Topic: erreur de frappe trouvée dans les fichiers
@Laurent (scorpio810)
../sources/ui/dynamicelementtextitemeditor.cpp
26 = #include "../ui_dynamicelementtextitemeditor.h"
_  devrait être  /
26 = #include "../ui/dynamicelementtextitemeditor.h"
../sources/ui/elementinfowidget.cpp
24  #include "../ui_elementinfowidget.h"
_ devrait être  /
24  #include "../ui/elementinfowidget.h"
I am an pre-retired industrial developer technician and born in 1960.Electrical, Electronics, Mechanical,Électricité, électronique, mécanique,Native language(Dutch)/langue maternelle/moedertaal(BE,NL).
Re: erreur de frappe trouvée dans les fichiers
Did you read line 18 in both cpp-files?
There the headerfiles are already included.
So:
If the lines you mentioned do not cause compilation-errors, they do not need to be changed.
It is OK now
The include ui_ files are generated files.
