Topic: Problem with install get_tb_generator on macOS
Hi
I'm new user for QElectroTech
I have problem with install get_tb_generator
Windows 10
Python 3.11.1 (download from python website)
QElectroTech 0.90
I run : pip install get_tb_generator
ERROR : Could not find a version that .....
Plese help me. Thanks
Screenshot_1.png, 8.51 kb, 818 x 58
Re: Problem with install get_tb_generator on macOS
maybe it is not available for python 3.11?
otherwise you have exe package here : https://download.qelectrotech.org/qet/b … generator/
Or here  https://download.qelectrotech.org/qet/b … rator_win/
Hi scorpio810,
Thank for your fast response but my antivirus, McAfee antivirus block exe file download from yourlink.
uninstall python 3.11 and try with python 3.9
Just tried on macOS Ventura:
 pip3 install qet_tb_generator
Defaulting to user installation because normal site-packages is not writeable
Collecting qet_tb_generator
  Downloading qet_tb_generator-1.3.1-py3-none-any.whl (393 kB)
     |████████████████████████████████| 393 kB 4.2 MB/s
Requirement already satisfied: PySimpleGUI in /Library/Python/3.9/site-packages (from qet_tb_generator) (4.60.4)
Installing collected packages: qet-tb-generator
  WARNING: The script qet_tb_generator is installed in '/Users/laurent/Library/Python/3.9/bin' which is not on PATH.
  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Successfully installed qet-tb-generator-1.3.1
WARNING: You are using pip version 21.2.4; however, version 23.0 is available.
You should consider upgrading via the '/Applications/Xcode.app/Contents/Developer/usr/bin/python3 -m pip install --upgrade pip' command.
Try with pip3 command:
I success to install them but when I run QElectroTech and goto Lunch the terminal block creation plugin menu
popup error lunching qet_tb_generator plugin show
I goto directory Python..\Scripts and run qet_tb_generator.exe It can open and run ok.
What your python version?
In QET code qet_tb_generator launch path was hardcoded with python version 3.9.
https://github.com/qelectrotech/qelectr … .cpp#L2377
https://github.com/qelectrotech/qelectr … .cpp#L2433
8 (edited by peter_smalley94 2023-02-22 12:02:46)
I have an issue where terminal Block plug in runs seperatly from Qelectrotech but it wont run properly or thought the Qelectrotech program. I know the correct file path is being used it jsut cant search it.
Screen Shot 2023-02-22 at 08.14.58.png, 105.75 kb, 578 x 372
Hi Peter,
when you have installed python 3.9 bundle have you also added python PATH in your zsh profile?
BTW, for my personnal information what QET version use you, intel or arm64 version?
A framework /Library/Frameworks/Python.framework, which includes the Python executable and libraries. The installer adds this location to your shell path.
https://docs.python.org/3/using/mac.html
MacOS arm64 python 3.11 installation
get:
https://www.python.org/ftp/python/3.11. … acos11.pkg
1) Install it.
2) Click on "Update Shell Profile.command" script to add python Path in your shell.
3) Install qet_tb-generator in terminal:
laurent@mini-de-laurent ~ % pip3 install qet_tb_generator
  Using cached qet_tb_generator-1.3.1-py3-none-any.whl (393 kB)
Collecting PySimpleGUI
  Downloading PySimpleGUI-4.60.4-py3-none-any.whl (509 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 510.0/510.0 kB 7.1 MB/s eta 0:00:00
Installing collected packages: PySimpleGUI, qet_tb_generator
Successfully installed PySimpleGUI-4.60.4 qet_tb_generator-1.3.1
[notice] A new release of pip available: 22.3.1 -> 23.0.1
[notice] To update, run: pip3 install --upgrade pip
Test if launch:
laurent@mini-de-laurent ~ % /Library/Frameworks/Python.framework/Versions/3.11/bin/qet_tb_generator
15:02:21 INFO     QET Terminal Block Generator - v1.3.1 [main.main:840]
15:02:28 INFO     Using the file: None [main.get_QET_fullpath:189]
macOs arm64 ok:
QElectroTech V 0.100.0-dev
Compilation : CLANG 14.0.0 (clang-1400.0.29.202)
Built with Qt 5.15.8 - arm64 - Date : Feb 22 2023 : 17:30:28
Git Revision : 78644a35245a4c658bcaa350d17130092d31b05b
Run with Qt 5.15.8 using 8 thread(s)
CPU : Apple M2
RAM Total : 8 GB
GPU :
GPU RAM :
OS : darwin - arm64 - Version : macOS 13.2 - Kernel : 22.3.0
*** Qt screens ***
( 1 : 3840 x 2160 )
https://download.qelectrotech.org/qet/forum_img_2/qet_tb-generator-arm64_python3.11.png
I dont think i have added the python PATH in your zsh profile how would you do this?
My Version is:
QElectroTech V 0.90 rc7891bc4c
Built with Qt 5.15.6 - x86_64 - Date : Jan 6 2023 : 13:09:17
Run with Qt 5.15.6 using 4 thread(s)
CPU : Intel(R) Core(TM) i5 CPU M 540 @ 2.53GHz
RAM Total : 8 GB
GPU :
GPU RAM :
OS : darwin - x86_64 - Version : macOS High Sierra (10.13) - Kernel : 17.7.0
*** Qt screens ***
( 1 : 1920 x 1200 )
for 0.90 QET version only use python 3.9
When you install python bundle at end is show a windows with more scripts, double click on "Update Shell Profile.command" script in the windows list to add python Path in your shell.
cat .zprofile
# Setting PATH for Python 3.11
# The original version is saved in .zprofile.pysave
PATH="/Library/Frameworks/Python.framework/Versions/3.11/bin:${PATH}"
export PATH
Modify PATH to your python 3.9 version.
I have updated the verison of qelectrotech to the same as you and put on python 3.11 run the shellprofile.command file and made sure everything is up to date and it still comes up with the same error when i try and run the terminal builder in the program
You don't have forgot to install
Try to launch qet_tb_generator with QElectroTech open with industrial.qet example provided.
Or get it here: https://github.com/qelectrotech/qelectr … strial.qet
When i install the pip3 it says that is is already satisfied:
Requirement already satisfied: qet_tb_generator in /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages (1.3.1)
Requirement already satisfied: PySimpleGUI in /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages (from qet_tb_generator) (4.60.4)
This still isnt working
QET version 0.100.0 use hardcoded python 3.11 path only for macOS.
I have python 3.11 and i am running QET version 0.100.0. I have run the shell profile too. I am not sure why it isnt working can you please give me some information to look for
Try this command in your terminal:
Command qet_tb_generator on terminal work too.
Last login: Sun Mar 19 11:15:52 on ttys000
laurent@mini-de-laurent-1 ~ % qet_tb_generator
11:34:34 INFO     QET Terminal Block Generator - v1.3.1 [main.main:840]
When i put the command in my terminal this comes up:
Screen Shot 2023-04-27 at 16.19.26.png, 90.89 kb, 906 x 632
When i run the terminal block generator this way i get this code:
Screen Shot 2023-04-27 at 16.41.55.png, 169.88 kb, 1920 x 1040
