1 (edited by scorpio810 2023-01-20 10:11:18)
Topic: Financing macOS machine for improving QElectroTech on MAC M1/M2 arm64
Until now QElectroTech team bundles were made under linux with OSX KVM for X86_64 Intel macOS. Obviously it takes a lot of work, knowledge, time consuming to make it.
I would like to buy the new mac mini M2 to make universal bundles for macOS (arch:amd64 & arm64), for that we are missing about 300€ on our Paypal to buy a 699€ the MAC Mini M2, are you ready to help us in this adventure?
https://www.apple.com/fr/shop/buy-mac/m … 3urs-256go
https://qelectrotech.org/forum/viewtopi … 377#p17377
I slightly improved my AMD Threadripper OSX/KVM and gained a lot of fluidity without going through the GPU passthrough...
Compiling QET on Monterey take ~34 s with CLANG 14 vs 32 s with GCC on my Linux host, is fine, but emulating an APPLE Silicon amr64 in QEMU is a hassle... and you lost 80 % off Host CPU for emulate it!, otherwise you have Rosetta2 which should work fine I think, without too much slowdown, if you have any feedback?
I'll leave that aside for a moment.
BTW,
For those who already have an M1 or M2 APPLE silicon, if you can test the build environment here:
it's need  ~ 11 Go free on your disk and can take some many hours for building the build environment by arch.
https://qelectrotech.org/wiki_new/doc/m … t_new_2023
Or tell us how QET behaves with rosetta2 on an M1, M2..
Without a real MAC it is more difficult to improve the software under this OS...
Re: Financing macOS machine for improving QElectroTech on MAC M1/M2 arm64
                100%
0[=====================] 700 €
They used the Donate button:
Mauro (IT)
Marco (CH)
Bernd (DE)
Jean (FR)
Anastasios  (EL)
Krystian (PL)
Philipp (DE)
Jean Pierre (BE)
Jacobo (ES)
Fabrice (FR)
Immanuel (DE)
Marcel (DE)
Miguel (PER)
Johannes (DE)
Marcel (DE)
Antonio (ES)
Ruben (DE)
Andre (DE)
Can't build QET with MacPorts and Digikam scripts, I have linking errors:
...........building for macOS-arm64 but attempting to link with file built for macOS-x86_64.. For All KF5 libs...
Ok! with Homebrew: ps: compile QET on mini M2 8Go 256Go take 60 s. BUT I can't provide export database with sqlite3
The time of compilation is 1 min 2 sec
12:35:04.709 Info: Elements collection finished to be loaded in 0.651 seconds
:33:55.114 Info: Start-up
12:33:55.122 Info: debugging enabled: false
12:33:55.122 Info: Qt library version: 5.15.8
12:33:55.122 Info: Qt library location default prefix: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:33:55.122 Info: Qt library location documentation: "/opt/homebrew/Cellar/qt@5/5.15.8_1/doc"
12:33:55.122 Info: Qt library location headers: "/opt/homebrew/Cellar/qt@5/5.15.8_1/include"
12:33:55.123 Info: Qt library location libraries: "/opt/homebrew/Cellar/qt@5/5.15.8_1/lib"
12:33:55.123 Info: Qt library location executables: "/opt/homebrew/Cellar/qt@5/5.15.8_1/libexec"
12:33:55.123 Info: Qt library location Qt binaries: "/opt/homebrew/Cellar/qt@5/5.15.8_1/bin"
12:33:55.123 Info: Qt library location Qt plugins: "/opt/homebrew/Cellar/qt@5/5.15.8_1/plugins"
12:33:55.123 Info: Qt library location installed QML extensions: "/opt/homebrew/Cellar/qt@5/5.15.8_1/imports"
12:33:55.123 Info: Qt library location installed QML extensions: "/opt/homebrew/Cellar/qt@5/5.15.8_1/qml"
12:33:55.123 Info: Qt library location dependent Qt data: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:33:55.123 Info: Qt library location independent Qt data: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:33:55.123 Info: Qt library location translation: "/opt/homebrew/Cellar/qt@5/5.15.8_1/translations"
