| 0000305 | QElectroTech | Diagram Editor | public | 2024-05-22 12:18 | 2024-11-01 09:55 |
| Reporter | Electro Agropack | Assigned To | |||
| Platform | Gnome | OS | Linux | OS Version | Fedora Linux 40 |
| Summary | 0000305: Impossible d'intégrer les "Panels" dans l'interface principale sous Wayland | ||||
| Description | Lorsque l'on détache un des "Panels" (Projets, Collections, Annulations, Propriétés de la sélection, Sélection numérotation Auto), il est impossible de les réintégrer dans l'interface quand je suis sous Gnome Wayland. Par contre cela fonctionne correctement sous Gnome Xorg. | ||||
| Steps To Reproduce |
| Additional Information | QElectroTech V 0.90 Compilation : GCC 14.0.1 20240125 (Red Hat 14.0.1-0) Built with Qt 5.15.12 - x86_64 - Date : Jan 26 2024 : 00:00:00 Run with Qt 5.15.13 using 4 thread(s) CPU : model name : Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz RAM Total : 7 GB RAM Available : 5 GB GPU : Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07) GPU RAM : Video memory: 7814MB OS : linux - x86_64 - Version : Fedora Linux 40 (Workstation Edition) - Kernel : 6.8.10-300.fc40.x86_64 *** Qt screens *** ( 1 : 1920 x 1080 ) | ||||
| Tags | wayland | ||||
Log d'erreurs : 12:21:04.731 Warning: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x561823bda7d0) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x561823fae580) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents (:0, ) 12:21:10.067 Warning: Wayland does not support QWindow::requestActivate() (:0, ) |
As tu essayé de lancer QET dans un terminal |
A tester?
https://github.com/KDAB/KDDockWidgets/issues/10
https://bugreports.qt.io/browse/QTBUG-108675 |
Rapport des différents essais (je n'ai mis que les erreurs quand je bouge les panels):
Merci du retour. Je pense que le workaround serai de modifier pour ceux sous Wayland le qelectrotech.desktop https://github.com/qelectrotech/qelectrotech-source-mirror/blob/master/misc/qelectrotech.desktop#L5C1-L5C21
Par |
A priori la syntaxe pour le .desktop n'est pas correcte et ne fonctionne pas (en tout cas sous Gnome 46)
Il vaut mieux mettre
Merci de ton aide tout fonctionne correctement !! |
Merci de ton retour, effectivement d’après ce post il vaut mieux ajouter le "env" https://github.com/keepassxreboot/keepassxc/issues/4105#issuecomment-812473875 |
Pour information j'ai ajouté ces dépendances dans la construction du paquet Debian en .deb libqt5waylandclient5-dev, libqt5waylandcompositor5-dev, Il est ainsi possible de les ré intégrer dans l’application mais pas sous forme de pile... donc pas empilables |
| 2024-05-22 12:18 | Electro Agropack | New Issue | |
| 2024-05-22 12:18 | Electro Agropack | Tag Attached: wayland | |
| 2024-05-22 12:26 | Electro Agropack | Note Added: 0000714 | |
| 2024-06-03 18:19 | scorpio810_mantis | Note Added: 0000719 | |
| 2024-06-06 14:58 | scorpio810_mantis | Note Added: 0000721 | |
| 2024-06-06 15:28 | scorpio810_mantis | Note Added: 0000722 | |
| 2024-06-06 15:35 | scorpio810_mantis | Note Added: 0000723 | |
| 2024-06-06 15:40 | scorpio810_mantis | Note Edited: 0000723 | |
| 2024-06-07 09:13 | Electro Agropack | Note Added: 0000724 | |
| 2024-06-07 14:35 | scorpio810_mantis | Note Added: 0000725 | |
| 2024-06-09 12:39 | Electro Agropack | Note Added: 0000726 | |
| 2024-06-09 12:40 | Electro Agropack | Note Edited: 0000726 | |
| 2024-06-09 13:53 | scorpio810_mantis | Note Added: 0000727 | |
| 2024-11-01 09:54 | scorpio810_mantis | Note Added: 0000755 | |
| 2024-11-01 09:55 | scorpio810_mantis | Note Edited: 0000755 |
