1 (edited by elDrawer 2019-03-19 15:41:11)
Topic: pdf printer
hi gentlemen,
i've a question for a default pdf printer
i try to find a command to change a print margins...
es. i need to put 20mm for a top margins beacose we use a preholed paper...but i can't move down a page from a top margins....where i'm wrong to do? or dosn't have a possible to set?
2 (edited by Calypso 2019-03-19 18:35:07)
Re: pdf printer
Hello elDrawer,
in the menu, click on File, then on Print and select PDF. In the print menu you will find a page layout option. There you can set the margins for the PDF.
Yours sincerely
Stebo
3 (edited by elDrawer 2019-03-20 12:49:48)
Re: pdf printer
ok, thanks but when i use a "print on file PDF" i can't set a margins.
i can only if i use a "print on paper" and after set  a one pdf printer on my computer
Re: pdf printer
Yes you can!
"Stampa su un file PDF", then OK and then you come to the dialog displayed in the screenshot of Calypso.
And then click on the button shown by Calypso, a dialog opens where you can set the margins.
5 (edited by elDrawer 2019-03-20 14:33:35)
Re: pdf printer
sorry but no, i can't...
i've do it but when i click on it dosn't open a setting page.....
6 (edited by elDrawer 2019-03-20 14:44:25)
Re: pdf printer
use a 0.7 dev 5803. my system windows 10 64bit...
but also a previous versions have the same problem....
Re: pdf printer
Windows?
Use "stampa su carta" function and choose "Microsoft Print to PDF" printer like this :
https://download.qelectrotech.org/qet/forum_img/win_pdf_printer.png
8 (edited by elDrawer 2019-03-21 10:01:42)
Re: pdf printer
yes, i use it...but my question are.....
why if i have a option "print of file pdf" i can't use beacose isn't possible to set a margins nomicons/blink
Re: pdf printer
Note, however, a limitation for Windows PDF / PS printing: the Page Setup dialog, which allows you to specify the paper size and margins, is not available.
Edit :
And for fix HiDPi print render on Windows if I remember :
see commit rev 5242