12:33:55.123 Info: Qt library location examples: "/opt/homebrew/Cellar/qt@5/5.15.8_1/examples"
12:33:55.123 Info: Qt library location Qt testcases: "/opt/homebrew/Cellar/qt@5/5.15.8_1/tests"
12:33:55.123 Info: Qt library location Qt settings: "/Library/Preferences/Qt"
12:33:55.123 Info: "GitRevision 6e60842d6980f9d393bf234ccc4bc4963c62f720"
12:33:55.123 Info: "QElectroTech V 0.100.0-dev"
12:33:55.123 Info: "Compilation : CLANG 14.0.0 (clang-1400.0.29.202)"
12:33:55.123 Info: "Built with Qt 5.15.8 - arm64 - Date : Feb  6 2023 : 12:13:31"
12:33:55.123 Info: "Run with Qt 5.15.8 using 8 thread(s)"
12:33:55.123 Info: "CPU : Apple M2\n"
12:33:55.123 Info: "RAM Total : 8 GB"
12:33:55.123 Info: ""
12:33:55.123 Info: "GPU : "
12:33:55.123 Info: "GPU RAM : "
12:33:55.123 Info: "OS : darwin  - arm64 - Version : macOS 13.2 - Kernel : 22.3.0"
12:33:55.123 Info: *** Qt screens ***
12:33:55.123 Info: "( 1 : 3840 x 2160 )"
12:33:55.152 Debug: isReadOnly: true (../sources/machine_info.cpp:161, void MachineInfo::send_info_to_debug())
12:33:55.152 Info: DISK : /
12:33:55.153 Info: FileSystemType: "apfs"
12:33:55.153 Info: SizeTotal: 245 GB
12:33:55.153 Info: AvailableSize: 181 GB
12:33:55.153 Debug: isReadOnly: true (../sources/machine_info.cpp:161, void MachineInfo::send_info_to_debug())
12:33:55.153 Info: DISK : /Volumes/qelectrotech
12:33:55.153 Info: SizeTotal: 0 GB
12:33:55.153 Info: AvailableSize: 0 GB
12:33:55.153 Debug: isReadOnly: true (../sources/machine_info.cpp:172, void MachineInfo::send_info_to_debug())
12:33:55.153 Info: DISK USED: /
12:33:55.310 Info: Elements collection reload
12:33:55.321 Info: Elements collection finished to be loaded in 0.011 seconds
12:35:03.838 Info: Start-up
12:35:03.845 Info: debugging enabled: false
12:35:03.845 Info: Qt library version: 5.15.8
12:35:03.846 Info: Qt library location default prefix: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:35:03.846 Info: Qt library location documentation: "/opt/homebrew/Cellar/qt@5/5.15.8_1/doc"
12:35:03.846 Info: Qt library location headers: "/opt/homebrew/Cellar/qt@5/5.15.8_1/include"
12:35:03.846 Info: Qt library location libraries: "/opt/homebrew/Cellar/qt@5/5.15.8_1/lib"
12:35:03.846 Info: Qt library location executables: "/opt/homebrew/Cellar/qt@5/5.15.8_1/libexec"
12:35:03.846 Info: Qt library location Qt binaries: "/opt/homebrew/Cellar/qt@5/5.15.8_1/bin"
12:35:03.846 Info: Qt library location Qt plugins: "/opt/homebrew/Cellar/qt@5/5.15.8_1/plugins"
12:35:03.846 Info: Qt library location installed QML extensions: "/opt/homebrew/Cellar/qt@5/5.15.8_1/imports"
12:35:03.846 Info: Qt library location installed QML extensions: "/opt/homebrew/Cellar/qt@5/5.15.8_1/qml"
12:35:03.846 Info: Qt library location dependent Qt data: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:35:03.846 Info: Qt library location independent Qt data: "/opt/homebrew/Cellar/qt@5/5.15.8_1"
12:35:03.846 Info: Qt library location translation: "/opt/homebrew/Cellar/qt@5/5.15.8_1/translations"
12:35:03.846 Info: Qt library location examples: "/opt/homebrew/Cellar/qt@5/5.15.8_1/examples"
12:35:03.846 Info: Qt library location Qt testcases: "/opt/homebrew/Cellar/qt@5/5.15.8_1/tests"
12:35:03.846 Info: Qt library location Qt settings: "/Library/Preferences/Qt"
12:35:03.846 Info: "GitRevision 6e60842d6980f9d393bf234ccc4bc4963c62f720"
12:35:03.846 Info: "QElectroTech V 0.100.0-dev"
12:35:03.846 Info: "Compilation : CLANG 14.0.0 (clang-1400.0.29.202)"
12:35:03.846 Info: "Built with Qt 5.15.8 - arm64 - Date : Feb  6 2023 : 12:13:31"
12:35:03.846 Info: "Run with Qt 5.15.8 using 8 thread(s)"
12:35:03.846 Info: "CPU : Apple M2\n"
12:35:03.846 Info: "RAM Total : 8 GB"
12:35:03.846 Info: ""
