Sources :
Minor : Rename variable for translation , Laurent Trinques
Add new variables for report folio and can be added in a composite text , Laurent Trinques
Fix bug with folio report formula , Claveau Joshua
Replace minus (-) by underscore (_) , Claveau Joshua
minor , Laurent Trinques
generalWidget : add Kindinformations , Laurent Trinques
generalWidget : add link type information , Laurent Trinques
Improve ProjectDataBase use , Claveau Joshua
Minor improvement , Claveau Joshua
allow multiedit also for arceditor, ellipse, line, rectangle and show properties when single polygon is selected , Martin Marmsoler
add Vertical sparcer's , Simon De Backer
Fix crash. , Claveau Joshua
Summary query widget : config can be saved/loaded , Claveau Joshua
Continue new summary feature , Claveau Joshua
fix tr() cannot be called without context , Simon De Backer
fix deprecated warning int QWheelEvent::delta() const , Simon De Backer
fix Wmisleading-indentation , Simon De Backer
add Q_UNUSED for TerminalData:: fromSettings & toSettings , Simon De Backer
fix Wdeprecated-declarations , Simon De Backer
Minor , Laurent Trinques
add font color of the conductors , Simon De Backer
another alternative ui for ConductorPropertiesWidget , Simon De Backer
Improve Simon patch : The window of the properties of the conductor does not exactly fit in height. , Laurent Trinques
The window of the properties of the conductor does not exactly fit in height. , Simon De Backer
fix fail to build , Claveau Joshua
Add new summary table (WIP) , Claveau Joshua
Revert "MacOS: try to remove hard coded python PATH" , Laurent Trinques
MacOS: try to remove hard coded python PATH , Laurent Trinques
Minor : general_widget add TextEditorInteraction , Laurent Trinques
Update Copyright date , Laurent Trinques
Try to fix Ubuntu 18.04 FTBFS, again , Laurent Trinques
Try to fix Ubuntu 18.04 FTBFS again , Laurent Trinques
do not set parts again when they are set already , Martin Marmsoler
implement currentParts() for every elementItemEditor so the editor can be extended to multi part edit in a later step , Martin Marmsoler
add multiedit feature also for dynamic text , Martin Marmsoler
static_cast is enough , Martin Marmsoler
multipart edit , Martin Marmsoler
- static_cast because it is a condition that it is PartTerminal , Martin Marmsoler
solves #7 , Martin Marmsoler
forgotten to commit texteditor , Martin Marmsoler
make partTextEditor capable to modify multiple parts at the same time , Martin Marmsoler
multiterminal change , Martin Marmsoler
WIP , Martin Marmsoler
not needed, because it is the same than a few lines below , Martin Marmsoler
Try to fix Ubuntu 18.04 FTBFS , Laurent Trinques
hot fix zoom and scrolling , Laurent Trinques
hot fix zoom and scrolling , Simon De Backer
remove inline, because it creates compile issues in release mode. see #48 , Martin Marmsoler
add comments , Martin Marmsoler
replace foreach by for , Martin Marmsoler
Use uuid instead of an index to connect multiple elements , Martin Marmsoler
move initialization to header, so it must not be done in every constructor , Martin Marmsoler
fix segmentation fault , Martin Marmsoler
fix nullpointer exception , Martin Marmsoler
try to use TerminalData in Terminal and PartTerminal, sou the code must not be written double , Martin Marmsoler
regarding to joshuas email, toXml uses a new structure. So it is changed in the properties interface and xrefproperties , Martin Marmsoler
Revert pull request #48 , Laurent Trinques
Improve last commit , Laurent Trinques
Fix FTBFS QTextStreamFunctions::endl(QTextStream&) , Laurent Trinques
fix deprecated warning QTextStream& QTextStreamFunctions::endl(QTextStream&) , Simon De Backer
fix deprecated warning Qt::WindowFlags = nullptr , Simon De Backer
fix deprecated warning void QGraphicsView::resetMatrix() , Simon De Backer
fix deprecated warning QMatrix QGraphicsView::matrix() const , Simon De Backer
