1 (edited by scorpio810 2023-11-07 12:49:37)
Topic: Use QT Creator to build qelecotech source code under windows
hello,
I downloaded the source code of qelectroTech0.9 version from the official website
and used QT Creator5.15.2 to open the qelectrotech.pro file for compilation when this problem occurred:
:-1: error: Project ERROR: sqlite3 development package not found.
According to the instructions in the forum <Building QET from source - sqlite3 development package not found>, compile the path of sqlite3 and add it to the directory of the pro file,
and then add the path to the pro file. The test still lacks sqlite3.
so I define it by : #DEFINES += QET_EXPORT_PROJECT_DB, and ,#unix|win32: PKGCONFIG += sqlite3.
Then this happens again when you rebuild: :-1: error: Project ERROR: Unknown module(s) in QT: KWidgetsAddons KCoreAddons.
i found another article on the forum <How can i build in Windows QTcreator: KwidgetAddons KcoreAddons> post, because I am a new graduate, the windows compilation is not familiar, according to the above instructions I have been unable to compile, may I ask how can I build KWidgetsAddons KCoreAddons in QT? Or is there a more detailed way?
Re: Use QT Creator to build qelecotech source code under windows
https://qelectrotech.org/forum/viewtopi … 999#p12999
https://qelectrotech.org/wiki_new/doc/qt_pour_windows
3 (edited by 云中君 2023-11-07 11:15:00)
@scorpio810:
It is my great honor to receive your reply.
I followed the link instructions you sent to operate step by step. But, this problem occurred every time, and I did not know what was wrong. Could you please tell me in detail?
Error message:
D:\QET_Chinese\kcoreaddons-master\build>cmake .. -DCMAKE_INSTALL_PREFIX=%QTPATH% -DCMAKE_PREFIX_PATH=$QTPATH -G "MinGW Makefiles" -DZLIB_LIBRARY:FILEPATH=D:\QT\Tools\Tools\mingw730_64\x86_64-w64-mingw32\lib\libz.a
-- The C compiler identification is GNU 7.3.0
-- The CXX compiler identification is GNU 7.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: D:/QT/Tools/Tools/mingw730_64/bin/gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: D:/QT/Tools/Tools/mingw730_64/bin/c++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at D:/CMake/share/ECM/modules/ECMQueryQt.cmake:84 (message):
  No executable found.  Can't check QT_INSTALL_PREFIX as required
Call Stack (most recent call first):
  D:/CMake/share/ECM/kde-modules/KDEInstallDirs6.cmake:199 (ecm_query_qt)
  D:/CMake/share/ECM/kde-modules/KDEInstallDirs.cmake:15 (include)
  CMakeLists.txt:14 (include)
-- Configuring incomplete, errors occurred!
See also "D:/QET_Chinese/kcoreaddons-master/build/CMakeFiles/CMakeOutput.log".
maybe you forgot to enter in your terminal before this command:
SET QTPATH=C:\Qt\5.12.4\mingw73_64
But I saw you have Qt5 installed  on D:/QT ?? maybe correct your SET with good path and correct the Qt version and also minGW version?
SET QTPATH=D:\QT\5.12.4\mingw73_64
It's more easy to compile on Linux, like Ubuntu/Debian if you know?
6 (edited by 云中君 2023-11-07 12:33:43)
hello,
After I corrected the Qt and minGW versions according to the instructions,
after I changed QTPATH in the environment variables, the 5.12.4 folder was automatically generated in my Qt installation directory.But,the above question still arises.
I'm not familiar with LInux and I think the probability of error is probably a little higher.
Hmm try:
cmake .. -DCMAKE_INSTALL_PREFIX=%QTPATH% -DCMAKE_PREFIX_PATH=$QTPATH -G "MinGW Makefiles" -DZLIB_LIBRARY:FILEPATH=D:\QT\Tools\mingw730_64\x86_64-w64-mingw32\libz.a
A question: why do you want to compile yourself QElectroTech, we offert a lot of packages here?
