Topic: Entête de colonne export nomenclature et intitulé champs qet
il y a une incohérence entre les intitulés des champs information des éléments et l'entête des colonnes de l'export  de la nomenclature.
Soit re-dis en passant, je préfère largement les intitulés de l'export que ceux de l'interface de saisie ... Je ne comprend toujours pas lequel sert à quoi ... Je galère pour généré la nomenclature.
Cordialement.
Re: Entête de colonne export nomenclature et intitulé champs qet
//Process...
    QString data = QObject::tr("NOMENCLATURE : ") + m_project -> title() + "\n\n";
data += QObject::tr("A001") +";" //:Don't translate this text! //ID for folio number
""+ QObject::tr("B001") +";" //:Don't translate this text! //ID for folio title
""+ QObject::tr("C001") +";" //:Don't translate this text! //ID for folio label
""+ QObject::tr("D001") +";" //:Don't translate this text! //ID for qet designation
""+ QObject::tr("E001") +";" //:Don't translate this text! //ID for position of element on the folio
""+ QObject::tr("F001") +";" //:Don't translate this text! //ID for label of element
""+ QObject::tr("G001") +";" //:Don't translate this text! //ID for order number
""+ QObject::tr("H001") +";" //:Don't translate this text! //ID for article description
""+ QObject::tr("I001") +";" //:Don't translate this text! //ID for comment
""+ QObject::tr("J001") +";" //:Don't translate this text! //ID for manufacturer
""+ QObject::tr("K001") +";" //:Don't translate this text! //ID for article number
""+ QObject::tr("L001") +";" //:Don't translate this text! //ID for supplier
""+ QObject::tr("M001") +";" //:Don't translate this text! //ID for auxiliary field 1
""+ QObject::tr("M002") +";" //:Don't translate this text! //ID for auciliary field 2
""+ QObject::tr("N001")+";" //:Don't translate this text! //ID for internal number
""+ QObject::tr("O001")+";" //:Don't translate this text! //ID for location
""+ QObject::tr("P001") +"\n"; //:Don't translate this text! //ID for function
data += QObject::tr("N° de folio") +";"
    ""+ QObject::tr("Titre de folio") +";"
    ""+ QObject::tr("Label de folio") +";"
    ""+ QObject::tr("Désignation qet") +";"
    ""+ QObject::tr("Position") +";"
    ""+ QObject::tr("Label") +";"
    ""+ QObject::tr("Désignation") +";"
    ""+ QObject::tr("Description") +";"
    ""+ QObject::tr("Commentaire") +";"
    ""+ QObject::tr("Fabricant") +";"
    ""+ QObject::tr("Reference Fabricant") +";"
    ""+ QObject::tr("Fournisseur") +";"
    ""+ QObject::tr("Bloc auxiliaire 1") +";"
    ""+ QObject::tr("Bloc auxiliaire 2") +";"
    ""+ QObject::tr("Machine-reference") +";"
    ""+ QObject::tr("Localisation") +";"
    ""+ QObject::tr("Fonction") +"\n";
Bien joli ton code ... nomicons/happy
Joli ou pas ... ça devrait t'aider a comprendre, non? nomicons/w00t
 nomicons/smiley-green
Pas du tout, je ne me fait pas comprendre:
6
https://download.qelectrotech.org/qet/forum_img/nomenclature_galexis.png
7
Du coup , c'est pas possible de corriger ces incohérences d'intitulés en colonne G et K ?
8
Galexis a raison, c'est incohérent.
Il faut que les intitulés des champs de saisie du widget de l'élément correspondent à la virgule près aux intitulés des colonnes de la nomenclature csv, sinon...
...Bonjour les pendaisons d'utilisateurs !
9 (edited by Joshua 2019-11-05 20:17:47)
Ba pour le coup, on peut oublier tout ça, car obsolète depuis mon dernier commit.
En revanche si il existe toujours des incohérences avec le nouveau générateur, il faudra remonté ça dans le topic https://qelectrotech.org/forum/viewtopic.php?id=1521 (galexis à déjà commencé).
