Re: freepascal-code to take a QET- Element and scale the content by a fact
Hi Plc-user,
it only takes me ~3 seconds to compile it and push it to the repository.
QElectroTech → Scripts → freepascal-code to take a QET- Element and scale the content by a fact
Hi Plc-user,
Today I uploaded a new version of "QET_ElementScaler" to github: https://github.com/plc-user/QET_ElementScaler
This version is completely rewritten in C++, where I (like QET) use pugixml for handling the contents of the element files.
I made a few additions/changes that makes working with the software easier: The XML description line no longer needs to be removed afterwards!
As before, x and y scaling factors can be specified, input is via STDIN (-i) or a file (-f FILEINAME) and output is, as before, to a new file or to STDOUT (-o).
In addition, I have added the possibility to remove "terminals" from the element. This can be useful when terminals can be omitted from overloaded front views.
Furthermore, there is now the possibility to flip polygons and lines horizontally and/or vertically. This can be useful during the development of complex front views, as long as these functions are not yet available in the QET element editor.
Special care should be taken with the option "--OverwriteOriginal", because here the original file will be overwritten WITHOUT further request!
The scaled values of the new element are written into the new file with a maximum of 2 decimal places. In my view, this is completely sufficient for the display of schematic symbols and front views (thumbnails). In some elements present in the QET collection I have seen values with up to six decimal places, which in my opinion is excessive.
To "fix" such elements, QET_ElementScaler can of course be used! With the call:QET_ElementScaler -f FILENAMEthe values are rounded to max. 2 decimal places and any font sizes with decimal places are rounded to whole numbers.
I wish all users of the software a lot of fun and success with it and would like to see bugs reported (e.g. here or at github). Of course, I also have an "open ear" for suggestions for improvement!
Best regards
plc-user
It's not possible to integreted it directly on QET like it's C++?
Hi Plc-user,
Thank you very much !
There are several new topics for me at once:
For the beginnings in Pascal I only needed to add a little XML to the Pascal knowledge. The change to C++ was then already bigger. But then to integrate that into an existing, grown QT project, that's quite another matter...
For the moment I have put together a small (and from my point of view) usable package. There is no question that in the foreseeable future it will make sense to integrate scaling and mirroring directly into QET's Element-Editor!
Ok, compile and work fine on Apple Silicon chip.![]()
laurent@mini-de-laurent ~ % cd QET_ElementScaler
laurent@mini-de-laurent QET_ElementScaler % ./QET_ElementScaler --FlipVertical -f ../.qet/elements/p.elmt
galexis wrote:It's not possible to integreted it directly on QET like it's C++?
Bravo plc-user! QET becomes more and more appealing by the day - many thanks for your great work!
Hamish
Hello everyone, I have many doubts regarding the use of this program, I am not an expert in program issues and their execution at the CMD level, but I need to scale a DXF so that it is the actual size of the design, qelectrotech makes it smaller. Could someone tell me how to use this program properly on Windows, please?
in last version 0.100-dev "Import an element to resize" was implanted directly on element editor, no need to use terminal if you want.
See the plc-user's quick-guide -> https://download.qelectrotech.org/qet/Q … ick-guide/
https://qelectrotech.org/forum/viewtopic.php?id=2795
For installation and can be launched in element editor it's the same way like dxf2elmt install see:
https://qelectrotech.org/forum/viewtopi … 116#p17116
(...) but I need to scale a DXF (...)
As the name QET_ElementScaler might suggest, only QET-Elements can be scaled by that software!
You need to convert your dxf to a QET-Element before using QET_ElementScaler!
I appreciate the prompt response provided, I was able to install the qelectrotech plugin satisfactorily, now I have another couple of questions, I hope this doesn't sound overwhelming.
1.What is the correct way to create a new element from a DXF?
I am currently importing my DXF to the new elements editor in qelectrotech, to be able to add the necessary connections, but I see that the DXFTOQET tool is suggested in the forum. Does this program perform the same procedure or does it perform any additional processes?
2.What scale does Qelectrotech work on?
Currently, from the element editor I exported a DXF with measurements of 100mm 27mm (100 X 49.92mm).
Did you notice the menu-entry just below "Import scaled element"? (see attachment!)
