Re: snap package
Off course like my AppImage the snap package can't launch qet_tb_generator or DXFtoelmt plug-in.
27
Re: snap package
We can fix all that and include those in the snap. Let's track all snap related deficiencies @ https://github.com/ppd1990/qelectrotech-snap/issues
Re: snap package
A possible solution is perhaps packaging a snap python qet_tb_generator, and for DXFtoelmt a Qt 5 program users put binary into snap env?
Re: snap package
Strange file exists.
ls -al /usr/share/libdrm/amdgpu.ids
-rw-r--r-- 1 root root 6682 janv. 22 17:32 /usr/share/libdrm/amdgpu.ids
30
Re: snap package
It is possible to package them separately and then join them via the content interface.
But far simpler is this solution: Just ship everything in the qelectrotech snap itself. That's really easy to do with snapcraft.
What do you think?
31
Re: snap package
The snaps run strictly confined, so it does not see that file unless we include it. I'm preparing an update for the snap as we speak to test a fix.
32
Re: snap package
Laurent,
do you know where to find the source/repo of qet_tb_generator? Or does only the pypi package exist?
Re: snap package
What do you think?
For for far simpler QET search qet_tb_generator installed on the system, and for DXFtoelmt converter is search on Linux QDir::homePath() + "/.qet/DXFtoQET"
Re: snap package
https://pypi.org/project/qet-tb-generator/
https://download.qelectrotech.org/qet/b … f_to_elmt/
These two plug-ins are autonomous and can work without QET, but users liked to launch with QET program. nomicons/smile
35
Re: snap package
I don't think we will be able to access the system's python packages. It must be installed into the snap itself or be exposed with another snap.
Re: snap package
I have make a Debian package on this qet_tb_generator if you want?
You can find it on my PPA's or my Debian Repository.
37 (edited by ppd 2019-06-21 23:59:55)
Re: snap package
Thank you, I think I can do it via pip and a bit of hackery.
The QElectroTech project & friends are quite oldschool regarding the source distribution for my juvenile taste, that's all nomicons/laughing
I think it's a good idea to host as much stuff as accessible as possible. Maybe putting qet-tb-generator on Github isn't too bad of an idea.
Re: snap package
We use Tuxfamily.org hosting and services, and I love it.  nomicons/cool
https://faq.tuxfamily.org/Services/En
Joining us is not that complicated, except maybe for Windows users but WSL2 is coming .. on Win10.. https://devblogs.microsoft.com/commandl … ing-wsl-2/
https://qelectrotech.org/wiki_new/doc/rejoin_project
Re: snap package
ppd wrote:
strange. Maybe a temporary problem, given that you have a working internet connection.
Can you give me the output of
snap version
Bust most likely it is/was a temporary problem on the store side
Cheers
Max
Hello Max
I am in another PC, but with similar problems:
juliomarin@Julio-Studio:~$ snap version
snap    2.38
snapd   2.38
series  16
ubuntu  16.04
kernel  4.4.0-150-generic
juliomarin@Julio-Studio:~$ sudo snap install qelectrotech --edge
error: cannot install "qelectrotech": Post
       https://api.snapcraft.io/v2/snaps/refresh: proxyconnect tcp: tls:
       oversized record received with length 20527
40 (edited by ppd 2019-06-22 00:27:28)
Re: snap package
I bet you have incorrectly set a https_proxy. Can you show me
echo $https_proxy
and
cat /etc/environment
and
cat
/etc/systemd/system/snapd.service.d/proxy.conf
Or just in general:
env|grep http
I suspect you have set https_proxy=https://something when it should be https_proxy=http://something
Re: snap package
Julio could try this command :
traceroute api.snapcraft.io
42
Re: snap package
No worries, I haven't worked with Windows in about 15 years. That's not the issue.
I just think qet_tb_generator should have a repository so it can be properly cloned. That may be on tuxfamily for all I care.
Re: snap package
  Why not, will surely be easier to find for new users, QET guys can find information by Unalcade here  : https://qelectrotech.org/forum/viewforum.php?id=16
44
Re: snap package
Also for packaging (as in this case) and for development. I would hardly consider sending a patch or pull request for something that only exists visibly on the pypi registry.
