Topic: Impossible to scroll page tabs (left-right) on Mac and how to compile
I am using QElectroTech V 0.70-RC1 r5859 on my Mac (10.13.6) and I can't see left and right arrows to scroll page tabs.
At the top-right of the window there is the "add page" button only.
In Linux version, arrows are visible and working.
Giovanni
Re: Impossible to scroll page tabs (left-right) on Mac and how to compile
Hi Giovanni,
yes,it not appear on macOS, but you could use page up page down key, and enable touchpad gestures on config.
Thank you scorpio810.
I am using an iMac, and there is not touchpad.
Using page up-down it works. It changes the page shown.
But since the tabs don't scroll and those on the rightmost side are hidden, I can't see the number of page the where I am working to.
I switched off my Apple wireless mouse and I attached a standard generic USB mouse.
When the pointer is on the page the scroll wheel acts as zoom.
When the pointer in on the tabs nothing happens (neither with Alt, control CMD keys).
Is there anyone else running QET on Mac?
In version "qelectrotech 0.80-DEV r6006" for Mac as in previuous release it is also not visible the "add page" button on the right side of the bar.
Resizing the side window, the button appears, but it is still impossible scroll page tabs.
It is pretty impossible to work with documents with 15 pages or more.
Regards
Giovanni
Seem's like this :
https://forum.qt.io/topic/94574/how-to- … -for-mac/5
Maybe add for macOS  style ("macintosh, or  fusion") in code.
https://doc.qt.io/qt-5/qtabbar.html
See : A truncated tab bar shown in the Fusion widget style.
Yes, it is my case.
Yes, Safari hasn't left-right arrows, but if I put the mouse over and scroll left-right, tabs scroll left-right.
So, referring to that link "It's not a bug it's a platform guideline", in my opinion, that is a guideline badly applied by QT, so it is a bug, sSince the behaviour is different from Safari and it does not do the job.
Firefox has arrows instead.
I attach screenshots of both browsers for reference.
(sorry but I had to split the message)
Regards
Giovanni
10 (edited by bgio 2019-08-27 19:45:06)
Attachment icon Safari tabs 2019-08-27 alle 19.16.49.jpg 31.32 kb, 446 downloads since 2019-08-27
11 (edited by bgio 2019-08-27 19:47:05)
(It's very hard to use this forum)
Attachment icon Firefox tabs 2019-08-27 alle 19.18.51.jpg 59.27 kb, 185 downloads since 2019-08-27
If you have Qt 5 installed or know a liitle C++/Qt you can try to add Fusion style for macOS in qetapp.cpp
Like this :
p, li { white-space: pre-wrap; }
    Autodetec Windows style
    @param Windows style
#if defined(Q_OS_WIN) && defined(Q_OS_WINCE)
            if ((QSysInfo::WindowsVersion >= QSysInfo::WV_VISTA
                && QSysInfo::WindowsVersion < QSysInfo::WV_NT_based))
                style = QLatin1String("WindowsVista");
            else if ((QSysInfo::WindowsVersion >= QSysInfo::WV_XP
                style = QLatin1String("WindowsXP");
            else
                style = QLatin1String("Windows"); // default styles for Windows
#endif
I could try it.
Have I to download QeT sources and modify/compile with QTcreator, right?
Sorry, it can't compile:
:-1: error: Unknown module(s) in QT: KWidgetsAddons KCoreAddons
I use https://github.com/KDE-mac/homebrew-kde for  KWidgetsAddons KCoreAddons libs.
/usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
brew tap kde-mac/kde
brew install kde-mac/kde/kf5-karchive
brew install kde-mac/kde/kf5-kwidgetsaddons
brew install kde-mac/kde/kf5-kcoreaddons
  Unfortunately, we have no one who is familiar with the macos environment as well as C ++ / Qt to help us improve the software on this platform.
We do what we can with our Linux virtual machines. and not time..nomicons/sad
No way.
I can't compile it. Aways the same error in QTcreator: Unknown module(s) in QT: KWidgetsAddons KCoreAddons
I have installed library by brew as you suggested and also read lots of web pages, but I have obtained nothing more than that error.
And the libraries installed by brew .dylib are on my disc.
I think it is a path issue with libs and headers.
How do you compile QeT? Do you use QtCreator and qmake?
If I remember well, I use Qt 5 framework libs provided by Brew and now only Command_Line_Tools_macOS_10.13_for_Xcode_10.1.dmg I compile it with qmake -spec macx-clang and make -j16
See MacQetDeploy.sh script on misc directory on GIT.
Look the full log issue here, that can help you :https://github.com/KDE-mac/homebrew-kde/issues/285
QTcreator: Unknown module(s) in QT: KWidgetsAddons KCoreAddons :
You can try to copy your libs KF5 *.pri  on /usr/local/opt/qt5/mkspecs/modules/  like :
cp /usr/local/opt/kf5-kwidgetsaddons/mkspecs/modules/qt_KWidgetsAddons.pri  /usr/local/opt/qt5/mkspecs/modules/
etc.
Thank you
You were almost there.
Ok to copy, and I have done, but also rename copied files:
mv qt_KWidgetsAddons.pri qt_lib_KWidgetsAddons.pri
mv qt_KCoreAddons.pri qt_lib_KCoreAddons.pri
Now, running MacQetDeploy.sh script, it is compiling, or at least it is doing something,
Compile finished without error?
If ok, you have the bunde dmg located in packaging/mac-osx/ directory.
MacQetDeploy.sh on GIT is not up to date (it is still based on the old SVN trunk). I have not yet pushed the new adaptation for GIT.
Compile works, but I had to make a mac-osx folder since the script doesn't create any.
There are some errors at the end, syntax errors in the script, but at the moment I don't care since the application is build and working. So the script is working.
But there are many problems on inserting the chnage of style in the code.
If I run QeT from console using:
 ./qelectrotech -style fusion
It run in fusion-style and the tab-bar has arrows and tabs scroll left and right using keyboard arrows too (not with mouse scroll)
But when I try to insert a change of style in the code I obtain only errors.
Firstly I write:
 style = QLatin1String("Fusion");
but "style" results undefined (maybe is it defined in some Windows related include?)
Then I write:
 qApp::setStyle(QStyleFactory::create(QLatin1String("Fusion")));
but it also give me errors
I have already tried that and now I retried.
sources/qetapp.cpp:1236:4: error: C++ requires a type specifier for all declarations
1 warning and 1 error generated.
make: *** [release/qetapp.o] Error 1
make: *** Waiting for unfinished jobs....
A question: the Windows related lines that you have suggested (   #if defined(Q_OS_WIN) && defined(Q_OS_WINCE   ... and below), are working?
Fixed ! https://git.tuxfamily.org/qet/qet.git/c … ed69f515de
Try new dmg bundle qelectrotech-0.80-DEV_r6007.dmg
Strange that Qt did not apply himself the style defined on this platform by Qt upstream.
Thank you.
The program in the new bundle works well.
What have you done to fix it?
