Re: Discussion sur le générateur de borniers.
Terminal strip: save the layout (font, cell sizes...) in the project
The default terminal strip layout was rebuilt at every project load,
so the font size set in the layout editor was reset to 15 px.
Add TerminalStripLayoutPattern::toXml/fromXml and
TerminalStripLayoutsHandler::toXml/fromXml, write a
<terminal_strip_layout> element in QETProject::toXml() and read it
before the diagrams are loaded. Projects without it keep the defaults.
https://github.com/qelectrotech/qelectr … b245b7b84b
Terminal strip: add an anti-parallel diodes terminal type
Add ElementData::TTAntiParallelDiodes (xml value "antiparallel_diodes"),
selectable in the element editor, the terminal strip editor and the free
terminal editor, and drawn in the terminal strip plan as two diodes wired
in opposite directions between the top and the bottom of the terminal.
https://github.com/qelectrotech/qelectr … 81913583c7
Terminal strip: remove the circles at the end of connections and wires
Draw the top/bottom connections of the terminals and the wires under
the cable as plain lines, without the small circle at their end.
https://github.com/qelectrotech/qelectr … f32b318f05
Terminal strip: add resistor, varistor, test socket and reversed diode types
Add ElementData::TTResistor, TTVaristor, TTTestSocket and TTDiodeReversed
(xml values "resistor", "varistor", "test_socket", "diode_reversed"),
terminal editor, and drawn in the terminal strip plan.
https://github.com/qelectrotech/qelectr … d2a4733058
