1 (edited by javdenech 2026-03-05 00:07:39)
Topic: QET TB GENERATOR stage update color and custom tkinter
I rewrite the software from raulroda with management of stage and other
pip install qet-tb-generator-xd
Here the link of all my tool for qelectrotech including
>new qet generator raulroda updated xd (me)
>num wire for automatic numerotation
>qet element for automatic numerotation of element K KM YV B IS renamed KA1 KA2 KA3 etc except slave element
also include terminal with and without stage numbering in automatic serveral X1 to X1:1 X1:2 ETC
>qet nomenclature to copy paste from excel directly in your diagram for every propertys of elements
https://drive.google.com/drive/folders/ … sp=sharing
Re: QET TB GENERATOR stage update color and custom tkinter
WOW! nomicons/wink
3 (edited by javdenech 2026-03-02 09:11:24)
I send the script to raulroda but i don't know if i can share his work ! Waiting a response from him, maybe he can take a look and update his package.it provide compatibility with previous version, because the name X3:1 can be used also and you can also manually configure the stage... else it take .1 .2 .3 automatically to défine the stage position from the id. The sort by id also take care of that and if you have three stage with the same id the sorting take care of cable name to sorting them.
4 (edited by javdenech 2026-03-02 09:45:49)
The bridge management work also for stage with O to start a bridge and F to stop à bridge connections. And there is also a automatic bridge analyser with stage by stage mode to connect bridge with cable with the same polarity O O O O F
to trace exception betweew stage.
5 (edited by javdenech 2026-03-02 09:51:20)
If someone know where to change the link in qelectrorotech folder, to launch the plugin link in windows...
You could off course seee the Licence!!! But It is more friendly to notify the author and share the task than to make an aggressive fork yourself without sending a PR to the original git and submitting a PR that he can help with his code or reject in which case it will be a hostile fork.
Licensed under the General Public License 2.0
Same project, same vision: ‘Alone we go fast... together we go further.’ QET's goal here is not to divide us but to move forward together, hand in hand, without tearing each other apart.
We have nothing to gain from that.
I would like to remind you that QET's goal is to provide free, like free beer (no cost), open-source software that is multi-platform for everyone on this earth who wants to design engineering projects, regardless of their field, skills, or no more financial means.
8 (edited by javdenech 2026-03-02 19:36:14)
I sent to him all the source code,I hope he can test and deploy for other because this new plugin change life for every electrician in my compagny. Hope it will be useful for other user in the world ! nomicons/wink
9 (edited by javdenech 2026-03-04 13:08:19)
code source dispo ici par contre j'ai fais ca sur windows pour compiler en exe je sais pas si tout est bon pour du deploiement pip
raulroda contact me and asking me if I want him to preparing a version for pip.
will see...
11 (edited by unalcalde 2026-03-03 20:07:07)
Hi family. I'll try to deploy it on the weekend.
Nowadays I'm using Windows at work and I don't have the development tools installed.
I'll try to install it and create the pip version.
Thanks @javdenech for your excellence version.
De nada
There a setup file to install it on windows as a standalone exe program in the folder output for windows with no link launch it from qet generator from qelectrotech.
and also in the dist folder the exe if you want to test it directly with all the python extension in folder _extention to run without installing anything.
The setup was done with "inno setup 6" software and the script to create the setup for inno is QET_TB_Generator_Setup.iss.
Also, I modifing src script with antigravity and i don't know if setup.py and run.py is ok...
it will be cool to have a configurable extension plugin list in qelectrotech to launch other program
14 (edited by javdenech 2026-03-04 03:38:35)
I make a clean package to deploy on pip at the begining of the discution i will try to deploy on pip with a new name to maintain for later update on the link
https://drive.google.com/drive/folders/ … drive_link
Are the Terminals, the bridge, the cable etc created automatic or did u write it yourself for each terminal?
Hi, I deploy version 2.0.0 to pypi.
