1 (edited by tito.tit 2020-09-01 20:10:12)
Topic: tester 2 éléments
j'ai créer 2 éléments 2 contacteurs inverseurs 3 poles et 4 pôles
Je n'arrive pas à connecter les bornes si quelqu'un peut tester ces 2 éléments.
Merci
2 (edited by Calypso 2020-09-01 20:52:38)
Re: tester 2 éléments
Hello,
each connection is given its own identification when it is inserted into a symbol. With your symbols it looks like the connectors have been copied and then pasted because the identifications are duplicated. As far as I know, this problem has been fixed (current version).
sincerely yours
Stebo
3 (edited by tito.tit 2020-09-01 22:47:59)
Hello
Current version ?
Je les ai refaits 2 contacteurs inverseur qui n'existant pas dans la bibliothèque et qui fonctionne.
Ils peuvent etre mis dans :
"02_power_contacts"
4 (edited by Calypso 2020-09-01 20:59:52)
Hello,
symbol opened with a text editor. The colored lines are the connections. Using the colored markings, you can see that identifications are duplicated.
Best regards
Stebo
Screenshot 020-09-01 20:41:12.png, 121.83 kb, 684 x 677
Hum strange, I though I was fixed this problem, may be a special case which cause the issue.
I see that.
Calypso wrote:
Hello,
Best regards
Stebo
Indeed it is understandable