Mod Copyright Date , Simon De Backer
fix deprecated warning QString::SplitBehavior , Simon De Backer
fix deprecated warning QButtonGroup::buttonClicked , Simon De Backer
fix deprecated warning QHash , Simon De Backer
fix deprecated warning QMap , Simon De Backer
fix deprecated warning QDirModel , Simon De Backer
Revert Martin pull request for now, and return to last 7e9fd8df9 commit , Laurent Trinques
graphics table properties editor : Add two buttons new button , Claveau Joshua
when model is not yet loaded, but the element editor should be opened, a segmentation fault occurs. Do not set current index when m_model is not yet loaded , Martin Marmsoler
QAbstractTableModel explicitly initialized in copy constructor , Simon De Backer
fix deprecated warning QSet<T> QList<T>::toSet() , Simon De Backer
fix deprecated warning qUpperBound , Simon De Backer
fix deprecated warning QList::swap() attempt 2 , Simon De Backer
fix deprecated warning QModelIndex::child , Simon De Backer
remove user-defined copy constructor , Simon De Backer
table item : remove a table remove also all linked tables , Claveau Joshua
Make a copie of previous table model when unlink a table from her previous table. , Claveau Joshua
Improve the use of the database , Claveau Joshua
Nomenclature model : Improve function to setup the name of header , Claveau Joshua
Table widget : Enable arrow to quicly switch to previous/next linked table , Claveau Joshua
fix deprecated warning QPainter::drawRoundRect , Simon De Backer
fix deprecated warning QTreeWidgetItem::setBackgroundColor , Simon De Backer
Add new conductors properties color and section , Laurent Trinques
fix deprecated warning QDrag::start , Simon De Backer
Add table dialog : table config can saved and loaded. , Claveau Joshua
Revert "fix deprecated warning QList::swap()" , Laurent Trinques
fix deprecated warning QList::swap() , Simon De Backer
fix deprecated warning QDir& QDir::operator=(const QString&) , Simon De Backer
fix -Wswitch warning , Simon De Backer
Nomenclature model don't save header data "display role" , Claveau Joshua
fix deprecated warning qVariantFromValue , Simon De Backer
fix deprecated warning QLineF::intersect , Simon De Backer
fix deprecated warning QFontMetrics::width(QChar ch) , Simon De Backer
fix -Wmisleading-indentation warning , Simon De Backer
*fix deprecated warning QWidget::getContentsMargins , Simon De Backer
fix deprecated warning QSet<T>::toList() Use values() instead. , Simon De Backer
Reduce the time spend when nomenclature table is created automatically , Claveau Joshua
Minor typo , Claveau Joshua
Add nomenclature dialog : enable option "add new folio and table if needed" , Claveau Joshua
Change the way how a diagram is added , Claveau Joshua
Nomenclature : enable option "fit to diagram" , Claveau Joshua
Typo , Laurent Trinques
Improve : Try to launch qet_tb_generator portable version of the plugin if user put binary on QDir::homePath() , Laurent Trinques
Animate search and replace widget when close with the button of the widget , Claveau Joshua
Minor : increase max conductors to 20px , Laurent Trinques
Minor : set maximum to 99 text conductor , Laurent Trinques
Minor : typo and tab edit order , Claveau Joshua
Bug fix : some element informations can't be set , Claveau Joshua
Prepare to add new country Norwegian switch , Laurent Trinques
Qet graphics table item can be removed from diagram , Claveau Joshua
qet graphics table item : to/from xml change , Claveau Joshua
Fix : key sequence 'space' don't work with nl be local , Laurent Trinques
Fix : key sequence 'space' don't work with nl be local , Claveau Joshua
Fix typo , Laurent Trinques
Nomenclature : Add dialog when insert a new nomenclature table , Claveau Joshua
Fix wrong element text value when loading from xml , Claveau Joshua
Minor : improve layout for low resolution screen , Claveau Joshua
