Topic: Rules with handling of conductors
Hello
Is there a particular rule for the labeling of conductors? Does the Multiline text column need to be a character or can it remain empty?
Best regards
Stebo
Re: Rules with handling of conductors
In folio properties i have in the "Type" tab the field "Text:" empty, so conductors initially have no naming, and most conductors i do not name.
There is still a invisible but selectable spot along the conductor for the "Text:" which is possible to select and edit.
Hard to find, but right click the conductor and hit Ctrl+e and edit anything about it.
Have you seen a problem?
And whether it is possible to move the conductor's marker aside. Permanently a problem with moving a conductor, I get on a marker.
4 (edited by Morganol 2017-02-05 19:58:59)
Yes the default position of conductor labels most often make them land on the neighbour so unless moved manually the labeling is wrong.  (my drawings are pretty dense)
https://qelectrotech.org/bugtracker/view.php?id=91
https://qelectrotech.org/bugtracker/view.php?id=89
I often move them so they "sit" on the conductor
Screenshot_20170205_185236.png, 51.93 kb, 399 x 643
He understood himself. It is necessary to remove the mark of the text in the page properties.
Ah you wanted to remove it.
Sorry I misunderstood.
Didn't notice it earlier, but now often I get on the tag of the conductor, but not on the conductor
https://youtu.be/GZ-GecJmC1w
In the folio settings, remove the mark in the box next to "Visible text" in picture
Screenshot_20170209_081414.png, 20.04 kb, 643 x 268
To set the defaults for new pages ("folios"), use Project properties.
Right click your project in the project list and select "Project properties" and select:
Screenshot_20170209_081814.png, 71.24 kb, 964 x 472
