1 (edited by jhonathan disner 2022-11-06 00:01:49)
Topic: user collection
Hello,
I installed version 0.90-DEV+git7713-1, where I came across the following situation, in the collection of user elements, the name of the folders does not appear, where I already tried to change the path several times, I installed this version on the ntebook at home to be able to test and validate for other works, where I have been using version 0.7.
I would like help, because as I said, I've already made some attempts...
I'm waiting....
thankful.
Re: user collection
The folder-names are the loclised texts taken from the file "qet..." lying in that directory and not from the file-directory-name itself.
Please compare with the other directories in the QET-collection.
Re: user collection
I've made several attempts, but without success, until I create a new folder in the QET itself, it doesn't appear with mone, and the element itself doesn't appear in your design either.
but settings have a field where we define that directory or folder we are going to extract the elements or subfolders, I already configured it, but it doesn't work either.
D:\Users\Application Data\qet\elements
this being the path you are already selecting.
4 (edited by plc-user 2022-11-06 20:20:47)
Re: user collection
Just tried on a fresh installed win10 and "ReadyToUse - QET":
Created Sub-Directories under "c:\tools\qet\conf\elements\"
placed some elmt-files in the sub-sub-directory and created a file "qet_directory" for each sub-dir.
Here it works as expected. See screenshot.
Maybe the language is not set correctly on your system?
Did you start QET from the batch-file "Lancer QET.bat"?
qet-screenshot.png, 13.87 kb, 226 x 372
Re: user collection
my native language is Portuguese Brazil, I checked the language settings of the system and Qeletrotech and they are compatible.
finally, I installed version 0.7, and in this version everything works correctly, the folder names appear and it runs perfectly.
and in version 0.8 and 0.9 the folder names and element drawings do not appear.
6 (edited by jhonathan disner 2022-11-07 03:00:26)
Re: user collection
Did you start QET from the "Lancer QET.bat" batch file?
no, I did the installation from the ''.exe'' file
Re: user collection
https://github.com/qelectrotech/qelectr … _directory
Re: user collection
It does not matter, how you installed QET. The question was how you start QET to use it.
Do you double-click on the executable file or do you start QET from the batch-file "Lancer QET.bat"?
When starting from the batch-file it reads some environmental settings and then it will start QET with the appropriate settings for language, etc.
Re: user collection
I double click to open the program, and it runs.
I've done everything, revised the ''QET-DIRECTORY'' directory, changed languages, changed the source folder, but nothing.....
version 0.70-dev+svn5121-1, rada perfectly.....TOP....
but unfortunately version 0.90-DEV_x86_64-win64+git7713-1, no...
I hope you can still help me... but I thank you for your willingness....
I will continue to search...
Re: user collection
Hello,
I installed version 0.9 on another computer, and the same problem with unnamed folders also occurred, and even creating a folder directly in Qeletrotech, it does not update.
I thought the error could be on the first computer, but it remained on the second.
I also tried to change the language both in the pastya features and in the software itself.
Re: user collection
Have you tried with 32 bits version?
Ins't the same libs, see :https://qelectrotech.org/forum/viewtopic.php?pid=16928#p16928
Re: user collection
Hello,
Yesterday I still had the problem of the names in the user's collection, where the mnemso didn't appear, with many attempts in vain, and after so much insisting I ended up finding the cause.
on the notebook that I installed Qeletrotech 0.9 has two memory disks (HDs)
one for general storage (D/), and the other for software (C/).
Qeletrotech is installed on the software disk (C/), and the user's collection is stored on the general disk (D/), thus the error in the naming of folders and components occurred.
solution:
I created a user folder on the disk (C/) and put the user's collection in this folder.. done...bingo...it worked...
thanks for the help....
Re: user collection
Strange, but not the case on Linux, maybe also a Win... problem ...
Under Windows disk (C:\) I/O file sytem is very very filtering by OS and other 3rdparty like antivir, indexing, telemetry, driver's, programs, etc.
For faster I/O Microsoft recommand using disk D: ....
Re: user collection
hello
I am changing computers, and the problem with the name of the user's collection folder happened again, and now this time it is installed in the right folder, so I need help to resolve this issue.
I already directed the path to the folder in the settings to try to adjust this, but without any gain, here are some photos and information to make this situation clearer.
this is the path to the collection files: C:\Users\User\Application Data\qet\elements
Attachment icon Captura de tela 2024-10-11 150901.png 165.57 kb, 8 downloads since 2024-10-11
Captura de tela 2024-10-11 152142.png, 29.27 kb, 561 x 279