9 (edited by 云中君 2023-11-08 09:26:57)
The reason why the source code is compiled,because I added some pictures and colors to the source code according to the work requirements.But,After modifying the code the QT compiler keeps telling me it's missing Project ERROR: Unknown module (s) in QT: KWidgetsAddons KCoreAddons.
rename D:\QT\5.12.4\mingw73_32\lib\libKF5CoreAddons.dll.a to libKF5CoreAddons.a
rename D:\QT\5.12.4\mingw73_32\lib\libKF5WidgetsAddons.dll.a to libKF5WidgetsAddons.a
TRY to copy your  KWidgetsAddons KCoreAddons. mkspecs/modules/*.pri  to D:\QT\5.15.2\mingw73_32\mkspecs\modules\
After in D:\QT\5.15.2\mingw73_32\mkspecs \modules\
edit  KWidgetsAddons KCoreAddons pri files like :
https://invent.kde.org/sdk/kdesrc-build … note_53888
Replace "$$PWD/../../" by real PATH in KWidgetsAddons KCoreAddons pri
See my example on OSX,
https://qelectrotech.org/wiki_new/doc/macosx
12 (edited by 云中君 2023-11-08 11:30:34)
Sorry to disturb you.
I installed QT according to the instructions you gave.But,me didn't find it in my installed QT directory:libKF5CoreAddons.dll.a,
KWidgetsAddons KCoreAddons. mkspecs/modules/*.pri..I haven't been able to locate it.Can you please tell us more about it?
====== Installing development tools for Microsoft Windows======
===== Install Qt: =====
Follow the instructions in this https://guillaumebelz.github.io/qtinstall in order to correctly install Qt
Create the QTPATH environment variable. For that :
Go to the Windows control panel, in the search bar type 'environment variable', in the result go to 'Modify system environment variables', in the dialog click on 'Environment variable' in the new dialog in 'system variable' click on 'new'.
Variable name:
QTPATH
value of the variable:
C:\Qt\5.15.0\mingw81_64
The path will need to be adapted according to your case.
Add minGW to the PATH environment variable, to do this:
Go to the Windows control panel, in the search bar type 'environment variable', in the result go to 'Modify system environment variables', in the dialog click on 'Environment variable' in the new dialog in 'system variable' select the 'Path' line then click on modify. In the 'Variable value' field add at the end
;C:\Qt\Tools\mingw810_64\bin\
the path will have to be adapted according to your case.
===== Installing cmake =====
Download the installer from the https://cmake.org/install/
During installation if you are asked to add cmake to the PATH do so (for all users) otherwise you will have to manually add the cmake bin folder to the PATH, see the procedure above. The path will be something like ''C:\Program Files\CMake\bin''.
===== ECM =====
The procedure used comes from this https://qelectrotech.org/forum/viewtopi … 120#p10120
Download https://github.com/KDE/extra-cmake-modules then unzip it to the folder of your choice.
In a command guest:
cd (path of ecm)
cmake -DCMAKE_INSTALL_PREFIX=%QTPATH% -G "MinGW Makefiles"
mingw32-make install
Compile KwidgetAddons and KcoreAddons (libraries used by QElectroTech)
The procedure used comes from this forum post and this one.
KCoreAddons
https://github.com/KDE/kcoreaddons
Download KCoreAddons and unzip it to the folder of your choice. In a command guest:
cd (path of kcoreaddons)
mkdir build
cd build
cmake .. -DCMAKE_INSTALL_PREFIX=%QTPATH% -DCMAKE_PREFIX_PATH=$QTPATH -G "MinGW Makefiles" -DZLIB_LIBRARY:FILEPATH=C:\Qt\Tools\mingw810_64\x86_64-w64-mingw32\lib\libz.a
mingw32-make
the path C:\Qt\Tools\mingw810_64\x86_64-w64-mingw32\lib\libz.a must be adapted according to your case.
Rename C:\Qt\5.15.0\mingw81_64\lib\libKF5CoreAddons.dll.a to libKF5CoreAddons.a (Path to adapt according to your case).
KWidgetAddons
https://github.com/KDE/kwidgetsaddons
Download KWidgetAddons and unzip it to the folder of your choice. In a command guest:
cd (kwidgetsaddons path)
mkdir build
cd build
mingw32-make
Rename C:\Qt\5.15.0\mingw81_64\lib\libKF5WidgetsAddons.dll.a to libKF5WidgetsAddons.a (Path to adapt according to your case).
Retrieve QElectrotech sources with git
Install git for windows.