Nomenclature query can be saved/load , Claveau Joshua
Update on PT_BR translation members , gleissonjoaquim3
Element query widget : widget restor is state according to the current query , Claveau Joshua
macOS : add more explanation in Message Box about install plugin , Laurent Trinques
Add view 'element_nomenclature_view' to projectDataBase , Claveau Joshua
Animate show and replace widget. , Claveau Joshua
element query widget : minor improvement , Claveau Joshua
Element info query : fix wrong behavior , Claveau Joshua
QetGraphicsTableItem : Imrpove how the table is resized , Claveau Joshua
Merge branch 'master' of ssh://git.tuxfamily.org/gitroot/qet/qet , Claveau Joshua
save/load QetGraphicsTableItem to/from .qet file , Claveau Joshua
Minor: aboutqetdialog.ui set compilation information selectable by mouse , Laurent Trinques
Element Editor add new ColorHTML, THANKS Arnaud for the patch , Laurent Trinques
Fix break from merge of qetgraphicsTableItem to master , Claveau Joshua
Replace minus (-) by underscore (_) in all element information , Claveau Joshua
Merge Q_OS_MACOS need now Python framework Versions 3.8 for launching qet_tb_generator plugin , Laurent Trinques
Merge remote-tracking branch 'origin/QetGraphicsTableItem' , Laurent Trinques
Minor fix : dynamic text can't have 'label' info if formula is set , Claveau Joshua
Minor revamp , Claveau Joshua
Cross Xref : display power contact by default , Claveau Joshua
Fix crash when close project , Claveau Joshua
Minor fix : in some condition master cross Xref are not displayed , Claveau Joshua
Revert : MACOS remove static path "/Library/Frameworks/Python.framework/Versions/ *" for launching qet_tb_generator plugin , Laurent Trinques
Moving elements by mouse does not respect the grid settings , Laurent Trinques
Minor fix: conductor text don't move with element. , Claveau Joshua
Merge branch 'QetGraphicsTableItem' , Claveau Joshua
Add widget to edit QetGraphicsTableItem and QetGraphicsHeaderItem , Claveau Joshua
Improve files names extension for Gnome DE and Flatpak , Laurent Trinques
Add itemTYpe for QetGraphicsTableItem and QetGraphicsHeaderItem , Claveau Joshua
Add QetGraphicsHeaderItem , Claveau Joshua
Add QetGraphicsTableItem + entry "add nomenclature" in project menu , Claveau Joshua
Merge remote-tracking branch 'origin/test_pugi' , Laurent Trinques
Improve loading time , Claveau Joshua
Loading elements collections doesn't freeze gui anymore. , Claveau Joshua
Minor improvement about using pugixml , Claveau Joshua
Remove old aboutQet class , Claveau Joshua
Revamp the aboutQet dialog with Qt designer and add a new tab "libraries" , Claveau Joshua
Clean code , Claveau Joshua
Minor : Fix wrong position with cross ref item displayed as cross , joshua
Improve file access on windows and mac OSX , joshua
Use pugixml for parse local name of directory and element informations , joshua
Add option to switch between Qtxml or pugi xml. Add dialog to display the elpsaed time of collection loading. , joshua
Minor pugi improvement , joshua
Add pugi_xml test branch , joshua
Merge branch '20191111_fix_permissions' , Laurent Trinques
Remove a diagram doesn't save the project anymore , joshua
Revert , Laurent Trinques
App does not work with Qt::AA_EnableHighDpiScaling flags enabled on Windows platform since Qt 5.13.X , Laurent Trinques
Fix crash when quickly move tab of digramview , joshua
Add QFutureWatcher , Laurent Trinques
bugfix, XREF Update when Text Alignment used , stromie@web.de
Remove QTabBar custom style , joshua
Remove Execute Permissions from Non-Executables , Kim Kirwan
CSV export : minor gui change , joshua
CSV export : improve save/load export configuration. , joshua
CSV export : change menu and dialog text , joshua
CSV export : improve selection type. , joshua
CSV export : improve database and query , joshua
CSV export : fix some missing informations. , joshua