12:35:03.846 Info: "GPU : "
12:35:03.846 Info: "GPU RAM : "
12:35:03.846 Info: "OS : darwin  - arm64 - Version : macOS 13.2 - Kernel : 22.3.0"
12:35:03.847 Info: *** Qt screens ***
12:35:03.847 Info: "( 1 : 3840 x 2160 )"
12:35:03.847 Debug: isReadOnly: true (../sources/machine_info.cpp:161, void MachineInfo::send_info_to_debug())
12:35:03.847 Info: DISK : /
12:35:03.847 Info: FileSystemType: "apfs"
12:35:03.847 Info: SizeTotal: 245 GB
12:35:03.847 Info: AvailableSize: 181 GB
12:35:03.847 Info: DISK : /Volumes/qelectrotech
12:35:03.847 Info: SizeTotal: 0 GB
12:35:03.847 Info: AvailableSize: 0 GB
12:35:03.847 Debug: isReadOnly: true (../sources/machine_info.cpp:172, void MachineInfo::send_info_to_debug())
12:35:03.847 Info: DISK USED: /
12:35:04.056 Info: Elements collection reload
https://download.qelectrotech.org/qet/forum_img_2/Capture%20d%e2%80%99%c3%a9cran%202023-02-06%20%c3%a0%2012.37.32.png
https://download.qelectrotech.org/qet/forum_img_2/Capture%20d%e2%80%99%c3%a9cran%202023-02-06%20%c3%a0%2012.48.52.png
Compile and program works well, but if I use macdeployqt to make packaging bundle, bundle crash on launch time.
Long is the road .....
Translated Report (Full Report Below)
Process:               qelectrotech [14278]
Path:                  /Applications/qelectrotech.app/Contents/MacOS/qelectrotech
Identifier:            org.qelectrotech
Version:               0.100.0 r7821 (???)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2023-02-06 12:58:50.0242 +0100
OS Version:            macOS 13.2 (22D49)
Report Version:        12
Anonymous UUID:
Sleep/Wake UUID:
Time Awake Since Boot: 6700 seconds
Time Since Wake:       3610 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_BAD_ACCESS (SIGKILL (Code Signature Invalid))
Exception Codes:       UNKNOWN_0x32 at 0x00000001033f4000
Exception Codes:       0x0000000000000032, 0x00000001033f4000
Termination Reason:    Namespace CODESIGNING, Code 2 Invalid Page
EDIT: Ok some more progress here:
https://kubadownload.com/news/codesign-sign-app/
Todo:
https://eclecticlight.co/2019/01/17/cod … ng-an-app/
https://stackoverflow.com/questions/238 … ile-in-mac
https://stackoverflow.com/questions/426 … er-for-osx
https://wiki.freepascal.org/Notarizatio … 10.14.5%2B
https://github.com/crystalidea/macdeployqt-universal
Ok with:
codesign --force --deep --sign - /Applications/qelectrotech.app
On Apple Silicon M1/M2 try new bundle arm64 packages:
Need after for now:
BTW, sqlite3 export of project database didn't work yet with my new Brew arm64 (Apple silicon) packages, so if you want it use Intel X86_64 bundle dmg build with Macports Digikam script for create compil environment.
Please try qelectrotech.app
https://download.qelectrotech.org/qet/s … ch.app.zip
A native M1 packaging need a signed Apple developer account. You need to pay 100 euros for that by year, which is unacceptable for an open source project. This is not yet the case for x86 packaging.
https://discuss.pixls.us/t/digikam-7-5- … ed/28921/3
I did not study this problem today, but I confirm that QET under mac mini M2 and compiled natively works much better than the package emulated with Roseta 2 and also well under linux or Windows but:
1] You need disabling Gatekeeper
sudo spctl --master-disable
2 ] Then need again to install Xcode program and re-sign the package and its libraries otherwise it will crash on launch...
But a novice macOS user is not going to install the Xcode development program which is very heavy and which takes about ten Giga bytes to run QElectroTech, he wants to click on the bundle, do the editing and simply drag and drop qelectrotech. app to Applications to install it....
