Topic: code no longer compiles for Qt5.15
no longer compiles from
commit ec5203253223ace22ca194b6abbe9f56f4bac76c
commit 8c6b4120f55a8f4d4916c517478413ab6cf74fd8 works
does it work for the other Qt versions?
QElectroTech → Code → code no longer compiles for Qt5.15
Tried to Merge https://github.com/qelectrotech/qelectr … or/pull/48 Martin pull request.
Building in Debug mode build , but failing in Release Mode build..
what are the settings for Debug mode build for you?
Debug mode does not work for me.
I just use qtcreator compile switch to pass in release or debug mode..
Maybe you could use make release or make debug.
https://launchpadlibrarian.net/48419501 … ING.txt.gz
Fixed build for Ubuntu 18.04 LTS https://git.tuxfamily.org/qet/qet.git/c … b4cb99ac39
my os "openSUSE Tumbleweed" is giving problems...
Project ERROR: Unknown module(s) in QT: KWidgetsAddons KCoreAddons
qmake don't find the dir of KWidgetsAddons KCoreAddons.
Maybe you can install KWidgetsAddons KCoreAddons devel packages?
I screwed up the zoom function
see 71abaf92cb81aeb832caac2372da2d60944f64b9
Same here, I reverted it 's break mouse wheelEvent in
https://git.tuxfamily.org/qet/qet.git/c … 22f9d3a2f2
Generated in 0.039 seconds (16% PHP - 84% DB) with 11 queries
