Topic: can't move device, because fields overlaying it
Hi there!
Sometimes I would like to move a device, e.g. a terminal.
You have to left click and hold on the right spot to move.
But a terminal is a small device, you have only little, tiny spots to click for move. Some other spots, you can start to draw a wire.
And if you have a text label near (overlaying partly the device), you can't reach "moving" spots.
So you have to move the label, then move the device, then move the label back.
Is there a possibility to click through the "layers" of overlaying labels, device, "wirepoints" to reach the right spot/grap.
I don't know how to name it "spot", "grap", "grap area" ....?
In other programs, if you click left to one area, and there are more overlying "things", you can click with right through all possibilities, click left second time if the right "thing" is highlighted, then you can edit, move... this.
Is there such a trick in this program?
Thank you!
using on Linux Mint 20.2 Cinnamon
Re: can't move device, because fields overlaying it
https://download.qelectrotech.org/qet/m … lbar-depth
https://download.qelectrotech.org/qet/manual_0.7/build/_images/qet_toolbar_depth.png
3 (edited by Aleksandr 2023-10-11 14:18:48)
By and large, text editing is not really necessary right away on the project sheet. Here we would have to take a conceptual approach. All element texts can be edited in the element properties. And after pressing Enter there should be a reaction from the OK button. This is much faster than looking for a mouse on the table and clicking OK. And if you need a line break, do it via Ctrl+Enter. You can also put a hidden symbol, like in LibreOffice (¶), to make it clear that there is a line break in the text. In general, there are many places where you could make a reaction to Enter by clicking on the OK button. I don’t really know how easily this is available in Qt. In general, this rule comes from programmers a long time ago. If you work on the keyboard, then it’s faster to finish the work from the keyboard than to look for the mouse. Pressing TAB multiple times doesn't help much.
I support the request but would specify a bit more:
the "Enter" key gets the same function as the <Apply> button on any popup.
Where there is an <OK> button I think the "Enter" key works.
This would indeed make work a lot faster.
Yes, exactly “apply”.
6
I want to return to this topic again. Qelectrotech has done a great job in that the properties of an element can be viewed and changed in the sidebar. But the fact that the text overlaps the element itself is very disturbing. Maybe in the project properties you can disable access to text. Moreover, it is immediately available in the properties panel. And there, what I like, by changing the properties they are immediately applied without confirmation.
It would also be nice to have the cursor remain in the last editable field with the text highlighted when you click on an element in the properties panel. I'm not good at programming, this is just a suggestion for improvement.
