Topic: install the DXF converter 2017-Jul-18
I would like to install the DXF converter 2017-Jul-18, but I can not start from QElectrotech. I work with version V 0.60-RC3 + svn5127 and XUBUNTU 16.04. In a Virtual Box I have XUBUNTU 17.10 and the version 0.70.r5129 and there it works. Does the DXF Converter 2017-Jul-18 only work with a later version?
Best regards
Stebo
Re: install the DXF converter 2017-Jul-18
@ Calypso:
did you make the file executable?
chmod +x DXFtoQET
3 (edited by Calypso 2017-12-03 13:09:27)
Hello Nuri,
I entered chmod +x /home/stebo/.qet/DXFtoQET in XUBUNTU 17.10 in a terminal and I was able to start the DXF converter from QElectrotech. But if I do it the same way with XUBUNTU 16.04 it will not work.
Best regards
Stebo
4 (edited by Nuri 2017-12-03 15:12:11)
Hi Stebo,
I'm on ubuntu 16.04 (Unity) and I have downloaded the last DXFtoQET from 2017-Jul-18.
I have made the file executable and then, I have tried to run it from the GUI -> nothing happened.
Then I have tried to run it from the Terminal and I get the following output:
nuri@nurikiste:~/.qet$ ./DXFtoQET
./DXFtoQET: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.7' not found (required by ./DXFtoQET)
./DXFtoQET: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5' not found (required by ./DXFtoQET)
./DXFtoQET: /usr/lib/x86_64-linux-gnu/libQt5Sql.so.5: version `Qt_5' not found (required by ./DXFtoQET)
./DXFtoQET: /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5: version `Qt_5' not found (required by ./DXFtoQET)
It seams that the Qt libraries are to old on 16.04.
Try to run an older version of DXFtoQET on 16.04.
On my system, I run the version from 2017-02-22.
Hello Nuri,
I get no error messages in the terminal. I have tried all versions, only the version linux_x86-64_qt5.5.1 / 2016-Mar-26 I can start from QElectrotch. Funny thing is that I can start the version linux_x86-64_qt5.5.1 / 2016-Mar-26 without QElectrotech.
Best regards
Stebo
Hi Calypso,
you could also download latest dxftoelmt branch and compil it with your Qt 5 version.
svn checkout svn://svn.tuxfamily.org/svnroot/qet/qet/branches/DXFtoQET3_DB DXFtoQET3_DB
cd DXFtoQET3_DB/
qmake-qt5   # or qmake
make -j$(nproc)
chmod +x ./DXFtoQET
./DXFtoQET
mv ./DXFtoQET ~/.qet/
Btw, or a specific commit (see web svn) for changelog : https://svnweb.tuxfamily.org/log.php?re … dir=1&
svn export svn://svn.tuxfamily.org/svnroot/qet/qet/branches/DXFtoQET3_DB --revision 4988 DXFtoQET3_DB_rev-4988
Hello scorpio810,
So I downloaded the version DXF converter 2017-Jul-18 and subversion installed. After I saved the file in the directory / home / stebo /. After executing your statement, the file is moved to the .qtec folder and a new DXFtoQTEC3_DB folder is located in the / home / stebo / directory.
But I can not start the DXFtoQET converter. Did I forgot something?
Best regards
Stebo
Hi Caplyso,
I think you need to install qt5-qmake, libqt5core5a, qtbase5-dev, libqt5svg5-dev, libqt5gui5, libqt5sql5-sqlite, etc
laurent@debian:~/test/DXFtoQET3_DB$ objdump -p /home/laurent/test/DXFtoQET3_DB/./DXFtoQET | grep NEEDED
 NEEDED               libQt5Widgets.so.5
 NEEDED               libQt5Gui.so.5
 NEEDED               libQt5Sql.so.5
 NEEDED               libQt5Core.so.5
 NEEDED               libGL.so.1
 NEEDED               libpthread.so.0
 NEEDED               libstdc++.so.6
 NEEDED               libm.so.6
 NEEDED               libgcc_s.so.1
 NEEDED               libc.so.6
Hello scorpio810,
The folder DXFtoQET3_DB is generated by me but with me is not so much in it as with you. I think I missed something or did something wrong. I will once again watch your video to understand your approach.
Best regards
Stebo
You need to compile program DXFtoQET3_DB with your Qt libs installed.
OK,
have qt5-qmake installed version 5.5.1 for XUBUNTU 16.04 is the latest.
XUBUNTU 17.10 uses version 5.9.1 I think it depends on it. I will then install XUBUNTU 17.10 on my main system.
Best regards
Stebo
Don't upgrade your XUBUNTU 16.04 to 17.10, just install needed Qt 5.5.1 libs for compile and build yourself DXFtoQET3_DB.
The goal is to build plugin with your Qt version installed in your distrib.