For the moment I'll just include the source you attached in the packaging repo.
Re: snap package
You could see the history of this plug-in here :
https://qelectrotech.org/forum/viewtopic.php?id=902
https://qelectrotech.org/forum/viewtopic.php?id=1007
46
Re: snap package
Great stuff. I'll push an updated version tomorrow/later and I hope you'll give it a thorough review.
Re: snap package
Nice, thanks Max.
Re: snap package
echo $https_proxy
and
and
cat
Or just in general:
env|grep http
juliomarin@Julio-Studio:~/Proyectos/QET/docs/source$ echo $https_proxy
https://myproxy:3128/
juliomarin@Julio-Studio:~/Proyectos/QET/docs/source$ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
http_proxy="http://myproxy:3128/"
https_proxy="https://myproxy:3128/"
ftp_proxy="ftp://myproxy:3128/"
socks_proxy="socks://myproxy:3128/"
juliomarin@Julio-Studio:~/Proyectos/QET/docs/source$ env|grep http
http_proxy=http://myproxy:3128/
KIGITHUB=https://github.com/KiCad
https_proxy=https://myproxy:3128/
Note I am before a proxy, and I change the real dir of the proxy  to "myproxy"
Re: snap package
juliomarin@Julio-Studio:~/Proyectos/QET/docs/source$ traceroute api.snapcraft.io
traceroute to api.snapcraft.io (91.189.92.19), 30 hops max, 60 byte packets
 1  AtMyNet.es (IP)  3.603 ms  4.415 ms  4.376 ms
 2  AtMyNet.es (IP)  4.586 ms  4.547 ms  4.816 ms
 3  AtMyNet.es (IP)  3.144 ms  3.113 ms  3.231 ms
 4  ge-1-1-5.almeria01.AtMyNet.es (IP)  4.668 ms  4.628 ms  4.861 ms
 5  xe-0-2-1.malaga01.AtMyNet.es (IP)  5.629 ms  5.605 ms  5.777 ms
 6  cica.ae5-69.uv.rt1.val.red.rediris.es (IP)  16.230 ms  15.960 ms  15.917 ms
 7  uv.ae5.telmad.rt4.mad.red.rediris.es (IP)  26.637 ms  23.158 ms  22.651 ms
 8  rediris-ias-geant-gw.mar.fr.geant.net (IP)  51.929 ms  51.873 ms  51.844 ms
 9  ae8.mx1.gen.ch.geant.net (62.40.98.73)  54.465 ms  54.697 ms  54.270 ms
10  ae6.mx1.par.fr.geant.net (62.40.98.183)  54.224 ms  54.144 ms  54.491 ms
11  ae5.mx1.lon2.uk.geant.net (62.40.98.178)  55.304 ms  54.825 ms  55.233 ms
12  ae6.mx1.lon.uk.geant.net (62.40.98.36)  61.748 ms  61.721 ms  61.651 ms
13  195.66.226.116 (195.66.226.116)  53.373 ms  53.337 ms  53.608 ms
14  173.231.129.65 (173.231.129.65)  54.202 ms  53.533 ms  54.118 ms
15  107.6.86.149 (107.6.86.149)  54.434 ms  54.391 ms  54.344 ms
16  border3.xe-0-1-0-bbnet1.lon003.pnap.net (212.118.240.52)  50.912 ms border3.xe-1-1-0-bbnet2.lon003.pnap.net (212.118.240.116)  50.276 ms border3.xe-0-1-0-bbnet1.lon003.pnap.net (212.118.240.52)  50.248 ms
17  canonical-4.edge1.lon.pnap.net (212.118.242.26)  51.460 ms  51.738 ms  51.368 ms
18  zeeman.canonical.com (91.189.93.205)  51.313 ms  51.222 ms  51.177 ms
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
50 (edited by ppd 2019-06-22 08:45:52)
Re: snap package
Remove the s from your https_proxy so it looks like https_proxy=http://...
