Topic: Introduction: Cable Component Type
Hi all
Under the conductor properties, there’s already a placeholder for a cable. How did you envision this? My idea would be to create a new component category for cables. That way, you’d have a component for the cable and could integrate it directly into the drawing. If the terminals are named with the wire designation, the terminal block plugin for terminal diagrams could check directly: Am I connected to a cable? Which wire is there? Then this could be nicely automated.
If this point is accepted by you, a function could be built to create a cable list from all cables, including start and end points.
What do you think? If that's okay, I'll get to work on creating it.
Re: Introduction: Cable Component Type
An Joshua idea for cable in diagram, but never finishe to coding, I'm think?
3 (edited by Kellermorph 2026-04-09 16:44:21)
Okay, that’s cool and better than what I’m currently doing and had planned to program. The only thing is, there’s no wire labeling here.
The way I’m doing it now—and the way I had planned to do it—is to use a dedicated component for this. I’ve attached an example image.
So should I not go ahead with it if Joshua already has an idea and has partially implemented it?
Bildschirmfoto_20260409_164049.png, 7.46 kb, 359 x 99
Yes I use the same workaround in my project read the entire topic.
https://qelectrotech.org/forum/viewtopi … 141#p17141
https://qelectrotech.org/forum/viewtopi … 158#p17158
C'est juste un symbole ...
So should we wait for Joshua to continue working on this, or should I go ahead and implement this as a component?
If we wait, I would work on integrating a macro explorer into QET.
a macro explorer into QET?
Why, you can explain?
BTW I use a lot of ctrl + F for quickly searching conductors name, element, etc in my projets and of course you could change many things, maybe you don't know it?
Yes, a macro explorer. That way, you can save entire pages. All components within these pages should also be directly imported so that you can insert complete, finished pages right away without having to add components first.
This is also a standard feature found in WSCAD or Eplan and would save a lot of work.
This has nothing to do with search and replace, but rather with being able to insert complete pages.
Ok, like Ai QET ?
https://qelectrotech.org/forum/viewtopi … 717#p22717
BTW, you can save a lot of work now:
9 (edited by Kellermorph 2026-04-09 19:02:08)
more like this
https://qelectrotech.org/forum/viewtopic.php?id=2990
but fully integrated in QET
yeah i know this features. They are nice
10 (edited by Kellermorph 2026-04-26 11:24:41)
the how to video is attached
https://qelectrotech.org/forum/viewtopi … 8040#p8040