Best regards,
13 (edited by Calypso 2017-12-07 15:17:37)
Hello scorpio810,
I'm not looking right through, they are installed (qt5-qmake, libqt5core5a, qtbase5-dev, libqt5svg5-dev, libqt5gui5, libqt5sql5-sqlite) which ones do I need? These can not be installed (libQt5Widgets.so.5, libQt5Gui.so.5, libQt5Sql.so.5, libQt5Core.so.5, libGL.so.1, libpthread.so.0, libstdc ++. So.6, libm. so.6, libgcc_s.so.1, libc.so.6), they do not exist with me.
Best regards
EDIT: I have compared the qt libs of XUBUNTU 16.04 and XUBUNTU17.10 are the same registered difference is the version 5.5.1 and 5.9.1
Stebo
libQt5Core.so.5 etc is libs name when you install libqt5core5a package.
open your DXFtoQET3_DB in a terminal
make
15 (edited by Calypso 2017-12-07 19:22:54)
So qmake-qt5 is installed but when I enter your commands in the terminal following statement:
The command qmake-qt5 was not found, you might have said:
 qmake-qt4 command from the qt4-qmake package (main)
qmake-qt5: Command not found.
stebo @ stebo: ~ $ make
Best regards
Stebo
sudo apt install qt5-qmake
Obviously, the name of the package had been changed nomicons/sideways
17 (edited by Calypso 2017-12-07 19:22:41)
the package is already installed. I do not look through enymore nomicons/cwy
stebo @ stebo: ~ $ sudo apt install qt5-qmake
Package lists are read ... Done
Dependency tree is set up.
Status information is read .... Done
"Qt5-qmake" is already the latest version (5.5.1 + dfsg-16ubuntu7.5).
0 updated, 0 reinstalled, 0 removed and 0 not updated.
stebo @ stebo: ~ $
Best regards
Stebo
Try
/usr/lib/x86_64-linux-gnu/qt5/bin/qmake  or qt5-qmake
make
19 (edited by Calypso 2017-12-08 11:20:38)
Hello scorpio810,
what do you mean the file is there.
Best regards
Stebo
2017-12-08 10:14:21.png, 9.38 kb, 449 x 203
Hello Caplyso,
have you tried to compil it now?
Download source files :
Go to directory :
cd DXFtoQET3_DB/
Compilation
make -j$(nproc)
Make it executable
chmod +x ./DXFtoQET
Test if run
./DXFtoQET
Now move or copy to QET user folder
Now, the DXF converter can be started from the QET editor menu.
Hello scorpio810,
so I have:
Download source files:
svn checkout svn: //svn.tuxfamily.org/svnroot/qet/qet/branches/DXFtoQET3_DB DXFtoQET3_DB
OK then:
Go to directory:
cd DXFtoQET3_DB /
OK then:
compilation
/ Usr / lib / x86_64-linux-gnu / QT5 / bin / qmake
make -j $ (nproc)
when I come in heaps of error messages and warnings.
I do not know, but at some point a file called Makefile has been created in the folder DXFtoQET3_DB.
I will try again but it seems as if there is always demand for qt4 although it is not installed.
Best regards
Stebo
It 's only Qt 5 version DXFtoQET3_DB
Yes we can see a lot of warnings, but compil fail or finish?
Paste the end of compilation, if you make it executable you can launch program?
23 (edited by Calypso 2017-12-09 18:08:54)
Hello scorpio810,
so I have uninstalled everything from qt5 (qt5-qmake, libqt5core5a and others). Then I have all reinstalled, then I've done your steps again. After doing the path / usr / lib / x86_64-linux-gnu / QT5 / bin / qmake make -j $ (nproc), the terminal continued to run and the DXFtoQET Converter was installed. Why it did not work yesterday when entering the path I can not say exactly.
Best regards
Stebo
Hello Calypso,
nice, you have now DXF converter run with your Qt 5.5.1 libs.
Best regards,
Nuri wrote:
@ Calypso:
chmod +x DXFtoQET
Or in one command to get and launch it :
x=DXFtoQET; wget https://download.qelectrotech.org/qet/builds/dxf_to_elmt/linux/2017-07-18/${x}; chmod +x ${x}; ./${x}
cd ~/.qet/
laurent@debian:~/.qet$ x=DXFtoQET; wget https://download.qelectrotech.org/qet/builds/dxf_to_elmt/linux/2017-07-18/${x}; chmod +x ${x}; ./${x}
--2019-06-23 12:16:35--  https://download.qelectrotech.org/qet/builds/dxf_to_elmt/linux/2017-07-18/DXFtoQET
Résolution de download.qelectrotech.org (download.qelectrotech.org)… 2a01:e0d:1:3:58bf:fa12:0:1, 2a01:e0d:1:4:58bf:faab:0:1, 88.191.250.18, ...
Connexion à download.qelectrotech.org (download.qelectrotech.org)|2a01:e0d:1:3:58bf:fa12:0:1|:443… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 750832 (733K) [application/octet-stream]
Sauvegarde en : « DXFtoQET »
DXFtoQET        100%[==========================================================================================================================================================================================================================================================>] 733,23K  1,46MB/s    ds 0,5s
2019-06-23 12:16:35 (1,46 MB/s) — « DXFtoQET » sauvegardé [750832/750832]
[12:16:39] laurent@debian:~/.qet$
Enjoy !
