Topic: Conductor's label blocked
Hi
Sometimes happen that conductor's label is getting blocked and I can not move it freely (look at the pic attached). I was triying to move the yellow label to the left but the program does not allow me. Moreover other labels I had problems to move them freely up and down. Is there a way to solve it?
Thanks!
Re: Conductor's label blocked
the movement of a conductor's label is limited in the code.
3 (edited by leenk10 2017-10-18 13:31:50)
So there is no way to solve this, isn't it?
Of course we can increase the limit value in the code.
But, not time this days to found this line code in this big program.
5 (edited by Calypso 2017-10-18 16:15:15)
Hello leenk10
you can copy the conductortext into the field Function or Voltage / protocol.
The texts function or voltage / protocol you can move larger.
Best regards
Stebo
EDIT: The texts for function or voltage / protocoll must be assigned to the element for slide references in the editor because they are not present in the standard symbol.
Attachment icon Bildschirmfoto 2017-10-18 15:33:08.png 42.73 kb, 387 downloads since 2017-10-18
Like this :
Merci guys!!!! nomicons/wink
I am still having problems to fit the label in the sheet, could you fix this issue?
Thanks in advance for this and for this great software!
Hello,
Have found the solution after a long time.
See Forum Progamming Code
Erik
10 (edited by McCormick 2018-11-29 00:33:26)
@McCormick
Your answer has happened too quickly.
The changes still have to be made by scorpio810(Laurent) or Joshua.
Have the source file retrieved from svn.
The changes made.
Compiles the program.
This is the result.