AND: Use the conversion-tool dxf2elmt! The other tool is VERY outdated!
You find the download-link for win64 in this post: https://qelectrotech.org/forum/viewtopi … 520#p20520
(...) I exported a DXF (...)
What do you want to do?
QET works with own file-formats for elements and schematics!
I think, many of your questions about scale and dxf-import will be answered, if you read in the other thread and follow the links there:
https://qelectrotech.org/forum/viewtopi … 684#p20684
Merci pour l'aide, j'ai en fait assez de puissance, vous pouvez créer mes composants et les adapter à ceux que vous ne souhaitez pas, et mes plans électriques sont ceux que j'aime. Salutations et merci d'avoir créé ce programme incroyable !
Salut galexis !
Hello everybody!
Maybe you already noticed?
Available in current 0.100-dev-version of QElectroTech:
In the last few days I implemented mirror (shortcut <M>) and flip (shortcut <F>) into element-editor.
Also the rotate-function was reworked, so that rotating of ALL primitives is made in increments of 90° with <Space>.
Rotation with smaller increments of 5° can be made with "text", "dynamic_text", "line" and "polygon" with <Ctrl>+<Space>.
"Merci" to Laurent, who supported with building all binaries!
Best regards
plc-user
"Danke" to plc-user, for your great work!
I build new QET_ElementScaler 0.5.4 macOS aarch64 binary, because binary provided by plc-user didn't work!
Hallo plc-user,
I tried your macOS aarch64 binary on new UTM virtual machine:
https://github.com/plc-user/QET_Element … /tag/0.5.4
The binaries for macos are to be seen as a “trial version” to see if the toolchain from the Docker image works, I don't have the possibility to test the executables.
FYI, QET_ElementScaler was saw as a document, so chmod +x QET_ElementScaler but binary crashed with:
dyld[1287]: Symbol not found: __ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE4findEPKcm
Referenced from: <D63C1A82-B78B-3F68-82A5-96DD24C5057C> /Users/laurent/Library/Application Support/QElectroTech/QElectroTech/binary/QET_ElementScaler
Expected in: <9FA59D2E-B8CF-39C2-BD5D-C04628AED360> /usr/lib/libstdc++.6.dylibBest regards,
Salut Laurent !
Thanks for the information!
That is good to know:
Then I can save myself the effort of building and uploading these packages in future!
As written in release-section:
I can't test the macos-binaries myself anyway. And if they don't work, I don't need to create them any more...
QET_ElementScaler 0.5.4 for macOS intel X86_64
Bonjour.
The request to be able to flip a symbol of an electrical component vertically or horizontaly has been on this forum since before 2014.
Thanks, Scorpio 810 [24 July 2025], but at 75+, having to set up a whole development environment and learning Pascal just to do all this work is becoming too much of a hassle. For me, it would be fine if it were in C or C++.
I find it hard to believe that, after 12 years at least, one of the latest versions of QElectrotech still hasn’t addressed such an important request.
Why?
on last version 0.100.0 be able to flip or mirror a symbol of an electrical component vertically or horizontaly on element editor without need to add plc-user's plug-in.
Installing plug-ins in the element editor in version 0.100.0 is very straightforward: simply click on the File menu, select ‘Resize an element’ or ‘Import a DXF file’. You will be guided through the download and installation process. Just extract the binary maybe rename it, and put it in binary folder asked by widget.
Hi Chavadam,
You may have noticed, that I rewrote the whole application to C++ and released that code in October 2022!
From that time there were many updates to the C++-code: Latest in December 2025.
Only the subject of this forum-thread is left to original...
Additionally you do not need to compile it yourself, if you use ReactOS, win or Linux: There are binaries available in Release-section of my GitHub-repo.
EDIT:
Even back in the days of Pascal code, executable files for ReactOS, win and Linux were already available, so there was no need to compile them yourself!
Have a look here: https://github.com/plc-user/QET_ElementScaler/releases
You are expressly permitted to use the existing C++ - code of QET_ElementScaler to implement mirror and flip to QET! ![]()
Best regards
plc-user
Generated in 0.028 seconds (52% PHP - 48% DB) with 12 queries
