Topic: Rules with handling of conductors
Hello
Is there a particular rule for the labeling of conductors? Does the Multiline text column need to be a character or can it remain empty?
Best regards
Stebo
QElectroTech → EN : Help, suggestions, discussions, ... → Rules with handling of conductors
Hello
Best regards
Stebo
In folio properties i have in the "Type" tab the field "Text:" empty, so conductors initially have no naming, and most conductors i do not name.
There is still a invisible but selectable spot along the conductor for the "Text:" which is possible to select and edit.
Hard to find, but right click the conductor and hit Ctrl+e and edit anything about it.
Have you seen a problem?
And whether it is possible to move the conductor's marker aside. Permanently a problem with moving a conductor, I get on a marker.
Yes the default position of conductor labels most often make them land on the neighbour so unless moved manually the labeling is wrong. (my drawings are pretty dense)
https://qelectrotech.org/bugtracker/view.php?id=91
https://qelectrotech.org/bugtracker/view.php?id=89
I often move them so they "sit" on the conductor
He understood himself. It is necessary to remove the mark of the text in the page properties.
Ah you wanted to remove it.
Sorry I misunderstood.
Didn't notice it earlier, but now often I get on the tag of the conductor, but not on the conductor
https://youtu.be/GZ-GecJmC1w
In the folio settings, remove the mark in the box next to "Visible text" in picture
To set the defaults for new pages ("folios"), use Project properties.
Right click your project in the project list and select "Project properties" and select:
Generated in 0.021 seconds (22% PHP - 78% DB) with 11 queries
