Topic: qet-tb-generator install linux using python3 -m venv
Hello everybody. I am having difficulty installing the terminal module. I'm on version 0.8 on Linux Mint 22. I need help.
On terminal :
gleissonjjc@gleissonjjc-Inspiron-3481:~$ sudo pip3 install qet_tb_generator
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
    python3-xyz, where xyz is the package you are trying to
    install.
    If you wish to install a non-Debian-packaged Python package,
    create a virtual environment using python3 -m venv path/to/venv.
    Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    sure you have python3-full installed.
    If you wish to install a non-Debian packaged Python application,
    it may be easiest to use pipx install xyz, which will manage a
    virtual environment for you. Make sure you have pipx installed.
    See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Re: qet-tb-generator install linux using python3 -m venv
Maybe with create your pyton virtual env?
python3 -m venv venv/ && source venv/bin/activate
pip install qet_tb_generator
laurent@debian:~$ whereis qet_tb_generator
qet_tb_generator: /home/laurent/venv/bin/qet_tb_generator
When you need qet_tb_generator activate your virtual env before.
by
ps: qet_tb_generator in virtual env can't be launched by QET directly, I don't know why at this time, so you need to do in the terminal and wrote qet_tb_generator for launch it and choose where is your project and select it.
That's why I prefer the deb packages I had packaged, I think I also created them on the ubuntu PPA.
FYI qet_tb_generator need also pysimplegui with deb packages.
See https://launchpad.net/~scorpio/+archive … rotech-dev
and for the same way you if you want with pinning you can upgrade to lastest devel 0.100 versions, QET 0.8 release was now very very old.
Edit : Linux Mint 22. x is based on Ubuntu 24.04.
name is Noble.
Uploaded qet_tb_generator and pysimplegui to Ubuntu 24.04 on my PPA.
Oh Great ! Worked perfectly ! Tks scorpio810 !
Great, thanks, what have you used python virtual env or my debs packages?
I added the ppa on my system with .deb packages. Working fine
Thanks for your feed back.
by
(venv) [14:20:26] laurent@debian:~$ whereis qet_tb_generator
(venv) [14:27:18] laurent@debian:~$
Now in the same terminal launch QET
qelectrotech
Example here
(venv) [14:20:26] laurent@debian:~$ qelectrotech
14:19:59.059 Info:  project to use for qet_tb_generator:  "/home/laurent/Qet-svn/git/qet/examples/industrial.qet"
14:19:59.059 Info:  success so far:  false   - now searching for  "/home/laurent/.local/share/QElectroTech/QElectroTech/binary/qet_tb_generator"
14:19:59.059 Info:  success so far:  false   - now searching for  "/home/laurent/qet_tb_generator"
14:19:59.059 Info:  success so far:  false   - now searching for  "/home/laurent/.qet/qet_tb_generator"
14:19:59.059 Info:  success so far:  false   - now searching for  "/home/laurent/venv/bin/qet_tb_generator"
14:19:59.091 Info:  success so far:  true   - now searching for  "qet_tb_generator"
14:19:59 INFO     QET Terminal Block Generator - v1.3.1 [main.main:840]
Maybe edit QET launcher to ?
source venv/bin/activate && qelectrotech %F
https://forums.raspberrypi.com/viewtopi … 1#p2145990
My recommendation is to add this to the bottom of your '~/.profile' file -
if [ ! -x ~/.venv ]; then
  echo
  echo "Creating Python 'venv' virtual environment"
  python -m venv --system-site-packages ~/.venv
fi
export VIRTUAL_ENV_DISABLE_PROMPT=1
source ~/.venv/bin/activate
https://github.com/qelectrotech/qelectr … 95e9f6b74a
Thanks, plc-user. nomicons/wink
16:30:28.938 Info:  project to use for qet_tb_generator:  "/home/laurent/Qet-svn/git/qet/examples/industrial.qet"
16:30:28.938 Info:  qet_tb_generator not found : "/home/laurent/.local/share/QElectroTech/QElectroTech/binary/qet_tb_generator"
16:30:28.938 Info:  qet_tb_generator not found : "/home/laurent/qet_tb_generator"
16:30:28.938 Info:  qet_tb_generator not found : "/home/laurent/.qet/qet_tb_generator"
16:30:28.972 Info:  qet_tb_generator found here: "/home/laurent/venv/bin/qet_tb_generator"
16:30:29 INFO     QET Terminal Block Generator - v1.3.1 [main.main:840]
16:30:29 INFO     Using the file: /home/laurent/Qet-svn/git/qet/examples/industrial.qet [main.get_QET_fullpath:189]
You're welcome!  nomicons/smile
