Topic: Drivers' Union
Hello everyone. I don't know if anyone has asked anywhere on the forum how to join conductors to identify which component specifically joins one conductor to another. I am attaching an image with different joins.
Thanks in advance.
Union Conductores.png, 83.79 kb, 468 x 735
2 (edited by LievenC 2024-10-30 10:40:56)
Re: Drivers' Union
this has nothing to do with the application
you can control this by using a splice
If it is purely for having a shematic I would leave the control to the application
if you want to indicate how the wiring should be I would put a splice
Anyway suggestion 2 is to avoid
and the the choise for 1 or 3 depends on the components where the wires need to be connected
if it is possible to put 2 wires into one connection
attached is a file with a number of splices I have created
A simple search on the forum would give you a list with answers you your question
Re: Drivers' Union
Maybe see this topic: https://qelectrotech.org/forum/viewtopic.php?id=2764
https://download.qelectrotech.org/qet/forum_img_2/1_schema.png
