Topic: Cloud Sync with QElectroTech
Has anyone tried saving to a cloud storage service (like OneDrive, iCloud, etc.)? Does it work properly when switching between PCs or in general on your current PC (Windows, macOS)?
Thanks!
QElectroTech → EN : Help, suggestions, discussions, ... → Cloud Sync with QElectroTech
Thanks!
Not knowing, what you would like to save on other people's hardware ...
If you used forum-search with the keyword "cloud" you would have found this post (among others):
https://qelectrotech.org/forum/viewtopic.php?id=2969
QET has no network function, so it can't connect to a remote server directly!
The trick is to create a network shared drive on Windows, on linux an maybe macOS create and mount a drive to remote directory.
https://qelectrotech.org/forum/viewtopi … 4173#p4173
Other solution:
https://qelectrotech.org/forum/viewtopic.php?id=2484
At work I use 2 monitors one right for diagram, and I put all widgets like collection, rules numering, selection, etc in left screeen.
I use also QET installed on entreprise remote server for increase power off my PC.
At work my setup is a old I5 intel setup on Debian Linux.
We have installed other Debian in remote server VMware and I use XRDP to run QET on remote server with my 2 monitors on my desktop Debian.
Thank you very much for your help.
[Edit by moderator]:
If you want to advertise unrelated topics, you are in the wrong place, GenevieveEbert999 !!!
Generated in 0.017 seconds (27% PHP - 73% DB) with 11 queries
