1 (edited by javdenech Today 03:39:43)
Topic: QET TB GENERATOR stage update color and custom tkinter
I rewrite the software from raulroda with management of stage and other
I will deploy soon on pip and make some video
Here the link of all my tool for qelectrotech including
>new qet generator raulroda updated xd (me)
>num wire for automatic numerotation
>qet element for automatic numerotation of element K KM YV B IS renamed KA1 KA2 KA3 etc except slave element
also include terminal with and without stage numbering in automatic serveral X1 to X1:1 X1:2 ETC
>qet nomenclature to copy paste from excel directly in your diagram for every propertys of element
https://drive.google.com/drive/folders/ … sp=sharing
Attachment icon TB GENERATOR.jpg 653.11 kb, file has never been downloaded.
Attachment icon TB.jpg 297.59 kb, file has never been downloaded.
Re: QET TB GENERATOR stage update color and custom tkinter
WOW! nomicons/wink
3 (edited by javdenech 2026-03-02 09:11:24)
I send the script to raulroda but i don't know if i can share his work ! Waiting a response from him, maybe he can take a look and update his package.it provide compatibility with previous version, because the name X3:1 can be used also and you can also manually configure the stage... else it take .1 .2 .3 automatically to défine the stage position from the id. The sort by id also take care of that and if you have three stage with the same id the sorting take care of cable name to sorting them.
4 (edited by javdenech 2026-03-02 09:45:49)
The bridge management work also for stage with O to start a bridge and F to stop à bridge connections. And there is also a automatic bridge analyser with stage by stage mode to connect bridge with cable with the same polarity O O O O F
to trace exception betweew stage.
5 (edited by javdenech 2026-03-02 09:51:20)
If someone know where to change the link in qelectrorotech folder, to launch the plugin link in windows...
You could off course seee the Licence!!! But It is more friendly to notify the author and share the task than to make an aggressive fork yourself without sending a PR to the original git and submitting a PR that he can help with his code or reject in which case it will be a hostile fork.
Licensed under the General Public License 2.0
Same project, same vision: ‘Alone we go fast... together we go further.’ QET's goal here is not to divide us but to move forward together, hand in hand, without tearing each other apart.
We have nothing to gain from that.
I would like to remind you that QET's goal is to provide free, like free beer (no cost), open-source software that is multi-platform for everyone on this earth who wants to design engineering projects, regardless of their field, skills, or no more financial means.
8 (edited by javdenech 2026-03-02 19:36:14)
I sent to him all the source code,I hope he can test and deploy for other because this new plugin change life for every electrician in my compagny. Hope it will be useful for other user in the world ! nomicons/wink
code source dispo ici par contre j'ai fais ca sur windows pour compiler en exe je sais pas si tout est bon pour du deploiement pip
grosfi.ch/2Y2qerbKpC6
raulroda contact me and asking me if I want him to preparing a version for pip.
will see...
11 (edited by unalcalde Yesterday 20:07:07)
Hi family. I'll try to deploy it on the weekend.
Nowadays I'm using Windows at work and I don't have the development tools installed.
I'll try to install it and create the pip version.
Thanks @javdenech for your excellence version.
De nada
There a setup file to install it on windows as a standalone exe program in the folder output for windows with no link launch it from qet generator from qelectrotech.
and also in the dist folder the exe if you want to test it directly with all the python extension in folder _extention to run without installing anything.
The setup was done with "inno setup 6" software and the script to create the setup for inno is QET_TB_Generator_Setup.iss.
Also, I modifing src script with antigravity and i don't know if setup.py and run.py is ok...
it will be cool to have a configurable extension plugin list in qelectrotech to launch other program
14 (edited by javdenech Today 03:38:35)
I make a clean package to deploy on pip at the begining of the discution i will try to deploy on pip with a new name to maintain for later update on the link
https://drive.google.com/drive/folders/ … drive_link
Are the Terminals, the bridge, the cable etc created automatic or did u write it yourself for each terminal?
Hi, I deploy version 2.0.0 to pypi.
To install the last version: pip install qet-tb-generator==2.0.0
To install previous version: pip install qet-tb-generator==1.3.1
