Topic: Manage terminals
i using QE since a few weeks. It is very usefull for me to draw circuit diagramms from my house-automation and some drawings of the plant and machines from my best friend who have a small metallworking company.
first question: is there an option to manage the terminals more comfortable? It is in my opinion very cumbersome to label and arrange terminals. My idea goes to an export/import option or to a direct editing method via popup-window.
second question: is there an option for direct labeling the connection from contacts (13-14, 23-24 for N.O, 11-12 for N.C) ? How can i transfer the labels of the contacts to the contact-table which is near the coil placed?
Many thanks for great work
Best regardings from Bavaria/Germany
erga
2 (edited by Nuri 2017-01-06 11:05:19)
Re: Manage terminals
hello Erga,
at the moment there is no convenient way to easier manage terminals. This will be surely made in a further version of QET (0.6 or 0.7...).
To your second question:
I have created some NO and NC contacts where the user can directly edit the terminal descriptions (13:14, 11:12...).
Look at the attached files.
You can not "transfer" the descriptions (13:14...) in the contact mirror (Kontaktspiegel) near the coil. Unfortunately, this is not possible at the moment.
Attachment icon auxiliary_contacts_with_cross_ref_functionality.zip 2.5 kb, 552 downloads since 2017-01-06
Hello piceaabis
The terminal numbers of symbols can only be entered or changed in the drawing.
I believe a direct transfer of the terminal numbers of contacts into the contact table is not possible. You can create your own icons for a contact mirror with reference.
Best regards
Stebo
thank you for answers
@Calypso: How to create my own contact mirror, have you some short information?
Best regards
piceaabies
5 (edited by Calypso 2017-01-06 19:43:30)
Hello
First you create an element for the contact mirror (contact NO), insert a label and as a component property incoming filing reference.
For the contact in the plan you create an element add a label and as a component property outgoing foil reference. In the plan, you can use them as references from conductors.
I'm trying to make a screen photo. The video is too big
Best regards
Stebo
Edit: The relay coil has no relationship with the contacts. Only the references are connected to the elements
Calypso wrote:
Hello
Best regards
Stebo
I can't create a component as incoming/outgoing foil reference without having a connection in the component. See attached screenshot. Is this right?
Best regards
piceaabies
7 (edited by Calypso 2017-01-06 22:04:10)
Hello
The element needs a terminal that is the red bars. The terminal is only an insertion point for this element to store it
Best regards
Stebo
@Calypso : if you create a video for helping Piceaabies, you could send me this by email, I could put this on download area and add a link for viewing it on the forum.
I limit your upload size because my quota on this web server is very limited, I have more space on download server.
9 (edited by Calypso 2017-01-06 22:19:29)
Hello
OK the video is now small enough
Hello
If the video is too big then you can move or link it?
Best regards
Stebo
Calypso wrote:
Hello
Thank you,
video is very usefull. Everything fine!
Best regards
piceaabies
