Topic: Conductor's label blocked
sources/qetgraphicsitem/conductor.cpp
À la ligne 884
 * @brief Conductor::nearShape
 * @return : An area in which it is considered a point is near this conductor.
QPainterPath Conductor::nearShape() const
    QPainterPathStroker pps;
    pps.setWidth(120);   nomicons/devil
    pps.setJoinStyle(conductor_pen.joinStyle());
    return pps.createStroke(path());
En augmentant la valeur de QPainterPathStroker setWidth , l’étiquette du conductor peut être déplacée davantage.
Dans le fichier sources/qetgraphicsitem/conductor.cpp
À la ligne 891 ; pps.setWidth(120);
à  ; pps.setWidth(1300);    nomicons/smile
By increasing the value of QPainterPathStroker setWidth, the conductor label can be moved further.
In the file sources/qetgraphicsitem/conductor.cpp
At line 891; pps.setWidth(120);
to pps.setWidth(1300); nomicons/smile
Erik
I am an pre-retired industrial developer technician and born in 1960.Electrical, Electronics, Mechanical,Électricité, électronique, mécanique,Native language(Dutch)/langue maternelle/moedertaal(BE,NL).OS : Linux/GNU Debian Forky/Sid and Trixie; Qt 5 and 6; Compiler :  qmake(Qt5) qmake6(Qt6)
Re: Conductor's label blocked
Added, thanks.
Revision: 5617
Author: scorpio810
Date: 2018-11-29 10:42:23 +0100 (Thu, 29 Nov 2018)
Log Message:
Big increase the value of QPainterPathStroker for very very long text, thanks
re-searcher
FYI, new packages is on the road.
