1 (edited by gaminn 2023-08-09 22:16:54)
Topic: Indirect connection
I'm sorry for such a basic question, but after an hour I found zero information about this:
How to make a connection like the one in attached file (24V)?
I used comming arrow and going arrow elements, placed them in the schematic. They had "%{label} / %{tension-protocol}" text next to them which I changed to 24V. However I think I didn't make the connection.
Thanks for help
Martin
Re: Indirect connection
Hi Martin
For items like this they need to be linked. I have uploaded screenshots of the process.
Right click -> Edit Element -> Folio Referencing -> Right click and link item -> Apply -> Select which wire number you want to associate.
This is the same process for Master/Child elements.
You can then see the associations of items and they will stay updated with the referencing format if you move them around.
Hope this helps nomicons/smile
PS - You can double click as a short cut...
Hi and thank you very much for your help and the detailed description.
I tried it and I think I can only connect 1 particular going arrow to 1 particular coming arrow. This definitely doesn't provide much flexibility for my design.
Imagine this: I have a power supply 24VDC and then I have many other elements that consume (are connected to) 24VDC. How do I connect all the elements with the power supply without drawing lines and thus making the schematic total chaos?
Also, I would like all the linked coming and going arrows to display some meaningful name of the wire (like 24VDC). How can I do that?
I'm sorry, I came from Altium/Eagle/KiCad PCB design software. It seems QElectroTech is very different and I have difficult times to achieve what I want.
I noticed this thread where topic author asks the same question. https://qelectrotech.org/forum/viewtopic.php?id=2563
The advise is that we should use one terminal element that can connect to multiple going arrows. I tried to search for "terminal" in Collections but I have no idea which terminal should I use as there are many elements that have "terminal" in its name.
https://qelectrotech.org/forum/viewtopic.php?id=1411
I don't understand how to make one to many indirect connection. The only solution I found is adding going arrow with a constant text label (e.g. 24VDC) to all nodes. It's a dirty solution but it works for me.