From what I understand Apple now obliges and forces to have an Apple developer key to sign the packages for their aplle silicon M1/M2 chips, otherwise it will not install on their imac, mac mini, mac sutdio M1 M2 which are arm64 architecture instead of X86_64 for intel or AMD cpus, on the other hand all this at a cost, and you still have to pay 100 €/year to obtain the key.
I have already spent more than 250 € out of my pocket to buy the cheapest mac mini M2 while waiting for the donations to arrive, having struggled with my PC keyboard and wasting time each time finding where the special keys were regularly used for scripts and code like "#&_-,$!%, etc" I reluctantly decided to pay out of my own pocket for an extended magic keybord keyboard for around 150 €, the paypal kitty is zero at this point. moment, and I have advanced too far on my money side to pay the aplle developer subscription to sign the packages, here is where we are today ...
Unfortunately, I can't afford to keep putting money out of my pocket...as I reach the goal of running QET on Linux as well as macOS M1/M2!
Just a little video to show you that QET works very well on a native arm64 compilation on mac mini M2 8Go 256G:
Much better than intel X86_64 builds emulated by roseta2...
I tried qelectrotech.app on UTM macOS Ventura VM.
Just :
Drag and drop qelectrotech.app in your Applications folder.
Enjoy! nomicons/wink
https://download.qelectrotech.org/qet/forum_img_2/utm_applem1.png
https://download.qelectrotech.org/qet/forum_img_2/utm_applem2.png
https://wiki.freepascal.org/Code_Signing_for_macOS
https://stackoverflow.com/questions/601 … -is-hidden
it was not possible for me to have a free developer account, despite my emails and phone calls with Apple support..
We are not a declared registration so impossible to have a DUNS number, or else I would have to become self-employed...
I was told that it was better to pay with your credit card than with a Paypal account to facilitate authentication..., so I had to pay again out of my pocket 99€/year...
After many hours, and days to learn I couldn't sign a dmg, although codesign -dv -r- /Applications/qelectrotech.app is ok, but QET crashes...on launch or does not launch...
So I modified my scripts to package a zip tarball..
Compile, sign, zip and upload:
The time of compilation is 1 min 5 sec
______________________________________________________________
Copy Qt libraries and private frameworks:
Processing Mac deployment tool...
Copy file missing:
Copying add elements in the bundle...
Copying titleblocks in the bundle...
Copying translations in the bundle...
qelectrotech.app: replacing existing signature
Create disk image:
The process of creating deployable application zip is done.
The disque image is in the folder 'build-aux/mac-osx'.
Would you like to upload MacOS packages qelectrotech-0.100.0-r7840-arm64.zip, n/Y?.
y
xxxxxx@ssh.tuxfamily.org's password:
building file list ...
2 files to consider
    47283680 100%  692.58kB/s    0:01:06 (xfer#1, to-check=0/2)
deleting qelectrotech.app.zip
sent 47289601 bytes  received 48 bytes  587449.06 bytes/sec
total size is 47283680  speedup is 1.00
laurent@mini-de-laurent-1 ~ % codesign -dv -r- /Applications/qelectrotech.app
Executable=/Applications/qelectrotech.app/Contents/MacOS/qelectrotech
Identifier=org.qelectrotech
Format=app bundle with Mach-O thin (arm64)
CodeDirectory v=20400 size=64596 flags=0x0(none) hashes=2012+3 location=embedded
Signature size=8981
Timestamp=20 Mar 2023 at 11:58:52
Info.plist entries=14
TeamIdentifier=Y73WZ6WZ5X
Sealed Resources version=2 rules=13 files=9822
designated => identifier "org.qelectrotech" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = Y73WZ6WZ5X
Next step is learning notarize application for gatekeeper...
https://developer.apple.com/documentati … n_workflow
https://github.com/electron/notarize/issues/88
https://scriptingosx.com/2021/07/notari … otarytool/
https://melatonin.dev/blog/how-to-code- … ins-in-ci/
https://blog.smittytone.net/2022/06/09/ … e-quickly/
https://blog.rampatra.com/how-to-notari … otary-tool
Check Notarizing macOS software before distribution:
https://developer.apple.com/documentati … stribution
Overview
Notarization gives users more confidence that the Developer ID-signed software you distribute has been checked by Apple for malicious components. Notarization is not App Review. The Apple notary service is an automated system that scans your software for malicious content, checks for code-signing issues, and returns the results to you quickly. If there are no issues, the notary service generates a ticket for you to staple to your software; the notary service also publishes that ticket online where Gatekeeper can find it.
