Topic: can't move device, because fields overlaying it
Hi there!
Sometimes I would like to move a device, e.g. a terminal.
You have to left click and hold on the right spot to move.
But a terminal is a small device, you have only little, tiny spots to click for move. Some other spots, you can start to draw a wire.
And if you have a text label near (overlaying partly the device), you can't reach "moving" spots.
So you have to move the label, then move the device, then move the label back.
Is there a possibility to click through the "layers" of overlaying labels, device, "wirepoints" to reach the right spot/grap.
I don't know how to name it "spot", "grap", "grap area" ....?
In other programs, if you click left to one area, and there are more overlying "things", you can click with right through all possibilities, click left second time if the right "thing" is highlighted, then you can edit, move... this.
Is there such a trick in this program?
Thank you!
