Topic: Dark theme in windows?
Hi all, just wondering if there is a way to enable dark mode in windows? I have tried the "Use System Colours" setting, but it didnt seem to do anything. Any help with this would be greatly appreciated, thanks nomicons/smile
Re: Dark theme in windows?
https://qelectrotech.org/forum/viewtopic.php?id=1466
https://qelectrotech.org/bugtracker/view.php?id=247
https://qelectrotech.org/forum/viewtopi … 2411#p2411
3 (edited by James4832 2023-04-02 06:52:53)
Thank you. I have a dark theme now, however the contrast on the icons is very poor. Is there any way to adjust these icons?
Screenshot 2023-04-02 165019.png, 24.9 kb, 1434 x 172
Maybe https://doc.qt.io/qt-6/stylesheet-examp … g-qmenubar
Hmm, no luck with that one, managed to change the font colour, and the background of the buttons under QToolButton. But no luck on the actual icons. Appreciate the help though.
The icons are just images and were designed for the white theme, the only thing you can try is to change the menu bar background to gray.
We don't have any icons for the black theme, nor does QET have any code to detect the theme change and select the correct icons...