When the user first installs or runs your software, the presence of a ticket (either online or attached to the executable) tells Gatekeeper that Apple notarized the software. Gatekeeper then places descriptive information in the initial launch dialog to help the user make an informed choice about whether to launch the app.
laurent@mini-de-laurent-1 ~ % cd MAC_OS_X
laurent@mini-de-laurent-1 MAC_OS_X % xcrun notarytool submit qelectrotech-0.100.0-r7842-arm64.zip --keychain-profile "org.qelectrotech" --wait
Conducting pre-submission checks for qelectrotech-0.100.0-r7842-arm64.zip and initiating connection to the Apple notary service...
Submission ID received
Upload progress: 100,00 % (48,1 MB of 48,1 MB)
Successfully uploaded file
  path: /Users/laurent/MAC_OS_X/qelectrotech-0.100.0-r7842-arm64.zip
Waiting for processing to complete.
Current status: Accepted..............................
Processing complete
  status: Accepted
MacQetDeploy_arm64.sh add Enable hardened runtime flag to fix notarization fail,
Add process to Upload a macOS app to be notarized and validate before upload to QET download servers
The time of compilation is 1 min 3 sec
Copy file missing:
Copying examples in the bundle...
Create zip tarball:
Notarize zip tarball:
  path: /Users/laurent/qet_git/build-aux/mac-osx/qelectrotech-0.100.0-r7842-arm64.zip
Processing complete
  status: Accepted
Would you like to upload MacOS packages qelectrotech-0.100.0-r7842-arm64.zip, n/Y?.
y
xxxxxxx@ssh.tuxfamily.org's password:
2 files to consider
    50451911 100%  692.76kB/s    0:01:11 (xfer#1, to-check=0/2)
deleting qelectrotech-0.100.0-r7840-arm64.zip
sent 50458220 bytes  received 48 bytes  604290.63 bytes/sec
total size is 50451911  speedup is 1.00
C'est incroyable, apple fait tout sont possible pour faire chier les petits dev comme nous..... et en plus il faut payer.....
https://opentoolchain.org/hackathon/
@Joshua:
J'ai été invité par la fondation opentoolchain.org au FOSDEM 2023 tout frais payés pour discuter et rencontrer la fondation et aussi les développeurs FreeCad, malheureusement:
J'ai du refuser au vu de mon état de santé très fragile, étant en arrêt de travail, je ne pouvais pas me permettre de sortir de chez moi et me déplacer en dehors de mon département sans autorisation de la CPAM..., il m’était alors impossible de me déplacer et se rendre au FOSDEM 2023 à Hambourg en Allemagne.. et mon anglais .....c'est de pire en pire ... alzheimer me guette ....
J'ai pensé à toi, mais je sais que la santé de ta compagne est préoccupante et que tu ne pouvais pas faire le déplacement..
https://forum.opentoolchain.org/t/visua … lchains/77
https://forum.opentoolchain.org/uploads/default/original/1X/4d72511df8c698466a22912d9467874f0736e078.png
16 (edited by scorpio810 2023-04-11 17:54:25)
C'est compliqué et je vais essayer de t'expliquer, c'est même impératif pour les puces M1 M2:
https://lessons.livecode.com/m/4071/l/1 … -13-and-up
1 ) il te faut tout d'abord un compte développeur Apple (Apple Developer Account) plus un autre compte (Developer ID Application) pour t'authentifier avec lequel tu signes le contenu de l'application, avec cela tu es certain que le paquet provient bien de moi et moi seul, que le paquet n'a pas été infecté ou bricolé par un autre sur un serveur de download, un peu comme l  SHA256 qu'on utilise aussi avec les signatures sur paquets Linux.
2) La notarization est la suite et un autre ensemble de clé et oui il faut d'autres certificats... two-factor authentication (2FA) qui avec la commande xcrun notarytool submit permet d'envoyer ton paquet sur un serveur Apple afin de vérifier que le 2FA two-factor authentication est valide, que tes signatures correspondent, en même temps il va vérifier que ton paquet ne contient aucun virus et autres saletés.