CSV export : correctly export label , joshua
Nomenclature export : Minor change in UI , Laurent Trinques
Nomenclature export : add coil and protection query , Laurent Trinques
Nomenclature export : items double click , joshua
Revampe nomenclature , joshua
Revert previous commit , Laurent Trinques
Try to fix Windows sqlite cache PATH , Laurent Trinques
Add contributor , Laurent Trinques
Conductors num can be exported to csv file. , joshua
Simplify how a project is save , joshua
Fix crash when a .qet file with 0 diagrams. , joshua
Fix : element prefix don't work with custom path of user elements collection , joshua
macOs : add command key for fix mouse scroll , Laurent Trinques
Replance Q_OS_MAC Deprecated by Q_OS_MACOS , Laurent Trinques
aDD scroll page tabs ON MACos, Thanks Giovanni , Laurent Trinques
Improve QTabBar::tab:selected style , Laurent Trinques
Add green style color for tab selected , Laurent Trinques
For the Flatpak package : remove the file name extension added automatically to the saved files even if the user sets an unknown file extension for the program. , Laurent Trinques
Minor : fix typo , joshua
Element editor : improve polygon edition , joshua
Merge and clean Stromie patch : feature set xref slave position , Laurent Trinques
Force Fusion style on macOS , Laurent Trinques
Element editor : add a control key for moving by keyboard thes primitives selected by mouse area in 0.1 increments instead of 1 , Laurent Trinques
Element editor : add a control key for moving by keyboard selected primitives in 0.1 increments instead of 1 , Laurent Trinques
Improve folio list position (user don't know index is 0) 1 for first position 2 for second position 0 always in the end , Laurent Trinques
Set defaut position to second page , Laurent Trinques
Add in setting folio list position spinbox 0 for first position 1 for second position 99999 always in the end , Laurent Trinques
Elements :
Add new symbols , Laurent Trinques
add be lang , Simon De Backer
add and update symbols , sdeffaux
Add some "Vaillant" hydraulic elements for allSTOR , Simon De Backer
Add symbol , Laurent Trinques
Add new Vacuum Technology elements, thanks Dinozzo , Laurent Trinques
suppression de doublon , sdeffaux
Add some "Vaillant" elements, thanks riesermauf , Laurent Trinques
Add Weintek HMI symbols, thanks Rafał , Laurent Trinques
Add new Delta symbols, thanks Rafał , Laurent Trinques
add symbols and reorganised folders , sdeffaux
add symbols , sdeffaux
Add new symbols Legrand Viking, thanks Arnaud , Laurent Trinques
add symbols and reorganise folders , sdeffaux
Add new GCE symbols , Laurent Trinques
Add new Legrand elements, thanks Arnaud , Laurent Trinques
add symbol , sdeffaux
Add new symbols, thanks Bisku , Laurent Trinques
Delete duplicate folder , Laurent Trinques
mise a jour symbol , sdeffaux
add symbols and update , sdeffaux
Add new Rexroth valves, thanks Fernando , Laurent Trinques
dd new Wago elements, thanks Pcl-user , Laurent Trinques
add symbols hager , sdeffaux
Add new symbol, thanks Mihicz , Laurent Trinques
Refresh legrand/61-busbar/ dir, thanks Arnaud , Laurent Trinques
Refresh bticino dir , Laurent Trinques
Add new legrand & bticino symbols, thanks Arnaud , Laurent Trinques
Add new icp-das symbols, thanks Arnaud , Laurent Trinques
Refresh ICP-DAS elements, thanks Arnaud , Laurent Trinques
Add ICP-DAS elements, thanks Arnaud , Laurent Trinques
Traduction and add symbols , sdeffaux
Add new Legrand symbols, thanks Arnaud , Laurent Trinques
Add new symbol, thanks Alexis , Laurent Trinques
Add news symbols, thanks Arnaud , Laurent Trinques
Add new symbols, thanks David , Laurent Trinques
Update qet_directory , sdeffaux
Fix symbol state , Laurent Trinques
Add element, thanks Alexis , Laurent Trinques
Refresh Wago symbols, thanks Plc-user , Laurent Trinques
Add symbol, thanks Christophe , Laurent Trinques
