Ok, I can see when i click on the text in the diagram editor that the option is available in the properties. This is checked/enabled by default.
Is it possible to uncheck/disable by default?
My problem is that I have many symbols that use dynamic text for terminal names. This enables me to rename the terminals as I need. For example I have created VFD's with limited terminals to keep the size small. Then I can rename the terminals as I need them. Otherwise I will have various versions of the same VFD in the collection for different terminal combinations.
I can go and edit all the symbols to use plain text, but that is a lot of work.