Ça prend un peu de temps ... le temps de recevoir la validation, si ok mon script fait un rsync pour uploader mon paquet sur les serveurs de Tuxfamily.org ..
A partir de là un ticket est émis correspondant, il va s'ajouter dans la base de données que Gatekeeper va interroger pour valider ou pas le lancement du logiciel, il est aussi possible de joindre ce ticket dans le paquet du logiciel pour ceux qui n'ont pas de réseau.. Je verrais ça plus tard!
Edit: fait!
Voila en quelques mots comment ça fonctionne..
Pour l'instant cela ne concerne que les paquets macOS arm64.
Apres pour que QET soit disponible sur l'APPLE store est une autre paire de manches...
Merci d'avoir pensé à moi pour le FOSDEM, mais effectivement je ne peut pas faire le déplacement pour les raisons que tu évoques…
Au sujet d’Apple, du coup tout ça c’est pour permettre à l’utilisateur de la pomme d’utiliser des logiciels vérifié et exempte de saloperie (pas comme Windows ou l’on peut installer n’importe quoi n’importe comment), mais si le logiciel n’est pas développé par une entreprise ou à minima une asso, c’est tout de suite plus compliqué.
Sur Windows ils y viennent petit à petit, bientôt faudra aussi mettre la main au porte-monnaie pour avoir une License et des certificats de confiance, plus ça va et plus installer QET sur Windows  devient pénible...
Voir ce topic:
https://bugs.kde.org/show_bug.cgi?id=398582
Oui tu payes plein pot, comme si tu étais développeur indépendant et que c'est ton gagne pain... et la validation des certificats, identité plus complexes..
Add the notarization ticket from Apple to qelectrotech.app for arm64 (Apple silicon M1 M2) packages,
this enables Gatekeeper to verify the ticket offline.
Stapling means the notarization ticket is added to the app/DMG.
This step is  not mandatory, but recommended.  It ensures that Gatekeekper can find the notarization ticket even when a network connection (internet connection) isn't available.
Without this step every time an app, dmg  or pkg is launched Gatekeeper has to check online if the PKG/DMG/App was notarized or not.
Stapling ensures that Gatekeeper can approve the notarization even when an internet connection isn't available.
See: https://keith.github.io/xcode-man-pages/stapler.1.html
@Joshua, j'avais préparé le dossier et commencé à remplir les formulaires pour lancer l’association à but non lucratif org.qelectrotech, j'ai du encore une fois abandonner..., déjà ton petit bled est introuvable dans le formulaire de l'état ! un comble !!!....   (d'ailleurs tu dois être bien embêté pour les démarches en ligne sur les sites de l'état, non?) et ça coince tout le reste, j'ai du magouillé en mettant un village à coté de chez toi, bref! ensuite je me suis heurté au document de création et définition de l'association qu'on doit signer des deux parties, Là j'ai tout lâché  ... impossible pour moi de continuer au vu de ma santé précaire...., de plus mon cerveau semble rebuter toutes les taches administratives en ce moment...
Je pense qu'il faudra qu'on se fasse épauler pour enfin avoir un statut juridique après tout ce temps ....(10 ans qu'on gèrent ensemble le projet QET) enfin créer de créer un but légal et une association loi 1911.
T'en penses quoi?
Sur le peu de dons qu'on reçoit c'est dommage qu'il faille y puiser dans ce compte 99€/an juste pour les utilisateurs Apple sur M1/M2...alors que Apple offre l'abonnement aux développeurs open source...mais il faut un pouvoir fournir un "number DUNS", on m'a donc répondu par Altares qui était chargé du dossier par Apple: que soit tu es un auto-entrepreneur ou une association, sinon c'est impossible..pour un particulier..
Nous sommes sollicités par APPLE pour attribuer un numéro de DUNS à votre entité.
Nous ne sommes pas arrivés à localiser votre société auprès des sources officielles.
Pouvez-vous nous communiquer votre numéro de Registre de Commerce, sans lequel nous ne pouvons attribuer de numéro de DUNS à votre entreprise.
Merci pour votre retour,
Pour obtenir un numéro de duns, il faut que vous soyez impérativement inscrit à l’INSEE en tant qu’AUTO-ENTREPENEUR.
Une fois l’inscription effectuée, vous obtiendrez un numéro siret.
On ne vend pas le logiciel, il est libre et gratuit!, créer un compte AUTO-ENTREPENEUR ... juste pour ça?, c'est vraiment n'importe quoi ....