Download the code from the github repository https://github.com/qelectrotech/qelectr … rce-mirror
git clone https://github.com/qelectrotech/qelectrotech-source-mirror.git
cd qelectrotech-source-mirror.git
git submodule update --init --recursive
mkdir build
cd build
qmake ..\qelectrotech.pro
make -j8
I had this problem when compiling KCoreAddons:
-- The C compiler identification is GNU 8.1.0
-- The CXX compiler identification is GNU 8.1.0
-- Check for working C compiler: C:/Qt/Tools/mingw810_64/bin/gcc.exe - skipped
-- Check for working CXX compiler: C:/Qt/Tools/mingw810_64/bin/g++.exe - skipped
CMake Error at C:/Qt/5.15.2/mingw81_64/share/ECM/modules/ECMQueryQt.cmake:84 (message):
  C:/Qt/5.15.2/mingw81_64/share/ECM/kde-modules/KDEInstallDirs6.cmake:199 (ecm_query_qt)
  C:/Qt/5.15.2/mingw81_64/share/ECM/kde-modules/KDEInstallDirs.cmake:15 (include)
Maybe send D:/QET_Chinese/kcoreaddons-master/build/CMakeFiles/CMakeOutput.log".
Do you mean that I send you the contents of the CMakeOutput.log file?
https://api.kde.org/ecm/module/ECMQueryQt.html
https://github.com/KDE/extra-cmake-modu … .cmake#L30
include(ECMQueryQt)
ecm_query_qt(bin_dir QT_INSTALL_BINS)
These two lines of code are at the beginning of the CMakeList.txt file in the kcoreaddons-master directory.This error occurs:
CMake Error at CMakeLists.txt:1 (include):
  include could not find load file:
    ECMQueryQt
CMake Error at CMakeLists.txt:2 (ecm_query_qt):
  Unknown CMake command "ecm_query_qt".
Hum, I think you do download KF5 branch for all, not master branch, I think master it is for Qt 6 version..
KF5 version to 5.112.0.
https://invent.kde.org/frameworks/extra … type=heads
https://invent.kde.org/frameworks/kcore … type=heads
https://invent.kde.org/frameworks/kwidg … type=heads
It would be an honor for me to be able to help everyone.
However, according to your instructions, when compiling Qelecotech, because my source code is directly downloaded from github and modified, I skipped the git clone in your instructions https://github.com/qelectrotech/qelectr … or.git,git submodule update --init -- recursive
mkdir build. Go directly to the directory where qelectrotech is located and start the following steps:mkdir build,cd build.But,When I'm doing this step: qmake.. qelectrotech.pro, I get this error: 'qmake' is not an internal or external command, nor is it a runnable program
or batch files.
I remember on Windows in list program Qt you have a terminal based on minGW, maybe try it..
Maybe
Edit the PATH where find qmake lile this:
\Qt\5.15.0\mingw81_64\bin\qmake ..\qelectrotech.pro
Or use this command with the right path in your terminal before using qmake command..
SET QTPATH=C:\Qt\5.12.4\mingw73_32
hello,
I use it in the terminal:C:\Qt\5.15.2\mingw81_64\bin\qmake ..\qelectrotech.pro.This error occurred:Info: creating stash file D:\QET_Chinese\qelectrotech\build\.qmake.stash.
I think the reason for this error is that I made changes to the source code,And then,I take it from what you gave above [https://github.com/qelectrotech/qelectr … rce-mirror]
Downloaded a source code,Manually unzip it to a folder,Start the following command:
cd D:\QET_Chinese\qelectrotech;mkdir build;cd build;C:\Qt\5.15.2\mingw81_64\bin\qmake ..\qelectrotech.pro;
This error occurred:Info: creating stash file D:\QET_Chinese\qelectrotech-source-mirror-master\build\.qmake.stash
Cannot read D:/QET_Chinese/qelectrotech-source-mirror-master/SingleApplication/singleapplication.pri:
No such file or directory.
Could you tell me the detailed solution?
If you download zip source code you don't have sub-modules, also please git to clone the repository.
https://www.reddit.com/r/github/comment … of_master/
https://github.com/dear-github/dear-github/issues/214
git clone --recursive https://github.com/qelectrotech/qelectrotech-source-mirror.git
https://gitforwindows.org/
Git BASH
Git for Windows provides a BASH emulation used to run Git from the command line. *NIX users should feel right at home, as the BASH emulation behaves just like the "git" command in LINUX and UNIX environments.
