Topic: Probleme mit Wayland
Guten Morgen zusammen,
ich habe testweise mal von X11 auf Wayland umgestellt.
Dabei ist mir ein Problem aufgefallen. Ich kann die Werkzeugleisten nicht am Rand wieder andocken.
Ich habe mal Beispielvideos angehangen. Ist das ein bekannter Fehler oder nur ein Problem bei mir?
Attachment icon Bildschirmfoto 2025-11-13 07:39:17.png 69.92 kb, 37 downloads since 2025-11-13
Re: Probleme mit Wayland
Hallo Thomas,
See:
https://qelectrotech.org/bugtracker/vie … d=305#c724
https://qelectrotech.org/bugtracker/view.php?id=311
I'm think this was fixed on Qt 6.9 not on old Qt 5.15.x
Regards,
I "m on Debian Sid with plasma6 with Wayland and Qt6.9.
If I need to re-stack the windows because I have moved them, I run this command to switch the compositor back to X11/xcb mode and restore my windows. After that, I can restart QET normally under Wayland.
QT_QPA_PLATFORM=xcb qelectrotech
Hi Laurent,
Sorry, but I think I'm too stupid to understand that right now.
According to the QElectrotech info, I have version QT 5.15 installed.
With 6.9, the problem should no longer exist?
How do I upgrade the version in QElectrotech? I installed it from the Ubuntu sources and then upgraded to V0100 according to your instructions.
This is a Qt 5 bug and I think is fixed on Qt 6.9 or 6.10 version?
For QET we need to wait when we compile it with Qt 6.X framework
Ah, okay, so that will be fixed in the future as soon as it is built with the new QT version? So it's just a matter of time? Will that come in via a normal update?
I checked an little with qt6-cmake branch of QET, is better but freezing the application..
10:05:36.676 Info: "QElectroTech V 0.100.0-dev"
10:05:36.676 Info: "Compilation : GCC 15.2.0"
10:05:36.676 Info: "Built with Qt 6.9.2 - x86_64 - Date : Nov 13 2025 : 10:03:29"
10:05:36.676 Info: "Run with Qt 6.9.2 using 48 thread(s)"
10:05:36.676 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
10:05:36.676 Info: "RAM Total : 64 GB"
10:05:36.676 Info: "RAM Available : 51 GB"
10:05:36.676 Info: "GPU :  Advanced Micro Devices, Inc. [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT] (rev df)\n"
10:05:36.676 Info: "GPU RAM :     Video memory: 10240MB\n    Dedicated video memory: 10240 MB\n    Currently available dedicated video memory: 8796 MB\n"
10:04:11.394 Info: Elements collection reload
10:04:11.516 Info: Elements collection finished to be loaded in 0.121 seconds
10:04:24.585 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:04:34.573 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:04:34.575 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:04:48.238 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:04:48.239 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:05:27.458 Warning: QObject::disconnect: wildcard call disconnects from destroyed signal of AutoNumberingDockWidget::AutoNumberingDockWidget (:0, )
10:05:55.454 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:05:58.409 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:05:58.412 Warning: This plugin supports grabbing the mouse only for popup windows (:0, )
10:06:22.174 Warning: QObject::disconnect: wildcard call disconnects from destroyed signal of AutoNumberingDockWidget::AutoNumberingDockWidget (:0, )
ok thank you a lot.
i will stay at X11 when im working with QET.
Or if you want to work under Wayland just edit /usr/share/applications/org.qelectrotech.qelectrotech.desktop
And change
Exec=qelectrotech %F
By
Exec=env QT_QPA_PLATFORM=xcb qelectrotech %F
Off course! you need to change this line in *.desktop after each QET package upgrade...
For users using Ubuntu snap see: https://github.com/qelectrotech/qelectr … issues/373
For history:
https://github.com/KDAB/KDDockWidgets/issues/10
https://qelectrotech.org/bugtracker/vie … 59891ad51d
David Edmundson added a comment - 30 Jul '25 09:11
The protocol mentioned above got merged and standardised as https://wayland.app/protocols/xdg-toplevel-drag-v1
QtWayland now supports this
Dates
Created:    19 Nov '22 23:08
Updated:    30 Jul '25 09:11
Resolved:    30 Jul '25 09:11
https://bugreports.qt.io/browse/QTBUG-138339
https://bugreports.qt.io/browse/QTBUG-136011
Thanks a lot!
