76 (edited by unalcalde 2016-08-29 12:09:00)
Re: Terminal block generator cross-platform
I think the installation path is the same that for the rest of python installation (under python scripts directory).
I tried on a windows clean installation and recognizes the 'qet_tb_generator' command.
Today I'll try on a clean linux installation
You could add in config page number/page ID.
https://download.qelectrotech.org/qet/forum_img/win_pip.png
Yes, download 89 Mo just for little script ....
79 (edited by unalcalde 2016-08-29 22:52:40)
Hi, there are new version. Current version is 0.5.3. Fixes save  page number/id in config.
I tested hoy to install / updates on fresh Windows 7 and Lubuntu 16.04. To run the program in boths systems type "qet_tb_generator" at command line.
Requires python 3.5 or above.
>> First install on Linux
1. check you have pip3 installed: pip3 --version.
   If not install with: sudo apt-get install python3-pip
2. Install the program: sudo pip3 install qet_tb_generator
3. Run the program: qet_tb_generator
>> Update on Linux
sudo pip3 install --upgrade qet_tb_generator
>> First install on Windows
2. pip install qet_generator
>> Update on Windows
scorpio810, I you test and work for you like me, you can consider to add an entry menu to launch this script.
The menu entry migth only appears if "qet_tb_generator" is installed. To check that could be interesting that my script answers something like:
    qet_tb_generator -v
    0.5.3
If exists an answer, you can show the menu entry to launch the script. If you need some change say me.
Thank you Unalcalde.
I think I can add a new action in QET for run qet_tb_generator, like a plugin.
I will look to add this new entry, but not tonight, I just arrive to my home and I'm too tired, holidays is finish for me .. nomicons/sad
nomicons/wink I'm too, my holidays finished.
Run qet_tb_generator is not easy and no time, but I tried to install qet_tb_generator directly in QET, now work on Gnu/Linux :
Unalcalde if you can help me for run this script :
http://stackoverflow.com/questions/1918 … hon-script
84 (edited by unalcalde 2016-08-30 18:55:01)
Ok, I'll try.
You are using qet_tb_generator 0.50, the last one is 0.53 (on window caption appears). You can update with: sudo pip3 install --upgrade qet_tb_generator
In the diff file, you are assuming that python 3.5 is intalled and QET is executing on linx. If you want I try to fix, but maybe is easy a menu command that launch the qet_tb_generator if it's installed.
If it's not intalled,  migth appears a msg indicating how to do, and a link to https://pypi.python.org/pypi/qet-tb-generator/
In next versions of QET, the menu entry remain, but it will launch the internal borne generator instead  of qet_tb_generator.
In the same time : it's not possible to had button to run dxftoelmt ?
87 (edited by unalcalde 2016-08-30 21:30:29)
Hi. This works.
The menu entry might be something like: "Launch plugin ..."
The text of message box something like:
>> Update on Linux
>> Update on Windows
CODE
* @brief QETDiagramEditor::slot_generateTerminalBlock
void QETDiagramEditor::slot_generateTerminalBlock() {
bool success;
QProcess *process = new QProcess(qApp);
// If launched under control:
//connect(process, SIGNAL(errorOcurred(int error)), this, SLOT(slot_generateTerminalBlock_error()));
//process->start("qet_tb_generator");
success = process->startDetached("qet_tb_generator");
if ( !success ) {
QMessageBox::warning(0,
"Error launching plugin",
"To install the plugin blah blah\nVisit https://pypi.python.org/pypi/qet-tb-generator/" );
Six month after, and you don't see this. nomicons/grin
https://qelectrotech.org/forum/viewtopi … 4532#p4532
https://qelectrotech.org/forum/viewtopi … 4533#p4533
Revision: 4676
Author:   scorpio810
Date:     2016-08-30 23:42:35 +0200 (Tue, 30 Aug 2016)
Log Message:
Added new entry for launch plugin qet_tb_generator, thanks Raul
So fast !nomicons/grin
I understand why my tests don't work :
If I run QET with Qt creator plugin don't run and in Qt creator console I saw this warning :
This application failed to start because it could not find or load the Qt platform plugin "xcb" etc...and now I see if I run directly binary compiled in source is work well , Strange ..
And I complicate my life wanting to run a shell with python3 command to launch plugin in QET entry ...
Thank you so much Unalcalde.
I tried on VM Windows, and Debian packages too, plugin work fine, nice.nomicons/smile
unalcalde wrote:
Ok, I'll try.
I understand now my mistake, in first I have installed plugin without sudo and forget this install and not upgraded this version.. nomicons/blush
For me I think which is better to install python environment for plugin in user in .local directory instead in /usr/local/lib/python3.5/ for Gnu/Linux users.
Perfect !!
By now it's enough. In about 6 months I'll can dedicate more time.
If there are some bug in qet_tb_generator say me.
The destination place of a pip3 installation is by default for all users. If you want to install for current user, you could write : pip3 install --local <package_name>
galexis wrote:
unalcalde wrote:
I didn't install any more packages. My primary os is xubuntu and I tried on a virtual machine with Lubuntu.
I'll continue trying to create a portable version for all os.
Ok, it's work. pyqt5-dev-tools installed python-pyqt5 (not python3-pyqt5).
Ok, added pyqt5-dev-tools to Recommends in Debian packages.
unalcalde wrote:
Perfect !!
Ask me, when you want to join the team.
I can guide you for subscribe, subversion, etc.
unalcalde wrote:
Perfect !!
nomicons/grin
Revision: 4676
Author:   scorpio810
Log Message:
All work fine on LM18 : good job !
99 (edited by galexis 2016-09-01 21:04:37)
Now, where is stored python code on linux version ?
whereis qet_tb_generator
