Topic: Create an elmnt from a SVG file; or png file
Dear QET's
Just draw this image and want to us it as an element and save it in my lib.
I really thought that I could convert this to an element; but can't find it how to this.
On the terminals of the Accu/battery I want to create a Positive and Negative terminal to get it connected to the wire diagram.
Any suggestions?
Like always thank you very much.
If there is a step to step tut, please let me know.
Battery_charging.png, 13.28 kb, 533 x 250
Re: Create an elmnt from a SVG file; or png file
Hello rvamerongen,
if you have SVG, you have possibility to convert your file to with Inkscape (a best open source software) to DXF format , after use dxf2elmt plugin for converter and transform your DXF to QET elment  *.elmt file.
Best regards,
I return to sleeping.. I am so tired!
New .dxf to .elmt Conversion Program
https://qelectrotech.org/forum/viewforum.php?id=12
Download
https://download.qelectrotech.org/qet/b … mt/V0.3.0/
3 (edited by rvamerongen 2023-12-04 18:58:12)
Already tried but did get just an outline very ugly
Maybe try online converter SVG to DXF...
Good night..
5 (edited by rvamerongen 2023-12-04 20:35:35)
Same result.
Screenshot 2023-12-04 at 19.34.22.png, 7.82 kb, 559 x 361
@rvamerongen
This is not a normal xml (plain text) svg.
I think this is a compressed svg.
That can be the problem.
I am an industrial developer technician and born in 1960
7 (edited by rvamerongen 2023-12-04 21:18:03)
Hi
I can read the text from the files.
Anyway. Then by hand in the element editor.
If someone can use it, please do.
Or have comments, please do.
I got two different ones with comments and value's but are to specific.
Screenshot 2023-12-04 at 20.14.43.png, 7.25 kb, 238 x 221
8 (edited by plc-user 2023-12-05 00:06:50)
Hello rvamerongen,
your SVG cannot be converted to DXF because most of it is an integrated Bitmap!
There is only one rect as outline of the Battery and the six smaller white rects is one big path.
You can even see that when you open SVG in a Text-Editor (see attachment).
If you open your SVG in Inkscape and look at the "Ebenen und Objekte"-Tab (opened with via Menu) you'll see what's inside your SVG: Most of it is a Bitmap that cannot be converted by any DXF-converter.
Such "simple" Symbols can be drawn very quick and easy with QET's Element-Editor:
Only rects that can be duplicated by <Ctrl>-C <Ctrl>-V
Bildschirmfoto_Battery_in_Inkscape.png, 19.88 kb, 703 x 363
Bildschirmfoto_Battery_in_Text-Editor.png, 23.75 kb, 945 x 119
@plc-user
Thank you for the information. I did download InkScape yesterday, so I don't know all the in and outs.
Curious where it did get started to go wrong.
I did draw it in Photoshop using the rectangle tools and fill's saving it as SVG.
then converted it with InkScapen ( and a web Converter ) to DXF.
Then just imported it in QET.
Will check what you wrote later today. Maybe I can draw it in InkScape and look for the difference
10 (edited by plc-user 2023-12-06 01:18:45)
Hello rvamerongen,
as far as I know photoshop can only handle pixel-graphic.
QET and Inkscape work with and produce Vector-Graphics.
If you have a pixel-graphic you have to work with "potrace" or the vectorising-features of inkscape to "trace" the graphic and thus create a vector graphic. In German Version of Inkscape: import a Bitmap to current file, click the image to mark it and then "Menü" -> "Pfad" -> "Bitmap nachzeichnen..." opens a tab where some parameters for tracing can be set.
When vectorised, converted to dxf, converted to QET-Element there is still much work to do, when you want to produce a fine-looking Element that only contains the necessary and visible parts. In the accu.elmt you attached earlier there are some polygons included that "blow up" the file-size but cannot be seen in the element because they are hidden behind the black rects! When I delete the invisible polygons, the file-size is reduced to less than half to 4.3kByte. When I adjust the English name of the element the file-size even reduces to 4.1kB...
But as I said in an earlier post:
For such simple Elements like the accu it would be much faster to draw it "from scratch" or you create yourself a template where for example a rect and some translations are included you'll be even faster in future!
EDIT: Of course I mean simple Elements can be drawn only with QET-Element-Editor!
I hope I haven't scared you off with these explanations!
Best regards,
  plc-user
@plc-user
Don't worry. I just 'almost' never used and needed InkScape, so knowledge about that is less than less.
Like Plc-user: for draw simple symbol like your battery, please use element editor include is so easy.
DXF2elmt is used fand needed for complex symbols like this:
Thank you.
I wrote before that I did redraw it with the internal editor
"Anyway. Then by hand in the element editor."
@rvamerongen, and all: the magic thing about incliude element editor: that you open several element select many part of other symbol and paste this part and create a complex symbol from scratch like frankeintein, if you understand what I say.. nomicons/wink
Best regards,
Workaround was power and I was the master, nomicons/smiley-green
My idol is Mac Giver...since my my childhood, uhuhu
Best regards,
True, I did create the cells in another document (element).
This beg the question /request that I would like to save parts outside the elements library folder.
Hello rvamerongen,
you noticed, that you can have a User-Collection?
I created a User-Collection where I have a Sub-Folder for elements "in development" (see attachments).
Each with a separate "qet_directory"-file with a QET-name for the Sub-Folders...
This would be the place for your "templates".
Bildschirmfoto_Preferences_Collections.png, 33.96 kb, 840 x 281
Bildschirmfoto_Sub-Folder_User-Collection.png, 11.31 kb, 269 x 207
17 (edited by rvamerongen 2023-12-11 12:39:14)
Thanks but I know and did this before.
have 350+ own elements in there. But like to have ‘parts’ separated somewhere outside QET from the final result.
Changed 35 to 350
Why not create a subdirectory for drafts there?
Some time ago I already suggested implementing a second user collection (https://qelectrotech.org/forum/viewtopic.php?id=2105), but the limited number of developers for QET unfortunately prevents this.
That was meant for another reason, but could be useful here, too.
Hallo plc-user,
you can change directory official or custom collection on the fly,
1] change PATH for custom collection.
https://download.qelectrotech.org/qet/forum_img_2/Bildschirmfoto_Preferences_Collections.png
2] on element collection tree field make a right click -> reload, and  voila. nomicons/wink
Regards,
laurent
Salut Laurent!
See the other Thread: https://qelectrotech.org/forum/viewtopic.php?id=2647  nomicons/smile
Best regards
  plc-user
Hallo plc-user,
Regards,
laurent
Hallo Plc-user,
I make a little video:
Best regards,
What do you want to say with this video, Laurent?
Do you think I don't know how to use the preferences-dialog?
Sorry again, Plc-user if I hurt your feelings, that was not my intention..
I adore you for your patience, and all your work, you mean a lot to me.
I'm still sorry if I offended you..
Best regards,
Apology accepted, Laurent!
