   80 | void ColorComboBox::paintEvent(QPaintEvent *e) {
../sources/editor/UndoCommand/openelmtcommand.cpp: In member function ‘virtual void OpenElmtCommand::redo()’:
../sources/editor/UndoCommand/openelmtcommand.cpp:66:102: note: ‘#pragma message: @TODO uncommante slot_select when fixed, see itemChange function for each primitive’
   66 | #pragma message("@TODO uncommante slot_select when fixed, see itemChange function for each primitive")
@Re-searcher:
And I found, that you do not answer questions and do not explain what you want to say with your posts.
This way, you are just wasting the time of people who read your posts.
Just barking around does not help at all!
7 (edited by Re-searcher 2025-10-15 08:05:00)
Use qmake6 in console
g++ -c -pipe -std=c++17 -Wall -g -std=gnu++1z -Wall -Wextra -D_REENTRANT -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_ALLOW_OVERRIDE_DD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DGIT_COMMIT_SHA=\"411fb3c4dc54b6aaea00f034d6c5396de5daa474\" -DQET_LANG_PATH=/home/me/1QET093ec56/build/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/home/me/1QET093ec56/build/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/home/me/1QET093ec56/build/share/qelectrotech/titleblocks/ -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I../../1QET093ec56 -I. -I../SingleApplication -I../sources/ui -I../sources/TerminalStrip/ui -I/usr/include/x86_64-linux-gnu/qt6 -I/usr/include/x86_64-linux-gnu/qt6/QtSvg -I/usr/include/x86_64-linux-gnu/qt6/QtPrintSupport -I/usr/include/KF6/KWidgetsAddons -I/usr/include/x86_64-linux-gnu/qt6/QtWidgets -I/usr/include/x86_64-linux-gnu/qt6/QtGui -I/usr/include/x86_64-linux-gnu/qt6/QtNetwork -I/usr/include/x86_64-linux-gnu/qt6/QtXml -I/usr/include/x86_64-linux-gnu/qt6/QtSql -I/usr/include/x86_64-linux-gnu/qt6/QtConcurrent -I/usr/include/KF6/KCoreAddons -I/usr/include/x86_64-linux-gnu/qt6/QtCore -I. -I. -I/usr/lib/x86_64-linux-gnu/qt6/mkspecs/linux-g++ -o dynamicelementtextitemeditor.o ../sources/ui/dynamicelementtextitemeditor.cpp
../sources/ui/dynamicelementtextitemeditor.cpp:26:10: fatal error: ../ui_dynamicelementtextitemeditor.h: No such file or directory
   26 | #include "../ui_dynamicelementtextitemeditor.h"
compilation terminated.
make: *** [Makefile:6893: dynamicelementtextitemeditor.o] Error 1
make: *** Waiting for unfinished jobs....
I can only repeat myself:
Compiled Qt6-branch of QET with the latest Debian unstable and Qt6.
You seem to be doing something different from everyone else:
You are the first and so far the only one to report these effects...
I'm in the process of adjusting the configuration. CONFIG and QMAKE_CXXFLAGS are changed.
Je suis en train d'ajuster la configuration. CONFIG et QMAKE_CXXFLAGS sont modifiés.
CONFIG += qt c++17 debug warn_on link_pkgconfig
QMAKE_CXXFLAGS += -std=c++17 -Wall
EN
https://gcc.gnu.org/onlinedocs/gcc/
https://gcc.gnu.org/onlinedocs/gcc/Option-Summary.html
https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html
Anyone playing around with compiler flags should know:
- what he is doing
- that it can go wrong!
Or rather: It will go wrong!
Comme vous ne me croyez pas, regardez ceci.
../sources/ui/alignmenttextdialog.cpp
Vous verrez alors que j'ai raison.
Vous devez supprimer ../ avant ui_
If you don't believe me, take a look here.
You'll see that I'm right.
You need to remove ../ before ui_
Différence entre #include ui_file
Difference between #include ui_file
#include "alignmenttextdialog.h"
#include "../qetgraphicsitem/dynamicelementtextitem.h"
#include "ui_alignmenttextdialog.h"
#include "dynamicelementtextitemeditor.h"
#include "../diagram.h"
#include "../elementtextpattern.h"
#include "../qetgraphicsitem/elementtextitemgroup.h"
#include "../undocommand/addelementtextcommand.h"
#include "../undocommand/deleteqgraphicsitemcommand.h"
#include "dynamicelementtextmodel.h"
#include <QTreeView>
#include <QUndoCommand>
