Topic: Add a nomenclature - translations
Hello
How can i change or add translations in nomenclature option window? Now i have polish and french texts.
https://ibb.co/4NVBDWM
Re: Add a nomenclature - translations
maybe you can help Pawel to finish translation.
Depending how you have installed QET and your OS, go to QET lang folder open qet_pl.ts with qtlinguist, translate, save and publish this make new binary qet_pl.qm.
Put this file on your QET lang folder and launch program again.
https://qelectrotech.org/wiki_new/doc/translation
s/Subversion/GIT/
Ok, i will try to help. I see that some of translations are already done, the only thing to do is mark them as done.
https://github.com/qelectrotech/qelectr … /qet_pl.ts
I made some translations. Also i found bug in nomenclature table headers. When i add folio number header, table show "folio" text instead of "Folio number" or any translations.
https://ibb.co/DVmDQv2
Merged, thanks Rafal.
Maybe delete this key, isn't usefull I think:
https://github.com/qelectrotech/qelectr … e.cpp#L282
--- sources/dataBase/projectdatabase.cpp
+++ sources/dataBase/projectdatabase.cpp
@@ -279,7 +279,6 @@ void projectDataBase::createElementNomenclatureView()
                          "e.type AS element_type,"
                          "e.sub_type AS element_sub_type,"
                          "di.title AS title,"
-                         "di.folio AS folio,"
                          "e.pos AS position "
                          " FROM element_info ei, diagram_info di, element e, diagram d"
                          " WHERE ei.element_uuid = e.uuid AND e.diagram_uuid = d.uuid AND di.diagram_uuid = d.uuid");
But break previous tables created...
Yesterday it was translatable, i checked it, but today i made QET update to newest version (2020-05-24-2) and it stopped working. Interesting thing is that, when i make update in content,  for eaxample disable terminal blocks, headers start to work properly.
https://www.youtube.com/watch?v=cJqi4bu … e=youtu.be
Thanks for your video, that can be help us.