Add new symbols, thanks Michele , Laurent Trinques
Improve Wago symbols, thanks Plc-user , Laurent Trinques
Minor : remove Dolphin .directory view file , Laurent Trinques
Add new Wago elements, thanks Plc-user , Laurent Trinques
Move symbols, thanks Galexis , Laurent Trinques
Build-aux :
snap: Start org.freedesktop.portal.Desktop on launch , Maximilian Federle
snap: Prevent the use of the KDE Plasma platformtheme , Maximilian Federle
Snap remove i386 architecture , Laurent Trinques
Enable only amd64 i386 architectures , Laurent Trinques
Refresh github link for DXFtoQET-2020 , Laurent Trinques
snap: Use symlinks instead of bind-mounts , Maximilian Federle
snap: Set correct PYTHONPATH , Maximilian Federle
snap: Use SNAP_USER_COMMON as HOME , Maximilian Federle
snap: Do not ship files already included in content snaps , Maximilian Federle
snap: Use kde-frameworks-5-core18-sdk to build , Maximilian Federle
snap: Use kde-neon extension , Maximilian Federle
Revert Update org.qelectrotech.QElectroTech.json not fixing Python's Tkinter need for qet-tb-generator , Laurent Trinques
Update org.qelectrotech.QElectroTech.json for Flatpak build , Laurent Trinques
flatpak: Properly rename the appdata file , Mathieu Bridon
build: Add a Flatpak manifest , Mathieu Bridon
build: Rename the packaging directory , Mathieu Bridon
build: Move the Snap recipes , Mathieu Bridon
Lang :
Danish translation , Ole Carlsen
Update * TS files , Laurent Trinques
updated hungarian files , artgg7300
Danish translation updated , Ole Carlsen
Update Polish translation, thanks Pawel , Laurent Trinques
modified: lang/qet_nl.qm modified: lang/qet_nl.ts , dlee99
Update *TS files , Laurent Trinques
translated hungarian files , artgg7300
Update fr en translation , Laurent Trinques
Minor Danish update , Ole Carlsen
Update polish translation, thanks Pawel , Laurent Trinques
Greek Lang update , aitolos
updated hungarian language files , artgg7300
Update Polish translation, thanks Rafal , Laurent Trinques
Update binary of norwegian translation , Laurent Trinques
Recent update of norwegian translation , Joel As
Update qet_nb.ts qet_nb.qm, thanks Joel , Laurent Trinques
Update qet_nb.ts , Laurent Trinques
Update *TS files and update english and french translation , Laurent Trinques
Update Binary be translation , Laurent Trinques
add translation be , Simon De Backer
Merge branch 'master' of ssh://git.tuxfamily.org/gitroot/qet/qet Translated hungarian files , artgg7300
Translated hungarian language files , artgg7300
Update danish translation , Ole Carlsen
Update translation ang generete new Norwegian dialects nb , Laurent Trinques
Update pt_b binary translation , Laurent Trinques
Update translation pt-br , gleissonjoaquim3
Update Fr translation , Laurent Trinques
Update En translation , Laurent Trinques
Czech translation update, thanks Pavel , Laurent Trinques
Update Greel Language files (spellcheck, typos) , aitolos
Update Greek Lang files , aitolos
Update Greek TS, thanks aitolos , Laurent Trinques
updated hungarian translate , artgg7300
Updated german translation , nuri
Update translation , Laurent Trinques
Update *TS file and generate new Slovakia ts file , Laurent Trinques
fixed syntax error in hungarian translation , artgg7300
Updated Danish translation , Ole Carlsen
Updated hungarian translate , artgg7300
updated hungarian translation , artgg7300
Update qet_fr.ts , tititiou36
Update EN translation , Laurent Trinques
Update turkish translation, add forget qml files thanks Emir , Laurent Trinques
Update turkish translation, thanks Emir , Laurent Trinques
Update Hungarian translations, thanks Gabor , Laurent Trinques
Dansih translation updated , Ole Carlsen
Update TS files , Laurent Trinques
Update hungarian translation, thanks Gábor , Laurent Trinques
Danish translation updated, latest update apparently went wrong. , Ole Carlsen
Add EN and FR translations , Laurent Trinques
