Hello Vadoola,
about the definition-line.
The definition-line describes the dimensions of the element and is calculated by the element editor. It is therefore not noticeable that the values have not been calculated (correctly) if the import is carried out directly in the element editor.
If the element is converted on the command line and the element is used directly in the diagram editor, it is not displayed correctly because the width, height and hotspots are not set correctly.
This is particularly noticeable when dragging the element onto the folio, see appendix.
You already write it in a comment in your code (src/qelmt/mod.rs from line 59:
//The original code had the height, and width hard coded to 10
//and the hotspots hard coded to 5. I'm not sure why this is?
//Maybe actually calculating the size wasn't worth it? I'm not sure
//if that info is part of the dxf. And maybe when you open he elemnt
//in the elemtent editor it corrects it anyway. Just look into it, and
//se if this is something that needs to get adjusted.
The values for the definition line can only be calculated correctly if all information about all graphical elements is available.
In QET_ElementScaler I keep the whole QET-element in memory and recalculate the definition-line after scaling and before writing anything to stdout.
The calculation is specific to QET and it took me some time and help from Laurent and Joshua to implement it accordingly.
If you read in the file sequentially and output everything immediately to stdout, the definition-line values can not be correct. As far as I know, the necessary information is not in the dxf...
