Salut Laurent !
Thanks for the links to the source code!
In my programme I already have all the information available that makes up a connection. That includes all information about the connected elements. The challenge I see at the moment is figuring out the logic of which connection I need to change and how, in order to be able to delete another connection.
From the file "Verweis.qet":
The PE connection can be deleted without any substitution, because on the one side there is a component (X0.PE) connected, but on the other side of the connection there is only a reference that does not point anywhere and also has no second connection.
The situation is different with the " Nonsense" line:
From X1:2, a connection goes to the left to the link that points nowhere. However, the line must not be deleted because a second connection is attached to the left reference, which goes somewhere. I therefore have to transfer the data from the second connection to the connection to X1:2 in order to be able to delete one of the two connections.
You have to move from point to point in order to delete as many connections as possible. Ideally, no reference element will remain at the end.
The situation is similar for the "Phase" and "Null" connections, which go from X0 to K1 and K2.
