Re: add documentation of functions patch files
yes
QElectroTech → Code → add documentation of functions patch files
yes
I sent my old Ryzen 1700X platform to Joshua.
/usr/bin/inxi -v2
System: Host: debian Kernel: 5.7.9-vanilla x86_64 bits: 64 Desktop: KDE Plasma 5.17.5 Distro: Debian GNU/Linux bullseye/sid
Machine: Type: Desktop System: Micro-Star product: MS-7C60 v: 1.0 serial: <superuser/root required>
Mobo: Micro-Star model: TRX40 PRO 10G (MS-7C60) v: 1.0 serial: <superuser/root required>
UEFI: American Megatrends LLC. v: 1.60 date: 05/13/2020
CPU: 24-Core (3-Die): AMD Ryzen Threadripper 3960X type: MT MCP MCM speed: 2199 MHz min/max: 2200/3800 MHz
Graphics: Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: fbdev,modesetting,vesa resolution:
1: 3840x2160~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: Radeon RX550/550 Series (POLARIS12 DRM 3.37.0 5.7.9-vanilla LLVM 10.0.0) v: 4.6 Mesa 20.1.2
Network: Device-1: Intel I211 Gigabit Network driver: igb
Device-2: Intel I211 Gigabit Network driver: igb
Drives: Local Storage: total: 2.96 TiB used: 1.28 TiB (43.1%)
Info: Processes: 571 Uptime: 1h 15m Memory: 62.76 GiB used: 8.34 GiB (13.3%) Shell: Bash inxi: 3.1.04
System: Host: linux-hxu6 Kernel: 5.7.5-1-default x86_64 bits: 64 Desktop: KDE Plasma 5.19.2
Distro: openSUSE Tumbleweed 20200701
Machine: Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4 serial: <superuser/root required>
UEFI [Legacy]: American Megatrends v: P2.20 date: 11/25/2019
CPU: 8-Core: AMD Ryzen 7 3700X type: MT MCP speed: 1911 MHz min/max: 2200/3600 MHz
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu
v: kernel
Display: x11 server: X.org 1.20.8 driver: amdgpu FAILED: ati
unloaded: fbdev,modesetting,radeon,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.37.0 5.7.5-1-default LLVM 10.0.0) v: 4.6 Mesa 20.1.2
Drives: Local Storage: total: 12.28 TiB used: 5.95 TiB (48.5%)
Info: Processes: 412 Uptime: N/A Memory: 31.28 GiB used: 8.25 GiB (26.4%) Shell: bash inxi: 3.1.00 3 a 6 months old
Good config, but very limited for me when I compile many framework, libs, compiler in a cross environment, I now save several hours of compile.
Building Debian stable, Unstable i386, amd64, macOS, AppImage, Flatpak, and Windows package is take only ~30 minutes for make and upload all. And PPA..
now I save several €€, your setup is too expensive for me. my sister does rendering with amd Ryzen 9 3900x.
The community helped me with their donations to buy this configuration, like old setup sent to Joshua.
https://qelectrotech.org/forum/viewtopi … 136#p11136
https://qelectrotech.org/forum/viewtopi … 6404#p6404
Building Flatpak, and Windows package
Windows Flatpak == chocolatey
Some of the common challenges include:
TIME: Manual approach to software deployment is time consuming & inefficient
COMPLEXITY: Traditional tools are complex & ineffective in today's IT environment
COST: Deploying & managing Windows software without standard package management results in additional overheads
I'm confirm.
yes I have already read that, I can help you with code but money is difficult.
For now, no need money, and we appreciate a lot your help, thank you again.
you remember this post?
Certainly there is a problem with my gitlab account. All my repositories are public, but there is one of them which doesn't allow the access, except to me of course. I don't understand it.
My apologies. I'll solve it and thank you for the advertisement.What am I imaging?
I'm writing a FreeCAD module or Workbench in order to draw buildings description which could be exported to OpenStudio, initially using the swig python bindings of OpenStudio and recently with direct connection in c++.
I've half done the constructive side, building, buildingstory or floors, spaces, surfaces, subsurfaces, shadows, etc. And fine.But now I'm starting to do HVAC side, nodes and components, which is more complicated. And I'm feeling that a program like QElectroTech could be the correct election to draw some circuits, one additional qt editor for OpenStudio object properties, and finally an exporter to OpenStudio format.
I don't know if the explained is too much imagine, but the next months I would like to study this option.
Thank you
I know chocolatey from FreeCad.
If you know some guys which can help to package it, I'm very interested.
Like automated nightly package Snap build on Travis.
https://qelectrotech.org/forum/viewtopi … 9960#p9960
I saw QBS and Github actions, kde Craft, but difficult to learn it and need more time.
well I had been looking for a few weeks, and only then started to inform you when I had all the information. I am still too early to present chocolatey.
The patch for the Doxyfile to make it more available to everyone. The disadvantage is that "doxygen Doxyfile" must be executed in the qet dir.
Is not a problem, merged, thanks.
maybe something like gitlab pipelines
If you want to rejoin the team and upload yourself your commit, you 're welcome.
https://qelectrotech.org/wiki_new/doc/rejoin_project
I would like to, but Tuxfamily asks for my Address.
And no website can be 100% sure against cracking.
I don't want to get pising in my letterbox.
With my AMD Ryzen Threadripper 3960X setup building MXE cross-compile Qt 5 env with Digikam scripts take ~ 38mn + ~ 15mn for compile KF5 Framework libs by environment, in the past it take 8 hours by environment..
I only do this when a new version of Qt shows up.
https://invent.kde.org/graphics/digikam … undles/mxe
eg:
https://gitlab.com/JaMeZ-B/cv/-/pipelines
you can open your pc yourself for gitlab so that gitlab compiles the code on your pc autom.
It should be better when I have the fiber, I will no longer need to go through the 4G of my smartphone for upload packages. ADSL upload is very bad..in 2020...
I knew the Tandy TRS80 (basic color) with backup on magnetic tape in the 80's MS Dos and 33k modem.. it doesn't rejuvenate me..
You live in Belgium.
They have been talking about that in Belgium for years, but it is not going to happen.
No, in France.
That won't matter if doel (nuclear power plant of Belgium) explodes.
now i'm joking.
test for doc:
@@ -51,16 +51,15 @@ BorderProperties::BorderProperties() :
BorderProperties::~BorderProperties() {
@brief BorderProperties::operator ==
- @param bp :
- - other BorderProperties container/class
- - autre conteneur BorderProperties
- @return
- - true if it and this container are identical, false otherwise
- - true si ip et ce conteneur sont identiques, false sinon
+ \~ @param bp : Other BorderProperties container/class.
+ \~French Autre conteneur BorderProperties
+ \~ @return True if it and this container are identical, false otherwise.
+ \~French True si ip et ce conteneur sont identiques, false sinon
bool BorderProperties::operator==(const BorderProperties &bp) {
return(
bp.columns_count == columns_count &&\
bp.columns_width == columns_width &&\
it's working.
Great!
Generated in 0.025 seconds (48% PHP - 52% DB) with 10 queries
