Topic: “qelectrotech.app” is damaged and can’t be opened. MacOS
I just did download the ARM version of qelectrotech (0.100.0 r8131).
Drop it in the application folder.
And....
“qelectrotech.app” is damaged and can’t be opened. You should move it to the Trash.
This file was downloaded on an unknown date.
If I leave it in the download folder and start it, it ask for access ( like always the first time ) and runs fine.
If I drop it in a subfolder of Application it doesn't run either.
Something wrong with a date?
Running Sonoma.
Re: “qelectrotech.app” is damaged and can’t be opened. MacOS
Maybe related to https://qelectrotech.org/bugtracker/view.php?id=290 ?
You used Safari for downloaded it?
3 (edited by rvamerongen 2024-08-20 16:24:40)
Doesn't matter with what kind of browser I did downloaded it; because it does works when outside the Applications folder, and I did download the M version.
B.t.w. The other, the intel version, gives the same result.
Did the previous version work for you? Maybe this issue comes from this commit?
https://github.com/qelectrotech/qelectr … b7361ad4b6
I can't tell anything about that, because I did jump from a few versions earlier to the latest version.
OK, so can I come back to this commit if the previous OSX arm64 application has already worked for you?
A previous arm64 did work, but I don't remember which version it was.
Ok, so I can revert this commit https://github.com/qelectrotech/qelectr … b7361ad4b6
I just downloaded the 20 of August version, and it has the same issue as in my opening post.
Directly in the Application folder it gives the App is damaged.
from the Download folder it works fine.
If I put it in another folder, like username/Applications/... and start it from there, then it works.
For now I use an Alias in the Apple Application folder then it works also ( of course ).
Side Note: I use Sonoma, maybe....
You don't have this issue?
Same like you,Sonoma too, and I don't have this issue... strange!
https://qelectrotech.org/forum/viewtopi … 829#p18829
Hi just downloaded the latest version today; the issue is still the case. Anyone?
Downloaded with Safari?
Yes, with Safari; but also with FireFox.
Same result. Same action required; placing the app inside my personal User application folder, then created a Alias to the system App folder and then it works.
Not knowing what application settings are set in your code editor, but is there a setting about Application targets? is it properly signed and notarized?
Did you use something like
xcrun altool --notarize-app --primary-bundle-id "org.qelectrotech.app" --username "your-apple-id" --password "your-app-specific-password" --file QElectroTech.dmg
14 (edited by rvamerongen 2025-02-24 21:09:27)
Issue with Version 0.100.0 r8390 on macOS ARM 14.7.2
I downloaded the latest version 0.100.0 r8390 for macOS ARM, but now the trick to create an alias to start and run it isn’t working anymore.
This issue has persisted for 8 months, and a neighbor is experiencing the same problem.
Does anyone with all the necessary compiler tools installed have success compiling it to make it work properly on macOS?
Hello rvamerongen,
please don't blame me, I do what I can, my scripts for mac Apple was on github and maybe improved by a specialist..
I have a shortcut on my desktop like aleas and it 's work well... FYI I stayed on the old Sonoma again.
Read on and you'll see that my work is no picnic...and or an pleasure...
https://qelectrotech.org/forum/viewtopi … 440#p17440
acolomb wrote:
Wow, this seems a major burden and a piece of work to support Apple.  Frankly, I would have stopped supporting the platform at all after all these troubles.  Not a big fan of the company anyway, but charging developers to allow users running their software is just... rude!  In the early computer days, some hardware vendors had a market advantage because they made it easy for software developers to write programs for their platform.  Somehow for a company of Apple's size, these economic mechanisms don't work anymore.  Except if people start sabotaging this madness and just stay away from Apple, especially those people putting in their volunteer work to publish open source software.
Enough ranting...  I didn't understand everything in this thread, unfortunately, since my French is very rudimentary. I'd be happy if more posts could stick to English language, as it's more accessible to the rest of the world ;-)
To be clear, if no one wants to help but just grumble, I'll stop making macOS packages, plus it costs me €100 out of my pocket every year.. just for signed and notarized.
Hello rvamerongen,
I have a shortcut on my desktop like aleas and it 's work well... FYI I stayed on the old sequoia again.
I don't blame anyone. I know nothing about qts. Just notifications, remarks and questions.
You wrote about github macos script. Can you show me where it is?
I will go back to the previous version or use the latest intel version.
Just curious why the intel version works fine and the Arm version not.
https://github.com/qelectrotech/qelectr … tDeploy.sh
https://github.com/qelectrotech/qelectr … y_arm64.sh
macOS ARM64 DMG Build & Notarization — Fixed Workflow
After a lot of trial and error, here is the working process to build, sign, notarize and distribute QElectroTech as a proper macOS DMG for Apple Silicon (arm64).
  • Problems encountered
    1. Gatekeeper blocking the app when downloaded via Chrome
    The original script used ditto --sequesterRsrc to create the final ZIP. This flag places resource forks in a hidden __MACOSX/ folder which breaks extended attribute extraction in Chrome / Archive Utility, causing Gatekeeper to block the app with "Apple could not verify that this app is free of malware". Safari worked fine because it handles ZIP extraction differently.
    2. All MacPorts dylibs were unsigned
    macdeployqt copies third-party libraries (libsqlite3, libpng, libssl, libharfbuzz, etc.) from MacPorts into Contents/Frameworks/ without signing them. Using codesign --deep (now deprecated) missed these flat .dylib files. Apple's notarization service rejected the submission with "The binary is not signed with a valid Developer ID certificate" for every single one of them.
    Fix: sign every binary explicitly in the correct order — all .dylib files in Frameworks/ first, then .framework bundles, then plugins, then the main executable, and finally the bundle itself.
    3. hdiutil invalidating the bundle signature during DMG creation
    After the .app was correctly signed and notarized, creating a DMG with hdiutil create copies the bundle and recalculates checksums, which invalidates the Sealed Resources signature. Submitting this DMG to notarytool resulted in "The signature of the binary is invalid".
    Fix: create a writable DMG (UDRW format), mount it, re-sign all binaries inside the mounted volume, detach it, then convert to the final compressed read-only DMG (UDZO). This ensures the signature is valid after the conversion.
  • Final workflow
    1. Build with qmake + macdeployqt
    2. Copy elements, titleblocks, translations, fonts, lang, examples into the bundle
    3. Sign all binaries (dylibs → frameworks → plugins → executable → bundle)
    4. Submit a temporary ZIP to notarytool → wait for Apple approval
    5. Staple the notarization ticket onto the .app
    6. Create a staging folder with the .app + a symlink to /Applications
    7. Create a writable UDRW DMG from the staging folder
    8. Mount the UDRW DMG and re-sign all binaries inside
    9. Detach and convert UDRW → UDZO (final compressed DMG)
    10. Sign the DMG with codesign
    11. Submit the DMG to notarytool → staple the ticket onto the DMG
    12. Verify: spctl -a -vv → "accepted / Notarized Developer ID"
Result
The DMG now passes Gatekeeper correctly whether downloaded via Chrome or Safari. It includes a drag-and-drop Applications shortcut and is fully notarized and stapled.
Enjoy! nomicons/wink
