Topic: erreur de frappe trouvée dans les fichiers
@Laurent (scorpio810)
../sources/ui/dynamicelementtextitemeditor.cpp
26 = #include "../ui_dynamicelementtextitemeditor.h"
_  devrait être  /
26 = #include "../ui/dynamicelementtextitemeditor.h"
../sources/ui/elementinfowidget.cpp
24  #include "../ui_elementinfowidget.h"
_ devrait être  /
24  #include "../ui/elementinfowidget.h"
I am an pre-retired industrial developer technician and born in 1960.Electrical, Electronics, Mechanical,Électricité, électronique, mécanique,Native language(Dutch)/langue maternelle/moedertaal(BE,NL).
Re: erreur de frappe trouvée dans les fichiers
Did you read line 18 in both cpp-files?
There the headerfiles are already included.
So:
If the lines you mentioned do not cause compilation-errors, they do not need to be changed.
3 (edited by Re-searcher 2025-10-09 16:26:08)
The include ui_ files are generated files.
QET_changes-files
../ui_ TO ui
../sources/ui/
line 26 MUST BE #include "ui_dynamicelementtextitemeditor.h"
Line 24 MUST BE #include "ui_elementinfowidget.h"
imagepropertieswidget.cpp
Line 23 MUST BE #include "ui_imagepropertieswidget.h"
inditextpropertieswidget.cpp
Line 24 MUST BE #include "ui_inditextpropertieswidget.h"
linksingleelementwidget.cpp
Line 28 MUST BE #include "ui_linksingleelementwidget.h"
multipastedialog.cpp
Line 27 MUST BE #include "ui_multipastedialog.h"
potentialselectordialog.cpp
Line 28 MUST BE #include "ui_potentialselectordialog.h"
shapegraphicsitempropertieswidgetcpp
Line 24 MUST BE #include "ui_shapegraphicsitempropertieswidget.h"
The project compiles here without any warnings or errors regarding these lines the way they are now!
If there would be a general problem with these lines, more users would have reported...
What is your build-environment?
What versions do you use? (OS, Qt, Compiler, etc)
How do you compile?
What error-messages do you get, when not changing these lines?