To install the last version: pip install qet-tb-generator==2.0.0
To install previous version: pip install qet-tb-generator==1.3.1
17 (edited by javdenech 2026-03-04 13:07:36)
ok cool did you take my last one from my google drive ?
because you deploy the wrong one from grosfichier.com
because cannot launch 2.0 from qelectrotech on windows....
https://drive.google.com/drive/folders/ … bNicnXMdAo
QET_TB_GENERATOR_PIP.ZIP
normally this last one can be launch from qelectrotech
Hello family, to @unalcalde and @javdenech have you see these issues?
https://github.com/raulroda/qet_tb_gene … gin/issues
New code fix them?
BTW, I don't see any git changes on Raul github...
Best regards,
19 (edited by javdenech 2026-03-04 18:34:11)
Bonjour laurent,
je pense que oui car j'ai integrer une fonction sort by id sur le bouton a gauche
et j'ai fait plusieurs test les fils sont bien raccorder avec les bonnes bornes
les hoses et les conductor sont bien enregistrer dans la partie fonction ainsi que les couleur
les fonction sur les borne sont cleannable avec l'outil qet nomenclature.
Bonjour laurent,
I think so, because I integrated a sort by ID function on the button to the left.
And I've done several tests; the wires are correctly connected to the right terminals.
The hoses and conductors are correctly registered in the function section, as are their colors.
The functions on the terminals can be cleaned up with the QET Nomenclature tool.
Hi, @javdenech I generate the pip version 2.0.1 with the last google drive version.
I also commit the version 2.0.1 the Github: https://github.com/raulroda/qet_tb_generator-plugin
If you make changes, create a pull request on github for easy team work.
Thanks
je me suis gourer sur le nom dans pyproject.toml
il y avait des - a la place des underscore le relou
j'ai creer un compte pip pour le publier
j'ai remis a jour le fichier dans le google drive
It's automatic
javdenech wrote:
It's automatic
javdenech wrote:
It's drawing in automatic, you can also copy an paste several line from excel into home and also conductor. I used the logic from see electrical mixed with the original. If you put X1:1.1 And X1:1.2, the last number is the stage, so the plugin automatically put 1 2 3 or 4 in stage field, there is a button, to generate bridge automatically on B1 B2 B3 and B4 column ( O is to start a bridge and F to end the bridge, so it will put O O O O F on B1 for bridge on stage 1.
Thanks @javdenech for this tip.
notice that on my pip account it's version 1.3.3
on pip official release it's 2.0.1 but i leave the wrong name on toml file so there's a bug to launch it from qelectrotech if installed from pip official release.
I don't know if raulroda do the modification yet, i need to connect on the github but i 'am to busy for the moment.
it works on windows but i don't test it yet on linux and mac.
For package it for Debian I use uscan and watch file:
version=4
opts="uversionmangle=s/_/-/" \
https://pypi.debian.net/qet-tb-generator/qet_tb_generator-(.+)\.(?:zip|tgz|tbz|txz|(?:tar\.(?:gz|bz2|xz))) debian uupdate
cd /home/laurent/qet_tb_generator_debian_package/qet-tb-generator-1.1.4/
uscan --verbose --force-download --rename --repack
cd to latest tarball
edit changelog or
dch -i -D unstable  "unstable "
sudo DIST=sid ARCH=amd64  pdebuild --configfile /home/laurent/.pbuilderrc
dch -i -D stable  "Backport stable " && sudo DIST=stable ARCH=amd64 pdebuild --configfile /home/laurent/.pbuilderrc
Copy files in SiD folder
cd /var/cache/pbuilder/unstable-amd64/result
debsign -k xxxxxxxxxxxxxxxxxxxxxxxxx *.changes
cd /home/laurent/apt
reprepro --ignore=missingfile -vb . include unstable /home/laurent/qet_tb_generator_debian_package/sid/*.changes
reprepro -vb . include stable /home/laurent/qet_tb_generator_debian_package/stable/*.changes
reprepro -b . export
cd /home/laurent/paquet_qet/script
rsync -e ssh -av -W --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ server:download.qelectrotech.org/qet/builds/debian/
That facilitate the Debian packaging for me tou upload new version on my Debian repository and Ubuntu PPA, So if you could made an diff and put an pull request on Raul Github, Raul can push new pip version?
On Debian like distributions, Ubuntu PPA, etc  an deb package is more easy to install it, and don't need python virtual venv: see this topic:
https://qelectrotech.org/forum/viewtopic.php?id=2857