22 (edited by Joshua 2023-05-02 21:46:21)
Non ça va au niveau des démarches en ligne, c'est juste que depuis le regroupement des 3 communes voisine le nom de la commune à changer..... mais a quand même gardé l'ancien nom (comme les deux autres commune d'ailleurs) du coup c'est soit l'un soit l'autre en fonction duquel existe dans la base de donné du truc que tu consulte.
Ce que j'en pense : je comprend l’intérêt de créer une association afin de faciliter bon nombre de chose, hélas toi comme moi avons un temps libre limité. Je pense qu'il vaux mieux laisser tomber actuellement, prend soins de toi c'est plus important que de te créer des soucis supplémentaire, moi de mon coté je n'ai clairement pas le temps de m'occuper de ça (en ce moment je n'ai même plus le temps de coder nomicons/sad )
Et non on ne va pas créer un compte auto-entrepreneur pour du bénévolat.
Pour info (Laurent et les autres) si vous avez l'habitude de lire linuxfr, les journaux de https://linuxfr.org/users/jehan au sujet de gimp sont intéressant, entre autre il parle des difficulté qu'ils ont à ceux sujet malgré l'age et la base d'utilisateurs de gimp (qui doit être sans commune mesure avec qet) tous ça pour dire qu'il ne faut pas trop se tracassé avec ça, on est juste trop petit et en plus un "marché" de niche.
Lire les retours des dev de logiciel libre et gratuit permet de comparer nos experience et je trouve qu'on s'en sort pas trop mal (surtout quand on regarde d'où l'on vient)
PS:
Je trouve ta photo de profil plus sympa que l'ancienne nomicons/wink.
En ce moment si je m’écoutais je passerai mon temps à dormir ... ou à lire sur ma liseuse ..
Madame m'oblige à aller marcher un peu quand il fait beau..., elle n'a pas tord c'est un cercle vicieux et tu perds très vite la forme si tu ne fais rien ... meme si c'est parfois très dur ...
J'ai avalé des dizaines de tomes entiers ces quelques mois d'hivers:
L’intégrale des annales de la compagnie noire de Glen Cook que j'ai vraiment adoré, puis j'ai enchaîné sur l'intégrale de l'ange du chaos de Michel Rober, j'ai tellement aimé que j'ai aussi lu presque d'une traite les autres romans associé.. et ceux de Rodolphe Vanhoorde, un régal..
PS:
Je trouve ta photo de profil plus sympa que l'ancienne .
Merçi, Je sais ... je n'ai pas besoin de forcer pour avoir l'air très sévère ...nomicons/wink
J'ai aussi lu tous les articles de Jehan Mainteneur GIMP sur Linuxfr.org et je le comprend, vu qu'on est dans le même cas..
Apres les entreprises qui veulent et peuvent payer une fonctionnalité ou nouvelles features pour QET peuvent par exemple s'adresser à KDAB ce sont des experts Qt C++ ils participent activement à Qt et aussi à KDE mon environnement de bureau et framework Linux préféré.
https://www.kdab.com/fr/
Not able to open a *.qet file with double click under osx
https://github.com/qelectrotech/qelectr … issues/218
On OSX you can't launch the same application several times, so QtSingleApplication is useless.
Catching the FileOpenEvent is the only way ...
https://forum.qt.io/topic/80205/open-fi … ick-on-mac
But I just read this and we use itay-grudev SingleApplication:
https://github.com/itay-grudev/SingleAp … issues/136
Well, for the moment I haven't understood everything, pfiuou Apple complicates everything unnecessarily... nomicons/sad
in short, a lot of work just for this small function....
Wow, this seems a major burden and a piece of work to support Apple.  Frankly, I would have stopped supporting the platform at all after all these troubles.  Not a big fan of the company anyway, but charging developers to allow users running their software is just... rude!  In the early computer days, some hardware vendors had a market advantage because they made it easy for software developers to write programs for their platform.  Somehow for a company of Apple's size, these economic mechanisms don't work anymore.  Except if people start sabotaging this madness and just stay away from Apple, especially those people putting in their volunteer work to publish open source software.
Enough ranting...  I didn't understand everything in this thread, unfortunately, since my French is very rudimentary. I'd be happy if more posts could stick to English language, as it's more accessible to the rest of the world ;-)
