1 (edited by fdomateu 2020-03-22 00:42:49)
Topic: Documentation QElectroTech 0.7
Hello,
The documentation from QElectroTech 0.7 has been updated at github. The modifications are:
  • Documentation re-structured to minimize the size using common figures.
  • Official icons added in the images.
  • Documentation ready for internationalization, file structure and new filename definition (figure_languge_filename = "{path}{language}/{basename}{ext}") for the automatic selection of figures depending on the language.
  • New theme used (sphinxbootstrap4theme).
  • Forum and Home page links added to the documentation menu.
  • Some grammatical corrections.
  • Some new information added
  • pdf version created and download link added to index page.
Re: Documentation QElectroTech 0.7
Hi Fernando,
good work, thanks.
The Online documentation from QElectroTech 0.7 has been synced.
Thanks a lot for this good work.
Great, many thanks nomicons/smile
fdomateu wrote:
Hello.
The translation is working according to the lazy text from python. On
github you will find the basic chapter in spanish as an example at the
locale/es/LC_MESSAGES folder. You should copy the project source folder and
follow the steps from *sphinx-intl*. The instructions can be found at the
link  copied below and the *conf.py* file of the project is already
prepared for that.
https://www.sphinx-doc.org/en/master/us … d/intl.htm
To also get the images in the final language, you should create the images
from the folder images/en/ in the desired language, if the images from the
english version are not created they will not be shown in the final
documentation. You will also find some examples in Spanish.
At the end of your job, we would appreciate that the final source code from
your folder locale/*xx*/LC_MESSAGES and the image folder are added to the
source repository of the project. These are the folders that the
QElectroTech team has to receive to include in the official github
repository.
Best regards
6
Hello,
The documentation master branch has been prepared for the version 0.8, the changes already made have been indicated at ChangeLof file from the source directory. The html files from the build directory have also been updated.
The added information has been taken from the ChangeLog of QElectroTech source mirror
I would appreciate any comment to focus the time on the issues you consider more important/interesting.
Note: The pdf manual version has also been updated for downloading
7
Great, Thanks Fernando
I synced new changes:
rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress /media/backup6/download/qelectrotech-doc/build/  johndoe@ssh.tuxfamily.org:/home/qet/qet-repository/manual_0.7/build/
8
Is it not better to keep the version 0.7 at directory 0.7 and add a new directory named manual_0.8? or, an idea that i like more, publish two different versions of documentation:
- Latest release (currently 0.7)
- Develop version (currently 0.8)
The 0.7 version can be found at branch 0.7.1 from github and the master branch is the latest (develop version).
Additionally, i would like to inform that the build files from tuxfamily are actually mixed. You can find some html from QElectroTech 0.8 documentation and some  of them from QElectroTech 0.7 documentation
9
F5 for refresh.
If I change directory to  manual_0.8 I need to change URL in QET code, but user use old version don't see new manual.
10
It will push them to switch to the new version. :p
11
Thanks for the F5 input.
Nevertheless, some images have not been uploaded from github. For example, downloading the github master banch as zip, I see all images from type of elements sub-files. At the tuxfamily source I am not getting the files in the documents. At preferences chapter I also see the same issue
I do not know if there is any problem during syncronization or at the server, downloading as zip from github all is inside and working
12
Images is on build folder, yes?
And yes I use git pull and after rsync
I try with Github tarball.
13
F5, I synced with Github tarball.
Thanks for the tip to tarball.
14
fdomateu wrote:
Hello.
prepared for that.
repository.
Best regards
You could add Spanish index.html link in main page?
15
Perfect,
Now the documentation is updated.
I have seen that at the end you have updated to manual link text from the forum to the documentation, perfect detail
16
I also replaced Arun old documentation 0.4 in main page site by new 0.8 version of manual.
17
Maybe to be added in documentation
https://qelectrotech.org/forum/viewtopi … 5584#p5584
18
Added CS translation :
19
Il  n'y a pas de documentation en francais?
20
Non, pas pour l'instant.
https://github.com/qelectrotech/qelectr … rce/locale
https://www.sphinx-doc.org/en/master/us … /intl.html
21
German 0.8 documentation pdf, thanks klaus10klaus.
https://download.qelectrotech.org/qet/m … 08deut.pdf
22
Hello,
How has the pdf in german been done? I have tried to built the CS documentation in pdf, currently we only have it in html, and I have still not been able.
I have problems with the rst2pdf package to choose a language different to the default english.
23
Hello,
see this german topic:
https://qelectrotech.org/forum/viewtopic.php?id=2044
24
fdomateu wrote:
For translating the documentation to Portuguese, the documentation has been
created with Sphinx from the beginning. you will find the source
documentation from python and reStructuredText in the following directory:
https://github.com/qelectrotech/qelectr … ter/source
The different languages are managed using the .po files. you can find them
for each current language available language in the following directory:
For the moment you can find the finished the Czech translation finished and
the Spanish started. I would recommend you to download the Czech folder
(cs) and modify on each po file all msgstr arguments from Czech to
Portuguese. The inglish text you will find above, at the argument msgid
Best Regards
Fernando
25
Online manual translation tip:
https://qelectrotech.org/forum/viewtopi … 244#p16244
Edit: here are some online translations of the manual in PDF:
https://download.qelectrotech.org/qet/m … ation_pdf/
