Topic: Subject: Folder/Category system for organizing sheets
Hello everyone,
I'd like to discuss a feature idea for organizing sheets in larger projects.
Current situation: In big projects with many sheets, the list becomes long and hard to navigate. All sheets are shown in a flat list.
Proposed feature:
Create folders/categories to group sheets (e.g., "General", "Power", "Control")
Organize sheets in a tree structure in the left panel
Move sheets between folders via drag & drop or right-click menu
Each sheet gets a "category" attribute in the .qet file
Table of contents can show which category a sheet belongs to
Additional ideas:
Folders can have default properties (titleblock, border) for new sheets created inside
When creating new sheets (via menu, right-click, or from table of contents), they go into the selected folder
Copy/paste sheets between different folders
Backward compatible: old files without categories still work
Questions for discussion:
Is this something the project wants/needs?
Any suggestions for the implementation approach?
Should categories be visible in the tab bar (e.g., "Power\Sheet 1")?
Looking forward to your feedback!
Re: Subject: Folder/Category system for organizing sheets
Doesn't anyone see the value in this feature? Personally, I think it would be great. But there's no point if I put a ton of work into it and it doesn't end up being included in the program.
Even a “no” would be helpful—then I can look into the next feature.
Hi Thomas, search on QET Github "IEC+8134"
https://github.com/qelectrotech/qelectr … ssions/613
https://github.com/search?q=repo%3Aqele … llrequests
https://github.com/search?q=repo%3Aqele … iscussions
4 (edited by Kellermorph 2026-08-18 07:24:24)
Maybe we're misunderstanding each other right now.
I mean something like what's shown in the picture—a tree structure that you can expand and collapse.
example.png, 33.35 kb, 1439 x 863
Hallo Kellermorph,
ich finde die Idee gut.
Die fehlenden Möglichkeiten zur Strukturierung von Projekten in QElectrotech machen das Zeichnen von modernen
Stromlaufplänen relativ schwierig oder sogar unmöglich.
Eine Baumstruktur wie in deinem Bild ist doch schon ein guter Anfang.
Mit welchen Regeln willst du eine solche Struktur aufbauen?
Eine Strukturierung nach „Allgemein“, „Leistungsteil“, „Steuerung“ wie du es in deinem ersten Post
erwähnt hast, kann man sicher machen. Auch sollte eine Strukturierung nach den aktuellen Normen (EN 81436, EN61355) möglich sein.
Am wichtigsten wird sein, das die Informationen aus dem Projekt (z.B. Anlagenkennzeichen, Ortskennzeichen) mit den Schaltplanseiten, dem Titelfeld und auch den Objekten im Schaltplan synchronisiert werden.
Ich habe jetzt auch keine Vorstellung wie man sowas umsetzt, aber wenn du regelmäßig deine Fortschritte teilst, kann man sich vielleicht zusammen an ein Ergebnis herantasten.
Hello Kellermorph,
I think it’s a good idea.
The lack of options for structuring projects in QElectrotech makes drawing modern
circuit diagrams relatively difficult or even impossible.
A tree structure like the one in your image is certainly a good start.
What rules do you intend to use to build such a structure?
Structuring by categories like "General," "Power Section," and "Control"—as you
mentioned in your first post—is certainly feasible. Structuring according to current
standards (EN 81436, EN 61355) should also be possible.
The most important thing will be ensuring that project information (e.g., system identifiers,
location codes) remains synchronized with the schematic pages, the title block,
and the objects within the schematic itself.
I don't have a clear idea of how to implement something like this either, but if you
share your progress regularly, perhaps we can work together to arrive at a solution.
Please use english in your messages, thanks !
My idea was that you could do this with up to two levels, as shown in the image. That said, even one level would be enough for me and would already be extremely helpful. Users should also be able to freely name the groups and, if needed, have those names displayed in the table of contents.
Of course, care must be taken to ensure that, for example, when a new bill of materials is created, it remains in the group in which it was created.
I used both, german and english!
