Topic: Summary - Sort by page number
Hi Guys !
How can I sort by page number?
I tried, but they are out of order.
Captura de tela 2025-09-25 152807.jpg, 229.88 kb, 711 x 646
Re: Summary - Sort by page number
Set the 'Page' column first, or adjust the SQL query
SELECT  folio, title, author, date FROM project_summary_view ORDER BY pos, folio, title, author, date
https://download.qelectrotech.org/qet/forum_img_2/summary_sql.png
Oh ! Great ! Work !
Tks all !
Hi Laurent,
I defined an user-property which is used on each folio. How can I use it within the SQL command?
If I just change your command into
SELECT  folio, title, date, status FROM project_summary_view ORDER BY pos, folio, title, date, status
it only shows a little grey box.
BR Joe
Hi Joe,
export your database and open it, you can show if your user-property appears?
See my post here:
https://qelectrotech.org/forum/viewtopi … 256#p16256
Code database:
https://github.com/qelectrotech/qelectr … tabase.cpp
BR Laurent
Hi Laurent,
thank you so much for your help. It appears that the custom value (see attachment) is not being saved in the database. Is it being saved somewhere else?
BR, Joe
QElectroTech_Custom-Folio-Value.png, 45.04 kb, 574 x 669
