Topic: tester 2 éléments
j'ai créer 2 éléments 2 contacteurs inverseurs 3 poles et 4 pôles
Je n'arrive pas à connecter les bornes si quelqu'un peut tester ces 2 éléments.
QElectroTech → Elements → tester 2 éléments
each connection is given its own identification when it is inserted into a symbol. With your symbols it looks like the connectors have been copied and then pasted because the identifications are duplicated. As far as I know, this problem has been fixed (current version).
sincerely yours
Stebo
Hello
Current version ?
Je les ai refaits 2 contacteurs inverseur qui n'existant pas dans la bibliothèque et qui fonctionne.
Ils peuvent etre mis dans :
"02_power_contacts"
symbol opened with a text editor. The colored lines are the connections. Using the colored markings, you can see that identifications are duplicated.
Best regards
Stebo
Hum strange, I though I was fixed this problem, may be a special case which cause the issue.
I see that.
symbol opened with a text editor. The colored lines are the connections. Using the colored markings, you can see that identifications are duplicated.Best regards
Stebo
Indeed it is understandable
Generated in 0.036 seconds (20% PHP - 80% DB) with 11 queries
