Topic: elements linked
I have made a new linked type file
it has a new type called EMPTY
as i see always a symbol at the master like a NO NC Power etc, i only need the reference.
so on the kindinformation i have changed the name NO to EMPTY, now yet i do not see the reference but that is because in software there is no icon called EMPTY
LAURENT
could you please add it to the software and replace the elements in the directory with the rar file included.
If this works i can make any type of reference, first subject will be terminal strips.
greetings polleke
paul deelen
shooter@home.nl
Re: elements linked
To do automatic terminal: it's perfect ! I'search that from few month !
Re: elements linked
It's not better ... Xref is not at the good place....
Re: elements linked
galexis please send the complete drawing as i need to know what elements are used? most probably you use the master slave, but that is not implemented yet. with renvoi it is possible.
as these texts stay on where you put them.
i will make you an example tomorrow.
paul deelen
shooter@home.nl
Re: elements linked
hi Paul,
Sorry i'm very busy (port Qt5, packaging, etc..),
you suggest that i replace /elements/10_electric/98_graphics/01_auxiliary_symbols/01_cross_ref_symbols/01_with_linking_function/*
 by your element archive?
6
Re: elements linked
The project ...
7
Re: elements linked
Yes, I try slave/master fonction, the problem is : with slave/master, Xref is not at the good place.
With renvoi fonction : no label auto.
8
Re: elements linked
in master slave like you did the position of the xref is dependant of the tagg label.
So we have to ask development to have this position set in another textfield with a taggname XREF, this would be a better option , as we can set the xref wherever we want it. (not at pagebottom but that is covered in software already)
In this same thing i would like to have we can choose what icon will be at master like a NO, NC, Power, EMPTY, safety, so this will need another directory with entries (a bit like references is now)
I will make an example on this for laurent and others ( as it is in line with these references i am making)
paul deelen
shooter@home.nl
9
Re: elements linked
Hi Shooter,
i remove your elements with linking function in official collection, i think isn't useful now.
But i moved these files to
http://qelectrotech.org/showcategory.ph … ry_symbols
10
Re: elements linked
Hi Shooter,
Reintegrated now (solved program segfault with these elements) .
