Topic: Terminal Block creation Plugin don't work
Hi.
I have Windows 7 Pro, Python 3.6 32 Bit, And Qelectrotec 0.60 RC2.
I tried to create the trerminal block following your Video "Terminal Block generator1".
When I click on Launch terminal block creation plugin I need to select the open drawing called "Test" after that I click on " Create terminal Block".
At this point, Python crash.
Where is the problem?
I must download also QT 5?
21
Re: Terminal Block creation Plugin don't work
Plugin installed like this, and upgraded to latest version?
https://qelectrotech.org/forum/viewtopi … 6515#p6515
No need to install Qt5 framework for use plugin.
Yes.
100
102
It's working now, or python crash again?
Hi.
Python crash again
you could send your project?
7
Hi
This is the link with my stupid project nomicons/smile
https://drive.google.com/open?id=0ByFuk … 3l2YlFYUXc
Thanks for help
35
8
I don't understand where is the problem.
https://drive.google.com/open?id=0ByFuk … 1dBaVV5Wkk
146
10
Try to launch qet_tb_generator on python program in the CMD terminal, and see if report a error?
What the number you put at the end of your posting messages, can you explain? nomicons/smile
11 (edited by galexis 2017-07-09 11:27:45)
Generator doesn't work for me too...
Crash after click on generate. No terminals are generated.
12
@Galexis :  it crash on Win 10 only?
13
No on LM18.1 ...
14 (edited by FR 2017-07-10 08:51:00)
Hi.
I tried to execute qet_tb_generator.exe directly.
I can select the file but when I click on "create terminal blocks" , this is the results.
I don't know what is the number. Every time that I finish to write a message, I see a number. nomicons/smile
36
15
Have you update script ?
https://qelectrotech.org/forum/viewtopi … 6786#p6786
16
Yes. I have the last version.
17
@FR : script qet_tb_generator run better now?
18
I think it is better now, but attached you can find the results nomicons/sad
I can post also the qet sheet.
qet is in C:\qelectrotech\ folder
project are in C:\qelectrotech\progetti\ folder
terminal stripare generated in C:/qelectrotech/conf/elements/auto_terminal_strip\
19
The problem is: you haven't change label of folio. On your project label is: "%id/%total". If you change it by "1" or what you want: it work.
20 (edited by galexis 2017-07-26 14:34:25)
To have good label of terminal "X1", when you put element of project, select no autonum for element.
21
Very Good.
Everything is ok.
I must remember to set the sheet number in manual.
Can I use a different symbol to indicate the terminal strip? In my drawing I use TB as Terminal Board.
22 (edited by galexis 2017-07-26 16:28:33)
I don't know if I answer about your question...
Name of terminal must be like that :
- first: name or label of terminal assembly X, 01X1, XC, TB1, TBX, ...
- separator: ":"
- number of terminal : 1, U1, L1, ....
23
Thank you galexis.
I will start to use this software.
I start to create some component that are missing in my version of qet like Siemens 1500 or some Pilz security relay.
Is it possible to send to qet this component or create a library available for all?
Best regards
24 (edited by galexis 2017-07-26 17:25:52)
FR wrote:
Thank you galexis.
Best regards
Yes of course ! There is a special section on this forum, wherre you post your elements : https://qelectrotech.org/forum/viewforum.php?id=10
or on the top of web site you have a link : https://qelectrotech.org/submit-element.php
25
@Scorpio810
Is it possible to include terminal generator and necessary like python on ReadyToUse version of qet ?
