1 (edited by c.hogg 2025-09-04 13:09:52)
Topic: New custom element
I have just created a new element and saved it.  I can place the element in the drawing , but after that I can not move it or edit it.  I can connect wires to it.
If I try to open it in the editor I just get a blank screen.  I have had a look at the element in a text editor and can not see anything obviously incorrect.
Does anyone have a solution for this so I can recover the element or does it have to be deleted and recreated.
Hi Scorpio810,
I started with ver. 0.9 and have now tried ver. 0.100-dev.  The only difference I can see is when placing a connection as mentioned below.
Please find attached the following;
"5axisbreakout.elmt", the element itself.
"Placing element", is the screen shot of me dragging the element on to the page.  the echo occurs after it has been placed.
"Element placed", is the screen shot after I de-select the element and move the page to refresh it.
"Making connection", is the screen shot of a connection being made.  In ver. 0.9 the image was not lost.
"Screen refresh", is a screen shot of the connection after refreshing the page with a mouse movement.
"Element editor", is a screen shot when I right click the element and select edit.  This is the only way I can get to the editor as the element can not be selected once it is placed.
Hope this helps
C.
Element editor.png, 69.53 kb, 1919 x 1080
Element placed.png, 147.94 kb, 1920 x 1080
Making connection.png, 159.32 kb, 1919 x 1077
Placing element.png, 171.37 kb, 1919 x 1077
Screen refresh.png, 156.31 kb, 1919 x 1077
Re: New custom element
Can you share your element?, just edit your previous post and share it.
BTW, what version of QET are you using it, I hope 0.100-dev, because  0.90 was very old now and can produce many crashes was  fixed since a long time in master branch alka 0100-dev..
Maybe right click on collection tree panel -> reload collection can solve your issue?
Please share more pictures for your problem.
It's a very rare case but it happend to me about 3-4 years ago in my experience...
Analyzing your elmt :
- Value position contain like 2.95
- Value position contain nan
Why that can be happend :
- Transforming (Moving/Rotating) multiple different object (shape|text|terminal) in the same time (together)
- CopyPasting multiple different object (shape|text|terminal) in the same time (together)
- Initiating a new blank element at first by copypasting multiple different object from another element
- Moving/dragging multiple different object all almost done by mouse
How to avoid :
- Transforming and CopyPasting multiple different object(shape|text|terminal) separately
- Often to check value position like 2.00 is stable | 2.10 is oke | 2.11 is danger
- If you find an object but value position like 1e72324 fix it immediatly and dont copypaste from it and create similar in a new one
- Using arrow keys and change value box
How to resolve (Notepad) :
- change value like 2.95 to 3
- change value nan to any digit
How to resolve (QET Element Editor)
- After fixed it by notepad, open it in QET Element Editor and edit your element
OR
- Even it is fixed successfully, i suggest you strongly build a new one similar and dont copypaste
from your fixed element (personally it can be a nightmare for me)
Quick Tips :
-Build all shapes at first
-Add all texts after
-Add all terminals at last
hope this helps
use QET_ElementScaler to fix the problem with your Element-File:
From whatever reason two lines have no (first) point.
Hello, I'm using QET and till now I could have all I want. The from/to labels I got a Python Script that doesn't work with master/slave elements, but i get a shortcut and config to Simple elements.
But about EDITING NAME AND INFORMATION OF THE ELEMENT, in the ''Edit Element'' window, it seems after some elements name change, I cannot do it anymore.
Today a unisntall QET and re-install it so I got fonctionnel till now, when I edit the Name, I add + a line, but it can't be saved.
If I edit only the name, i cannot even SAVE (only SAVE AS).
Someone have the same bug?
Thank you for all you're doing nomicons/smile
Could you tell us:
which QElectroTech version you use (Help → About QElectroTech);
where the element is: QET collection, company collection or user collection;
whether the editor’s title bar shows “[Read only]”;
the exact message you get when Save fails, with a screenshot of the Edit Element window;
and attach the .elmt file of one element that no longer saves.
Two things to check meanwhile. An element of the QET collection, or a .elmt file marked read-only, can only be saved with “Save As”: if your Python script renames or rewrites the files, check that it does not leave them read-only, and keep your own elements in the user collection. And if the message is “the conditions are not valid”, the element failed the check done at saving, for example two terminals with the same name.
Regards, Laurent
